[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.12.22+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #691 PREEMPT Wed Jun 18 18:29:58 BST 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 8 MiB at 1b800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c05fcdf0, node_mem_map c06ae000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708.boardrev=0xe bcm2708.serial=0x8557799d smsc95xx.macaddr=B8:27:EB:57:79:9D sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 439664K/458752K available (4376K kernel code, 238K rwdata, 1340K rodata, 143K init, 701K bss, 19088K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc059d54c (5718 kB)
[ 0.000000] .init : 0xc059e000 - 0xc05c1ee4 ( 144 kB)
[ 0.000000] .data : 0xc05c2000 - 0xc05fd900 ( 239 kB)
[ 0.000000] .bss : 0xc05fd90c - 0xc06ad0f8 ( 702 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:394
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001265] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001327] pid_max: default: 32768 minimum: 301
[ 0.001826] Mount-cache hash table entries: 512
[ 0.002661] Initializing cgroup subsys memory
[ 0.002770] Initializing cgroup subsys devices
[ 0.002809] Initializing cgroup subsys freezer
[ 0.002842] Initializing cgroup subsys blkio
[ 0.002985] CPU: Testing write buffer coherency: ok
[ 0.003447] Setting up static identity map for 0xc0427670 - 0xc04276cc
[ 0.005361] devtmpfs: initialized
[ 0.022065] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.023660] NET: Registered protocol family 16
[ 0.029064] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.029748] cpuidle: using governor ladder
[ 0.029794] cpuidle: using governor menu
[ 0.030396] bcm2708.uart_clock = 0
[ 0.032225] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.032280] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.032317] mailbox: Broadcom VideoCore Mailbox driver
[ 0.032418] bcm2708_vcio: mailbox at f200b880
[ 0.032527] bcm_power: Broadcom power driver
[ 0.032565] bcm_power_open() -> 0
[ 0.032591] bcm_power_request(0, 8)
[ 0.533317] bcm_mailbox_read -> 00000080, 0
[ 0.533358] bcm_power_request -> 0
[ 0.533591] Serial: AMBA PL011 UART driver
[ 0.533763] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.892096] console [ttyAMA0] enabled
[ 0.918979] bio: create slab <bio-0> at 0
[ 0.924505] SCSI subsystem initialized
[ 0.928501] usbcore: registered new interface driver usbfs
[ 0.934206] usbcore: registered new interface driver hub
[ 0.939766] usbcore: registered new device driver usb
[ 0.946396] Switched to clocksource stc
[ 0.950658] FS-Cache: Loaded
[ 0.953812] CacheFiles: Loaded
[ 0.969537] NET: Registered protocol family 2
[ 0.975032] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.982441] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.989013] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.995463] TCP: reno registered
[ 0.998763] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.004633] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.011392] NET: Registered protocol family 1
[ 1.016322] RPC: Registered named UNIX socket transport module.
[ 1.022381] RPC: Registered udp transport module.
[ 1.027140] RPC: Registered tcp transport module.
[ 1.031859] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.039240] bcm2708_dma: DMA manager at f2007000
[ 1.043979] bcm2708_gpio: bcm2708_gpio_probe c05cfed0
[ 1.049545] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.059161] audit: initializing netlink socket (disabled)
[ 1.064667] type=2000 audit(0.910:1): initialized
[ 1.231326] VFS: Disk quotas dquot_6.5.2
[ 1.235598] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.244609] FS-Cache: Netfs 'nfs' registered for caching
[ 1.251575] NFS: Registering the id_resolver key type
[ 1.256868] Key type id_resolver registered
[ 1.261075] Key type id_legacy registered
[ 1.265839] msgmni has been set to 874
[ 1.271655] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.279517] io scheduler noop registered
[ 1.283471] io scheduler deadline registered (default)
[ 1.289071] io scheduler cfq registered
[ 1.294239] BCM2708FB: allocated DMA memory 5bc00000
[ 1.299423] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.329794] Console: switching to colour frame buffer device 228x61
[ 1.350438] uart-pl011 dev:f1: no DMA platform data
[ 1.356097] vc-cma: Videocore CMA driver
[ 1.360196] vc-cma: vc_cma_base = 0x00000000
[ 1.364994] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.370578] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.385707] brd: module loaded
[ 1.394463] loop: module loaded
[ 1.398066] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[ 1.406149] Loading iSCSI transport class v2.0-870.
