PiGraham
Re: Adafruit LCD on 8bit interface
Fri Sep 05, 2014 5:34 pm
notro wrote:The BeagleBone Black 4" LCD cape has an onboard 74AVC32T245: 32-bit dual supply translating transceiver with configurable voltage translation; 3-state
It is used on all the LCD signals, and since both the display and the BBB works at 3.3V it doesn't act as a level shifter.
What's the purpose of this arrangement? To clean up the signals? (your display also has a 74LVC245, but the purpose here is level shifting)
Some Beagle boards run 1.8v I/O so I guess the shifter is to allow the cape to work with other models?
notro
Fri Sep 05, 2014 10:07 pm
Thanks, I wasn't aware of that. So the purpose is level shifting.
Ref: http://elinux.org/BeagleBoard_Hardware_ ... 1.8V_I.2FO
mwilliams03
Sun Dec 28, 2014 8:29 pm
Hi
I've been watching this thread with interest.
How are hard is it to change Peter's code to a 16bit parallel write?
I have been experimenting with some basic GPIO macros and I can get a 320x480 display to update in 70ms, via 16 parallel write on a B+. However I want to go faster.
A copy of my code can be found here;
http://ozzmaker.com/piscreen/PiScreen-16bitParallel.c
I compile with -O3 option.
Mark -- OzzMaker.com -- Creator of;
+ BerryIMU
+ Berry GPS-IMU
+BerryGPS-GSM
+ PiScreen - A 3.5" TFT for the Rasspberry Pi
peepo
Fri May 22, 2015 4:50 pm
Is there a clear simple write up anywhere?
cannot find introduction for Raspberry Pi.
8bit digital interface looks to be a great alternative to SPI,
ie SPI is already being used.
though it does look quite a beast.
Is it included in Device Tree?
or maybe not needed?**
thanks again
Jonathan
**this looks like DT notation:
https://github.com/notro/fbtft/wiki/Performance#itdb28
