Re: CAN controller
If everything is identical, then it should work - as long as the cabling polarity is correct and the bus is properly terminated.
As for the "poor mans logic analyzer":
[*]Connect a can transceiver to your can bus
[*]connect the rx pin via a voltage divider to a pin on the rpi
[*]run a programm that samples the specific pin at high frequency(know that frequency/sample rate)
[*]from this you can estimate the actual bit length on the bus
The other approach is to buy a logic analyzer/oscilloscope.
Re: CAN controller
I thoughts i found the the problem. I've been prototyping them on breadboard and .. after I fiddling with some wires I've found that the power wires onto breadboard (or maybe the breadboard contact) is actually a problem. So I move it to somewhere else and ... it just works
Thank you very much for your help Martin!
Re: CAN controller
No problem
BTW: you now use the latest foundation kernels with the device overlay for the mcp2515!
Re: CAN controller
Thanks Martin (let me know if you want a PiCAN board) for the latest kernel with device overlay built in.
I've done a step by step instructions of the installation at:
http://skpang.co.uk/blog/archives/1165
SK Pang
SK Pang
Re: CAN controller
Hi all,
I did recently a step-by-step post to use CAN Bus in Raspberry Pi, independently of any shield, and that works for latest Raspbian 3.18.7+.
http://tiqni.com/raspberry-pi/can-bus-s ... spberry-pi
If you need also help for electrical schematic, please let me know it.
Good luck !
Regards
Good luck !
Regards
Re: CAN controller
@Tiqni
If I see it right, your approach works only for the RPI A, or B+ but not the RPI 2.
Re: CAN controller
the approach using the foundation kernels works for RPI and RPI2.
Re: CAN controller
@bapou
As said by msperl, I don't see any reason for what Raspberry Pi 2 is not supported, since the same SPI chip is used.msperl wrote:the approach using the foundation kernels works for RPI and RPI2.
Re: CAN controller
Hello everyone!
I'm very happy I found this forum, it has already been very helpful in getting my CAN system up and running. Thank you very much!
I'm working on a project to create a CAN-Bus Datalogger. I followed the instructions on CANned Pi to get my system setup. My problem is that I cannot see any CAN messages coming off my vehicle even though everything seems to be setup properly. See screenshot below:
Link to full size image.
The vehicle I'm using is running OpenCAN but when I was using the SPKang CAN Bus Shield for the Arduino, I did not encounter any problems. Setup was easy and it was working right away.
Please let me know what I could be doing wrong. I am brand new to Linux and Raspberry Pi (just started yesterday!) but I'm very excited to get things working.
Thank you,
Julia
Thank you,
Julia
Re: CAN controller
Hi Julia,
From what I can see there is no SW problem, maybe you are not using the same Raspbian version like in the attached link.
However I can advise you to use latest modules versions : http://tiqni.com/raspberry-pi/can-bus-s ... spberry-pi
You mentioned Arduino shield, so it's probably a voltage issue, the MCP2551 uses 5V, while Raspberry Pi GPIO and MCP2515 use 3,3V.
So you need to make a voltage divider between them like described here : http://lnxpps.de/rpie/
Good luck !
Good luck !
Re: CAN controller
Hi Tiqni,
Thank you for your help. I happen to have both shields - one for the Arduino, and one for the Pi. So that should not be a problem.
I have the suggested Raspbian version from the CANned Pi article (3.12.28+) but I can retry with a newer version as you suggest.
Thank you, I will post an update when I am done!
Julia
Julia
Re: CAN controller
Thank worked, thank you very much!! This forum is great
Re: CAN controller
You're welcome :)
Re: CAN controller
Hi Rpi Community,
My PICAN worked like a charm the last few weeks.
Now i encountered a problem where after each Message send on my bus, i wasnt able to send a second message. I had to reboot my can-device :
ifconfig can0 down
ifconfig can0 up
to send the next message. I did not change any of my setup and it was working before.
Does anyone know what the problem could be ? I think it might be some kind of hardware issue, since the loopback mode worked without any problems.
I tried to solve the problem through an software update but when i updated my kernel to 3.18.7+ and loaded the CAN modules from lnxpp.de/rpie my spi-2708 module could not be loaded. everything else could (can, can-dev, can-raw...).