[ 1.412439] usbcore: registered new interface driver smsc95xx
[ 1.418669] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.624761] Core Release: 2.80a
[ 1.628097] Setting default values for core params
[ 1.633025] Finished setting default values for core params
[ 1.838815] Using Buffer DMA mode
[ 1.842219] Periodic Transfer Interrupt Enhancement - disabled
[ 1.848188] Multiprocessor Interrupt Enhancement - disabled
[ 1.853862] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.858343] Dedicated Tx FIFOs mode
[ 1.862275] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xdbc14000 dma = 0x5bc14000 len=9024
[ 1.872362] FIQ FSM acceleration enabled for :
[ 1.872362] Non-periodic Split Transactions
[ 1.872362] Periodic Split Transactions
[ 1.872362] High-Speed Isochronous Endpoints
[ 1.889371] dwc_otg: Microframe scheduler enabled
[ 1.889461] WARN::hcd_init:473: FIQ at 0xc03080cc
[ 1.894270] WARN::hcd_init:474: FIQ ASM at 0xc0308348 length 36
[ 1.904580] WARN::hcd_init:500: MPHI regs_base at 0xdc806000
[ 1.914555] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.923690] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.935272] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.945048] Init: Port Power? op_state=1
[ 1.953090] Init: Power Port (0)
[ 1.960816] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.971903] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.983483] usb usb1: Product: DWC OTG Controller
[ 1.992505] usb usb1: Manufacturer: Linux 3.12.22+ dwc_otg_hcd
[ 2.002643] usb usb1: SerialNumber: bcm2708_usb
[ 2.012380] hub 1-0:1.0: USB hub found
[ 2.020482] hub 1-0:1.0: 1 port detected
[ 2.029223] dwc_otg: FIQ enabled
[ 2.029241] dwc_otg: NAK holdoff enabled
[ 2.029252] dwc_otg: FIQ split-transaction FSM enabled
[ 2.029274] Module dwc_common_port init
[ 2.029752] usbcore: registered new interface driver usb-storage
[ 2.040439] mousedev: PS/2 mouse device common for all mice
[ 2.051036] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 2.061270] bcm2835-cpufreq: switching to governor powersave
[ 2.071156] bcm2835-cpufreq: switching to governor powersave
[ 2.081131] sdhci: Secure Digital Host Controller Interface driver
[ 2.091463] sdhci: Copyright(c) Pierre Ossman
[ 2.100171] sdhci: Enable low-latency mode
[ 2.146482] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.158732] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.169090] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.181150] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.198848] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.208890] usbcore: registered new interface driver usbhid
[ 2.220898] usbhid: USB HID core driver
[ 2.231278] Indeed it is in host mode hprt0 = 00021501
[ 2.245501] TCP: cubic registered
[ 2.266460] Initializing XFRM netlink socket
[ 2.278181] NET: Registered protocol family 17
[ 2.296722] Key type dns_resolver registered
[ 2.318154] registered taskstats version 1
[ 2.347649] Waiting for root device /dev/mmcblk0p6...
