moesizlag
I2C interfacing SHT21 sensor
Thu May 31, 2012 12:40 pm
Hi everyone,
I'm trying to get a Sensirion SHT21 I2C temp/humidity sensor running with the Raspberry Pi.
I use the Debian Image with the latest firmware:
https://github.com/raspberrypi/firmware ... aster/boot
And the 3.2.18 kernel with I2C support:
http://www.bootc.net/archives/2012/05/2 ... pi-kernel/
First: Thanks to all devs for your great work -> I have a DS2482-800 which is working very nice (together with with owfs).
Unfortunately I don't get any data out of the SHT21, here's what I tried.
First try to detect the I2C devices (0x18 is the DS2482-800, 0x40 the Sensirion SHT21:
i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- 18 -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: 40 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Load sht21 driver:
modprobe sht21
Add as new I2C device:
echo sht21 0x40 > /sys/class/i2c-adapter/i2c-0/new_device
Which results in:
i2c i2c-0: new_device: Instantiated device sht21 at 0x40
sht21 0-0040: initialized
But unfortunately I don't get an error when trying to query it:
sensors
sht21-i2c-0-40
Adapter: bcm2708_i2c.0
ERROR: Can't get value of subfeature temp1_input: I/O error
temp1:        +0.0°C
So I tried to manually read the user register of the sensor, so first delete I2C device (otherwise we get a "Device or resource busy" error):
echo 0x40 > /sys/class/i2c-adapter/i2c-0/delete_device
And than:
i2cget -y 0 0x40 0xe7
Error: Read failed
So this is where I'm currently stuck :-(
Any ideas what to try / what the problem is / what I'm doing wrong?
bootc
Re: I2C interfacing SHT21 sensor
Thu May 31, 2012 4:01 pm
Do you see anything in /var/log/kernel.log or dmesg that might be of any indication? Do you have a logic analyzer or scope you can connect to the i2c pins to check what's going on?
HTH,
Chris
moesizlag
Thu May 31, 2012 6:03 pm
Unfortunately there's nothing helpful to the problem in dmesg or kern.log.
Is there a way to debug what the I2C driver sends/receives ?
I don't have a logic analyzator yet but hope to get mine in the next few weeks.
I do have a scope but I'm not sure if know how to correctly interpret the signals I see.
bootc
Thu May 31, 2012 8:19 pm
Easiest thing to do would be to build a new kernel with CONFIG_I2C_DEBUG_CORE and/or CONFIG_I2C_DEBUG_ALGO and/or CONFIG_I2C_DEBUG_BUS enabled. They should give you a much better idea about what's going on.
If you haven't yet got a logic analyser, I recommend the Open Bench Logic Analyzer from Dangerous Prototypes / Gadget Factory / Seeed Studio - I have one and it's been very useful while working on this driver (and my SPI one)!
johankj
Mon Jun 04, 2012 8:06 pm
the i2c-tools that i have only accepts integer adresses, so have you tried:
sudo i2cdump -y 0 64
moesizlag
Thu Jun 14, 2012 6:04 pm
@johankj: My i2c tools seem to work correctly with hex values, but thanks for your hint.
@Chris: Thanks for your suggestion about the logic analyzer, I finally got a mine and are getting a bit more forward now.
So here are some updates which maybe help to solve the problems with the sensor.
First about the SHT21 Linux driver (made by Urs Fleisch from Sensirion):
As far as I can see the driver uses the "hold master" measurement mode which means after sending the Trigger Temperature or Humidity to the sensor it will block the SCL line as long as the measurement takes.
This is described in the datasheet on page 8 under 5.4:
http://www.sensirion.com/fileadmin/user ... eet_V3.pdf
My first shot would be this confuses the I2C driver?
After playing around some more I finally got the sensor to send some data.
Read User Register:
i2cget -y 0 0x40 0xe7 b
In my case returns: 0x3A -> 0011 1010
Trigger Temperature measurement (with no hold master)
i2cset -y 0 0x40 0xf3
Unfortunately I found no way to read the measurements as word.
i2cget expects a "DATA-ADDRESS" when setting the "MODE".
Here's what I got with reading the data byte after byte:
0x669b6cb2c82080
soend
Tue Jan 01, 2013 6:37 pm
Hey, sorry to bring this old topic up. But im also trying to get this sensor working on raspberry. I have the sht21 module loaded but i cant find anywhere how i can us it. Do anybody know and give me some example?
gcb
Wed Jan 02, 2013 9:41 pm
take a look at http://www.emsystech.de/raspi-sht21/, (page is in german) some sourcecode is available under http://www.emsystech.de/wp-content/uplo ... V3_0_0.zip.
It works here
oliverju
Wed Feb 06, 2013 10:21 pm
I have modified the broadcom i2c-driver to provide sht21-support.
The patch can be found here:
https://github.com/raspberrypi/linux/issues/211
Greetings Oliver
Anks
Mon Mar 09, 2015 2:15 pm
Hello everyone, I have interfaced Sht21 (Temperature and Humidity sensor) with raspberry pi (B+ version). I want to do data acquisition from this sensor. For this purpose firstly, I have gone through the procedure given by link "https://github.com/jaques/sht21_python" to configure Raspberry pi according to requirement then I used the python code available on link "https://github.com/jaques/sht21_python/ ... r/sht21.py". I have also modified the code by making changes as "device_number=1" and "with SHT21(1) as sht21:", since my raspberry pi is of B+ version and code given by above link is for old version. When I tried to run the code in Geany I am getting the error like
[Error 5] Input/Output error
Error creating connection to i2c. This must be run as root.
I am unable to get rid of this error. Can any one suggest me how to fix this problem. Thanks in advance.
drfrank
Tue Mar 24, 2015 12:13 pm
Thanks for all the links, I've got my SHT21 sensor working. Note to the wise - the NOOBS image caused me no end of trouble, but Wheezy was straightforward.
To solve your problem, you need to run sht21.py from the command line like this (I placed sht21.py in a subfolder called python and ran it from there):
[email protected] ~/python $ python sht21.py
[Errno 13] Permission denied: '/dev/i2c-1'
[email protected] ~/python $ sudo python sht21.py
Temperature: 20.7502905273
Humidity: 37.083190918
Prod69
Wed Apr 29, 2015 11:22 am
I have the exact same problem as Anks.
Noobs install but with the SHT25 sensor.
As far as I can tell the 21 code should also run on the 25.
