bilkpchan
infra red remote control
Fri Aug 01, 2014 11:14 am
hello,
i have connected a infared receiver directly in the gpio to receive a signal from the remote control. it works when i turn off the tv. but it doesn’t work when i turn on the tv. i place the pi just 0.5m beside the lcd tv.
anyone has idea why? thank
bill
FLYFISH TECHNOLOGIES
Re: infra red remote control
Fri Aug 01, 2014 3:43 pm
Hi Bill,
bilkpchan wrote:anyone has idea why?
Please provide us details - schematics with listed parts, description of the software you installed/wrote.
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
bilkpchan
Mon Aug 04, 2014 4:27 pm
hi,
l am using ir receiver “TSOP1238“ and direct connected the thee pins to the gpio in pi . the device driver is lirc.
i type the following command to test the ir receiver :
sudo mode2 -d /dev/lirc0
it show a lot of signal/pulse received when i turn on the tv
when i turn off the tv, only one signal/pulse show on screen when i press a button on remote control
thanks
Mon Aug 04, 2014 4:37 pm
HI,
bilkpchan wrote:l am using ir receiver “TSOP1238“
This receiver is 5V device. If you supply it:
- with 3.3V, it's out of spec.
- with 5V, then it's not best idea to connect its output directly to GPIO...
Ferdinand
Tue Aug 05, 2014 12:57 pm
Hi Bill,
Take a look at this thread: http://www.raspberrypi.org/forums/viewt ... 44&t=74407
(Transistor for IR Transmitter)
or
http://lirc.org
(Linux Infrared Remote Control)
or
otherwise post drawings, setups, software a.s.o.
-->(small) details are very important!
Good Luck with your project.
Success with your project!
Ferdinand