[ 2.359130] mmc0: read SD Status register (SSR) after 2 attempts
[ 2.388126] mmc0: new high speed SDHC card at address 1234
[ 2.398690] mmcblk0: mmc0:1234 SA08G 7.42 GiB
[ 2.413008] mmcblk0: p1 p2 < p5 p6 > p3
[ 2.496646] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.508357] Indeed it is in host mode hprt0 = 00001101
[ 2.716832] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.728055] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.740287] hub 1-1:1.0: USB hub found
[ 2.748584] hub 1-1:1.0: 5 ports detected
[ 3.036614] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.146854] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.158136] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.172797] smsc95xx v1.0.4
[ 3.240245] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:57:79:9d
[ 3.336560] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.449990] usb 1-1.2: New USB device found, idVendor=eb1a, idProduct=2821
[ 3.461434] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.473202] usb 1-1.2: Product: USB 2821 Device
[ 3.576620] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[ 3.691371] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c534
[ 3.702996] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.714874] usb 1-1.3: Product: USB Receiver
[ 3.723608] usb 1-1.3: Manufacturer: Logitech
[ 3.742814] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input0
[ 3.758162] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-bcm2708_usb-1.3/input0
[ 3.794988] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input1
[ 3.811055] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-bcm2708_usb-1.3/input1
[ 8.959516] EXT4-fs (mmcblk0p6): recovery complete
[ 8.980412] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 8.993687] VFS: Mounted root (ext4 filesystem) on device 179:6.
[ 9.011030] devtmpfs: mounted
[ 9.019684] Freeing unused kernel memory: 140K (c059e000 - c05c1000)
[ 10.616062] udevd[156]: starting version 175
[ 13.066370] media: Linux media interface: v0.10
[ 13.080357] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 13.344740] Linux video capture interface: v2.00
[ 13.914649] em28xx: New device USB 2821 Device @ 480 Mbps (eb1a:2821, interface 0, class 0)
[ 14.244526] em28xx: Video interface 0 found: bulk isoc
[ 14.432191] em28xx: chip ID is em2710/2820
[ 14.728361] em2710/2820 #0: i2c eeprom 00: 1a eb 67 95 1a eb 21 28 90 00 11 03 6a 22 00 00
[ 14.837282] em2710/2820 #0: i2c eeprom 10: 00 00 04 57 06 21 00 00 00 00 00 00 00 00 00 00
[ 14.936745] em2710/2820 #0: i2c eeprom 20: 02 00 01 01 f0 10 00 00 00 00 00 00 5b 00 00 00
[ 15.021410] em2710/2820 #0: i2c eeprom 30: 00 00 20 40 20 80 02 20 01 01 03 01 00 00 00 00
[ 15.104882] em2710/2820 #0: i2c eeprom 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 15.176651] em2710/2820 #0: i2c eeprom 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 15.198051] em2710/2820 #0: i2c eeprom 60: 00 00 00 00 00 00 00 00 00 00 22 03 55 00 53 00
[ 15.212576] em2710/2820 #0: i2c eeprom 70: 42 00 20 00 32 00 38 00 32 00 31 00 20 00 44 00
[ 15.227147] em2710/2820 #0: i2c eeprom 80: 65 00 76 00 69 00 63 00 65 00 00 00 00 00 00 00
[ 15.241527] em2710/2820 #0: i2c eeprom 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 15.255816] em2710/2820 #0: i2c eeprom a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 15.279046] em2710/2820 #0: i2c eeprom b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 15.305760] em2710/2820 #0: i2c eeprom c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 15.323264] em2710/2820 #0: i2c eeprom d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 15.337569] em2710/2820 #0: i2c eeprom e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 15.351506] em2710/2820 #0: i2c eeprom f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 15.365467] em2710/2820 #0: EEPROM ID = 1a eb 67 95, EEPROM hash = 0x26da7a8a
[ 15.379280] em2710/2820 #0: EEPROM info:
[ 15.388276] em2710/2820 #0: AC97 audio (5 sample rates)
[ 15.398713] em2710/2820 #0: 500mA max power
[ 15.408053] em2710/2820 #0: Table at offset 0x04, strings=0x226a, 0x0000, 0x0000
[ 15.516691] em2710/2820 #0: No sensor detected
[ 15.538344] em2710/2820 #0: found i2c device @ 0x4a on bus 0 [saa7113h]
[ 15.564363] em2710/2820 #0: found i2c device @ 0xa0 on bus 0 [eeprom]
[ 15.591274] em2710/2820 #0: Your board has no unique USB ID and thus need a hint to be detected.
[ 15.605202] em2710/2820 #0: You may try to use card=<n> insmod option to workaround that.
[ 15.618410] em2710/2820 #0: Please send an email with this log to:
[ 15.629526] em2710/2820 #0: V4L Mailing List <
linux-media@vger.kernel.org>
[ 15.641322] em2710/2820 #0: Board eeprom hash is 0x26da7a8a
[ 15.651835] em2710/2820 #0: Board i2c devicelist hash is 0x6ba50080
[ 15.663029] em2710/2820 #0: Here is a list of valid choices for the card=<n> insmod option:
[ 15.676249] em2710/2820 #0: card=0 -> Unknown EM2800 video grabber
[ 15.687649] em2710/2820 #0: card=1 -> Unknown EM2750/28xx video grabber
[ 15.699636] em2710/2820 #0: card=2 -> Terratec Cinergy 250 USB
[ 15.710710] em2710/2820 #0: card=3 -> Pinnacle PCTV USB 2
[ 15.721268] em2710/2820 #0: card=4 -> Hauppauge WinTV USB 2
[ 15.731985] em2710/2820 #0: card=5 -> MSI VOX USB 2.0
[ 15.742088] em2710/2820 #0: card=6 -> Terratec Cinergy 200 USB
[ 15.754627] em2710/2820 #0: card=7 -> Leadtek Winfast USB II
[ 15.775423] em2710/2820 #0: card=8 -> Kworld USB2800
[ 15.794432] em2710/2820 #0: card=9 -> Pinnacle Dazzle DVC 90/100/101/107 / Kaiser Baas Video to DVD maker / Kworld DVD Maker 2 / Plextor ConvertX PX-AV100U
[ 15.813461] em2710/2820 #0: card=10 -> Hauppauge WinTV HVR 900
[ 15.824235] em2710/2820 #0: card=11 -> Terratec Hybrid XS
[ 15.834703] em2710/2820 #0: card=12 -> Kworld PVR TV 2800 RF
[ 15.845260] em2710/2820 #0: card=13 -> Terratec Prodigy XS
[ 15.855458] em2710/2820 #0: card=14 -> SIIG AVTuner-PVR / Pixelview Prolink PlayTV USB 2.0
[ 15.868551] em2710/2820 #0: card=15 -> V-Gear PocketTV
[ 15.878449] em2710/2820 #0: card=16 -> Hauppauge WinTV HVR 950
[ 15.888834] em2710/2820 #0: card=17 -> Pinnacle PCTV HD Pro Stick
[ 15.899679] em2710/2820 #0: card=18 -> Hauppauge WinTV HVR 900 (R2)
[ 15.910587] em2710/2820 #0: card=19 -> EM2860/SAA711X Reference Design
[ 15.921592] em2710/2820 #0: card=20 -> AMD ATI TV Wonder HD 600
[ 15.932021] em2710/2820 #0: card=21 -> eMPIA Technology, Inc. GrabBeeX+ Video Encoder
[ 15.944323] em2710/2820 #0: card=22 -> EM2710/EM2750/EM2751 webcam grabber
[ 15.955533] em2710/2820 #0: card=23 -> Huaqi DLCW-130
[ 15.965011] em2710/2820 #0: card=24 -> D-Link DUB-T210 TV Tuner
[ 15.975274] em2710/2820 #0: card=25 -> Gadmei UTV310
[ 15.984558] em2710/2820 #0: card=26 -> Hercules Smart TV USB 2.0
[ 15.994926] em2710/2820 #0: card=27 -> Pinnacle PCTV USB 2 (Philips FM1216ME)
[ 16.006319] em2710/2820 #0: card=28 -> Leadtek Winfast USB II Deluxe
[ 16.017109] em2710/2820 #0: card=29 -> EM2860/TVP5150 Reference Design
[ 16.028088] em2710/2820 #0: card=30 -> Videology 20K14XUSB USB2.0
[ 16.038524] em2710/2820 #0: card=31 -> Usbgear VD204v9
[ 16.048051] em2710/2820 #0: card=32 -> Supercomp USB 2.0 TV
[ 16.058006] em2710/2820 #0: card=33 -> Elgato Video Capture
[ 16.068027] em2710/2820 #0: card=34 -> Terratec Cinergy A Hybrid XS
[ 16.080487] em2710/2820 #0: card=35 -> Typhoon DVD Maker
[ 16.098831] em2710/2820 #0: card=36 -> NetGMBH Cam
[ 16.116623] em2710/2820 #0: card=37 -> Gadmei UTV330
[ 16.126215] em2710/2820 #0: card=38 -> Yakumo MovieMixer
[ 16.137323] em2710/2820 #0: card=39 -> KWorld PVRTV 300U
[ 16.147393] em2710/2820 #0: card=40 -> Plextor ConvertX PX-TV100U
[ 16.158050] em2710/2820 #0: card=41 -> Kworld 350 U DVB-T
[ 16.168017] em2710/2820 #0: card=42 -> Kworld 355 U DVB-T
[ 16.177923] em2710/2820 #0: card=43 -> Terratec Cinergy T XS
[ 16.187936] em2710/2820 #0: card=44 -> Terratec Cinergy T XS (MT2060)
[ 16.198766] em2710/2820 #0: card=45 -> Pinnacle PCTV DVB-T
[ 16.208619] em2710/2820 #0: card=46 -> Compro, VideoMate U3
[ 16.218538] em2710/2820 #0: card=47 -> KWorld DVB-T 305U
[ 16.228227] em2710/2820 #0: card=48 -> KWorld DVB-T 310U
[ 16.237725] em2710/2820 #0: card=49 -> MSI DigiVox A/D
[ 16.247114] em2710/2820 #0: card=50 -> MSI DigiVox A/D II
[ 16.256601] em2710/2820 #0: card=51 -> Terratec Hybrid XS Secam
[ 16.266724] em2710/2820 #0: card=52 -> DNT DA2 Hybrid
[ 16.275862] em2710/2820 #0: card=53 -> Pinnacle Hybrid Pro
[ 16.285470] em2710/2820 #0: card=54 -> Kworld VS-DVB-T 323UR
[ 16.295230] em2710/2820 #0: card=55 -> Terratec Cinnergy Hybrid T USB XS (em2882)
[ 16.306807] em2710/2820 #0: card=56 -> Pinnacle Hybrid Pro (330e)
[ 16.317082] em2710/2820 #0: card=57 -> Kworld PlusTV HD Hybrid 330
[ 16.327395] em2710/2820 #0: card=58 -> Compro VideoMate ForYou/Stereo
[ 16.337874] em2710/2820 #0: card=59 -> (null)
[ 16.346247] em2710/2820 #0: card=60 -> Hauppauge WinTV HVR 850
[ 16.356088] em2710/2820 #0: card=61 -> Pixelview PlayTV Box 4 USB 2.0
[ 16.366697] em2710/2820 #0: card=62 -> Gadmei TVR200
[ 16.375729] em2710/2820 #0: card=63 -> Kaiomy TVnPC U2
[ 16.385006] em2710/2820 #0: card=64 -> Easy Cap Capture DC-60
[ 16.394792] em2710/2820 #0: card=65 -> IO-DATA GV-MVP/SZ
[ 16.403910] em2710/2820 #0: card=66 -> Empire dual TV
[ 16.412829] em2710/2820 #0: card=67 -> Terratec Grabby
[ 16.421740] em2710/2820 #0: card=68 -> Terratec AV350
[ 16.430629] em2710/2820 #0: card=69 -> KWorld ATSC 315U HDTV TV Box
[ 16.440681] em2710/2820 #0: card=70 -> Evga inDtube
[ 16.449370] em2710/2820 #0: card=71 -> Silvercrest Webcam 1.3mpix
[ 16.459301] em2710/2820 #0: card=72 -> Gadmei UTV330+
[ 16.468161] em2710/2820 #0: card=73 -> Reddo DVB-C USB TV Box
[ 16.477745] em2710/2820 #0: card=74 -> Actionmaster/LinXcel/Digitus VC211A
[ 16.488386] em2710/2820 #0: card=75 -> Dikom DK300
[ 16.497009] em2710/2820 #0: card=76 -> KWorld PlusTV 340U or UB435-Q (ATSC)
[ 16.507934] em2710/2820 #0: card=77 -> EM2874 Leadership ISDBT
[ 16.519482] em2710/2820 #0: card=78 -> PCTV nanoStick T2 290e
[ 16.536577] em2710/2820 #0: card=79 -> Terratec Cinergy H5
[ 16.545978] em2710/2820 #0: card=80 -> PCTV DVB-S2 Stick (460e)
[ 16.565753] em2710/2820 #0: card=81 -> Hauppauge WinTV HVR 930C
[ 16.575722] em2710/2820 #0: card=82 -> Terratec Cinergy HTC Stick
[ 16.585700] em2710/2820 #0: card=83 -> Honestech Vidbox NW03
[ 16.595201] em2710/2820 #0: card=84 -> MaxMedia UB425-TC
[ 16.604265] em2710/2820 #0: card=85 -> PCTV QuatroStick (510e)
[ 16.613889] em2710/2820 #0: card=86 -> PCTV QuatroStick nano (520e)
[ 16.623817] em2710/2820 #0: card=87 -> Terratec Cinergy HTC USB XS
[ 16.633751] em2710/2820 #0: card=88 -> C3 Tech Digital Duo HDTV/SDTV USB
[ 16.644206] em2710/2820 #0: card=89 -> Delock 61959
[ 16.652773] em2710/2820 #0: Board not discovered
[ 16.660766] em2710/2820 #0: Identified as Unknown EM2750/28xx video grabber (card=1)
[ 16.671926] em2710/2820 #0: Your board has no unique USB ID and thus need a hint to be detected.
[ 16.684248] em2710/2820 #0: You may try to use card=<n> insmod option to workaround that.
[ 16.696028] em2710/2820 #0: Please send an email with this log to:
[ 16.705691] em2710/2820 #0: V4L Mailing List <
[ 16.716364] em2710/2820 #0: Board eeprom hash is 0x26da7a8a
[ 16.725584] em2710/2820 #0: Board i2c devicelist hash is 0x6ba50080
[ 16.735489] em2710/2820 #0: Here is a list of valid choices for the card=<n> insmod option:
[ 16.747586] em2710/2820 #0: card=0 -> Unknown EM2800 video grabber
[ 16.757792] em2710/2820 #0: card=1 -> Unknown EM2750/28xx video grabber
[ 16.768529] em2710/2820 #0: card=2 -> Terratec Cinergy 250 USB
[ 16.779849] em2710/2820 #0: card=3 -> Pinnacle PCTV USB 2
[ 16.789395] em2710/2820 #0: card=4 -> Hauppauge WinTV USB 2
[ 16.800911] em2710/2820 #0: card=5 -> MSI VOX USB 2.0
[ 16.816582] em2710/2820 #0: card=6 -> Terratec Cinergy 200 USB
[ 16.836588] em2710/2820 #0: card=7 -> Leadtek Winfast USB II
[ 16.848233] em2710/2820 #0: card=8 -> Kworld USB2800
[ 16.857522] em2710/2820 #0: card=9 -> Pinnacle Dazzle DVC 90/100/101/107 / Kaiser Baas Video to DVD maker / Kworld DVD Maker 2 / Plextor ConvertX PX-AV100U
[ 16.875907] em2710/2820 #0: card=10 -> Hauppauge WinTV HVR 900
[ 16.886203] em2710/2820 #0: card=11 -> Terratec Hybrid XS
[ 16.896020] em2710/2820 #0: card=12 -> Kworld PVR TV 2800 RF
[ 16.905931] em2710/2820 #0: card=13 -> Terratec Prodigy XS
[ 16.915825] em2710/2820 #0: card=14 -> SIIG AVTuner-PVR / Pixelview Prolink PlayTV USB 2.0
[ 16.928501] em2710/2820 #0: card=15 -> V-Gear PocketTV
[ 16.937888] em2710/2820 #0: card=16 -> Hauppauge WinTV HVR 950
[ 16.948071] em2710/2820 #0: card=17 -> Pinnacle PCTV HD Pro Stick
[ 16.958492] em2710/2820 #0: card=18 -> Hauppauge WinTV HVR 900 (R2)
[ 16.969131] em2710/2820 #0: card=19 -> EM2860/SAA711X Reference Design
[ 16.980071] em2710/2820 #0: card=20 -> AMD ATI TV Wonder HD 600
[ 16.990278] em2710/2820 #0: card=21 -> eMPIA Technology, Inc. GrabBeeX+ Video Encoder
[ 17.002541] em2710/2820 #0: card=22 -> EM2710/EM2750/EM2751 webcam grabber
[ 17.013887] em2710/2820 #0: card=23 -> Huaqi DLCW-130
[ 17.023299] em2710/2820 #0: card=24 -> D-Link DUB-T210 TV Tuner
[ 17.033715] em2710/2820 #0: card=25 -> Gadmei UTV310
[ 17.043150] em2710/2820 #0: card=26 -> Hercules Smart TV USB 2.0
[ 17.053629] em2710/2820 #0: card=27 -> Pinnacle PCTV USB 2 (Philips FM1216ME)
[ 17.065269] em2710/2820 #0: card=28 -> Leadtek Winfast USB II Deluxe
[ 17.076130] em2710/2820 #0: card=29 -> EM2860/TVP5150 Reference Design
[ 17.087148] em2710/2820 #0: card=30 -> Videology 20K14XUSB USB2.0
[ 17.097784] em2710/2820 #0: card=31 -> Usbgear VD204v9
[ 17.107416] em2710/2820 #0: card=32 -> Supercomp USB 2.0 TV
[ 17.117509] em2710/2820 #0: card=33 -> Elgato Video Capture
[ 17.127541] em2710/2820 #0: card=34 -> Terratec Cinergy A Hybrid XS
[ 17.139995] em2710/2820 #0: card=35 -> Typhoon DVD Maker
[ 17.158526] em2710/2820 #0: card=36 -> NetGMBH Cam
[ 17.176625] em2710/2820 #0: card=37 -> Gadmei UTV330
[ 17.186123] em2710/2820 #0: card=38 -> Yakumo MovieMixer
[ 17.197093] em2710/2820 #0: card=39 -> KWorld PVRTV 300U
[ 17.206992] em2710/2820 #0: card=40 -> Plextor ConvertX PX-TV100U
[ 17.217658] em2710/2820 #0: card=41 -> Kworld 350 U DVB-T
[ 17.227547] em2710/2820 #0: card=42 -> Kworld 355 U DVB-T
[ 17.237341] em2710/2820 #0: card=43 -> Terratec Cinergy T XS
[ 17.247427] em2710/2820 #0: card=44 -> Terratec Cinergy T XS (MT2060)
[ 17.258222] em2710/2820 #0: card=45 -> Pinnacle PCTV DVB-T
[ 17.268121] em2710/2820 #0: card=46 -> Compro, VideoMate U3
[ 17.278119] em2710/2820 #0: card=47 -> KWorld DVB-T 305U
[ 17.287723] em2710/2820 #0: card=48 -> KWorld DVB-T 310U
[ 17.297367] em2710/2820 #0: card=49 -> MSI DigiVox A/D
[ 17.306775] em2710/2820 #0: card=50 -> MSI DigiVox A/D II
[ 17.316338] em2710/2820 #0: card=51 -> Terratec Hybrid XS Secam
[ 17.326523] em2710/2820 #0: card=52 -> DNT DA2 Hybrid
[ 17.335672] em2710/2820 #0: card=53 -> Pinnacle Hybrid Pro
[ 17.345308] em2710/2820 #0: card=54 -> Kworld VS-DVB-T 323UR
[ 17.355002] em2710/2820 #0: card=55 -> Terratec Cinnergy Hybrid T USB XS (em2882)
[ 17.366621] em2710/2820 #0: card=56 -> Pinnacle Hybrid Pro (330e)
[ 17.376826] em2710/2820 #0: card=57 -> Kworld PlusTV HD Hybrid 330
[ 17.387112] em2710/2820 #0: card=58 -> Compro VideoMate ForYou/Stereo
[ 17.397706] em2710/2820 #0: card=59 -> (null)
[ 17.406058] em2710/2820 #0: card=60 -> Hauppauge WinTV HVR 850
[ 17.416029] em2710/2820 #0: card=61 -> Pixelview PlayTV Box 4 USB 2.0
[ 17.426645] em2710/2820 #0: card=62 -> Gadmei TVR200
[ 17.435640] em2710/2820 #0: card=63 -> Kaiomy TVnPC U2
[ 17.444883] em2710/2820 #0: card=64 -> Easy Cap Capture DC-60
[ 17.454572] em2710/2820 #0: card=65 -> IO-DATA GV-MVP/SZ
[ 17.463792] em2710/2820 #0: card=66 -> Empire dual TV
[ 17.472650] em2710/2820 #0: card=67 -> Terratec Grabby
[ 17.481692] em2710/2820 #0: card=68 -> Terratec AV350
[ 17.490572] em2710/2820 #0: card=69 -> KWorld ATSC 315U HDTV TV Box
[ 17.500702] em2710/2820 #0: card=70 -> Evga inDtube
[ 17.509612] em2710/2820 #0: card=71 -> Silvercrest Webcam 1.3mpix
[ 17.519599] em2710/2820 #0: card=72 -> Gadmei UTV330+
[ 17.528475] em2710/2820 #0: card=73 -> Reddo DVB-C USB TV Box
[ 17.538006] em2710/2820 #0: card=74 -> Actionmaster/LinXcel/Digitus VC211A
[ 17.548754] em2710/2820 #0: card=75 -> Dikom DK300
[ 17.557379] em2710/2820 #0: card=76 -> KWorld PlusTV 340U or UB435-Q (ATSC)
[ 17.570027] em2710/2820 #0: card=77 -> EM2874 Leadership ISDBT
[ 17.586580] em2710/2820 #0: card=78 -> PCTV nanoStick T2 290e
[ 17.596259] em2710/2820 #0: card=79 -> Terratec Cinergy H5
[ 17.616195] em2710/2820 #0: card=80 -> PCTV DVB-S2 Stick (460e)
[ 17.626203] em2710/2820 #0: card=81 -> Hauppauge WinTV HVR 930C
[ 17.636044] em2710/2820 #0: card=82 -> Terratec Cinergy HTC Stick
[ 17.646075] em2710/2820 #0: card=83 -> Honestech Vidbox NW03
[ 17.655486] em2710/2820 #0: card=84 -> MaxMedia UB425-TC
[ 17.664633] em2710/2820 #0: card=85 -> PCTV QuatroStick (510e)
[ 17.674215] em2710/2820 #0: card=86 -> PCTV QuatroStick nano (520e)
[ 17.684228] em2710/2820 #0: card=87 -> Terratec Cinergy HTC USB XS
[ 17.694173] em2710/2820 #0: card=88 -> C3 Tech Digital Duo HDTV/SDTV USB
[ 17.704595] em2710/2820 #0: card=89 -> Delock 61959
[ 17.713460] em2710/2820 #0: Config register raw data: 0x90
[ 17.756591] em2710/2820 #0: AC97 vendor ID = 0x83847650
[ 17.776604] em2710/2820 #0: AC97 features = 0x6a90
[ 17.786131] em2710/2820 #0: Empia 202 AC97 audio processor detected
[ 18.466493] em2710/2820 #0: v4l2 driver version 0.2.0
[ 21.407338] em2710/2820 #0: V4L2 video device registered as video0
[ 21.417194] em2710/2820 #0: analog set to isoc mode.
[ 21.426021] em28xx audio device (eb1a:2821): interface 1, class 1
[ 21.446652] em28xx audio device (eb1a:2821): interface 2, class 1
[ 21.464428] usbcore: registered new interface driver em28xx
[ 21.618465] usbcore: registered new interface driver snd-usb-audio
[ 29.096964] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 30.068130] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 36.754766] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 39.419567] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 41.023414] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 46.142683] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