When i tried to modify my blacklist in the usual /etc/modprobe.d/raspi-blacklist.conf I noticed that the blacklistfile did not exist. So either i dont have blacklisted any or the file moved its place. On my SD-card with the 3.12.35+ Kernel the Blacklist.conf is in that exact spot.
So I have the following questions:
why can i only send one message? (and how can i fix that)
and where did my Blacklist go? If the above indicates, that i do not have a blacklist, why am i not able to load spi-bcm2708?
error code for:
~$ sudo modprobe spi-bcm2708
ERROR: could not insert 'spi_bcm2708':No such device
Greetings
TeeTrinker
ifconfig can0 down
ifconfig can0 up
error code for:
Greetings
TeeTrinker
Re: CAN controller
Hi TeeTrinker,
Why you can't send many messages ?
> I have sometimes the same problem, it's mainly due to SPI latency, so I had to down/up can0 to make it working again.
Another possibility is that your SW/HW changes (update, new CAN bus ?)
Where the blacklist goes ?
> The latest Raspbian version (3.18) doesn't include it. I had the same remark when I updated my Raspberry Pi.
Problems after update ?
> Please check the end of this post (http://tiqni.com/raspberry-pi/can-bus-s ... spberry-pi), one of problems is spi-2835 instead of spi-2708. Check your SPI modules like explained in the post.
Good luck !
Good luck !
Re: CAN controller
Hi Tinqui,
Thanks for the reply. The link actually did it for me. did not have spi - enabled on the 3.18.7+ Kernel. Stupid me!
But still don't know what the other problem on 3.12.35+ was. I can see messages on CAN bus through CANoe, and just the first message came through. The second message was not displayed. To send a second message i had to reboot canbus with ifconfig up/down.
But to be honest i didn't investigate it further since it is working with the 3.18.7+ Kernel.
Greetings,
Teetrinker
Greetings,
Teetrinker
Re: CAN controller
actually this "one message only" issue with 3.12.x kernel could be related to some interrupt handling bug in the mcp251x driver that could only get resolved during a restart. But this was actually (mostly) related to receiving too many packets in a short time.
The driver in the new 3.18.x kernel does not exhibit this kind of behaviour.
Re: CAN controller
I can't get this design to work for nothin' http://hackaday.io/project/346-canpi on Pi2.
Using the "new" overlay method. This is my first run at it, so I have no previous working version for refference.
Schematic:
lsmod:
dmesg:
/boot/config.txt
I tried loading all the various cad-dev/cat-raw/etc modules with no luck. Everything is the newest version available.
Thanks!
Schematic:
lsmod:
root@raspberrypi:~# lsmod
Module Size Used by
bnep 10206 2
binfmt_misc 6370 1
i2c_dev 6027 0
snd_bcm2835 18665 0
snd_pcm 73475 1 snd_bcm2835
snd_timer 17784 1 snd_pcm
snd 50998 3 snd_bcm2835,snd_timer,snd_pcm
fuse 82155 1
mcp251x 8640 0
ecb 2027 1
can_dev 9187 1 mcp251x
spi_bcm2835 3086 0
i2c_bcm2708 4990 0
btusb 19521 0
bluetooth 287204 21 bnep,btusb
uio_pdrv_genirq 2958 0
uio 8119 1 uio_pdrv_genirq
rfkill 16651 2 bluetooth
root@raspberrypi:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.9-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #768 SMP PREEMPT Sun Mar 15 19:41:56 GMT 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80809440, node_mem_map ba093000
[ 0.000000] Normal zone: 1888 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8620->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ba060000 s11456 r8192 d21312 u40960
[ 0.000000] pcpu-alloc: s11456 r8192 d21312 u40960 alloc=10*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa21041 bcm2709.serial=0xa2dd6313 smsc95xx.macaddr=B8:27:EB:DD:63:13 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 940852K/966656K available (5705K kernel code, 397K rwdata, 1740K rodata, 384K init, 763K bss, 25804K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x8074d700 (7446 kB)
[ 0.000000] .init : 0x8074e000 - 0x807ae000 ( 384 kB)
[ 0.000000] .data : 0x807ae000 - 0x8081147c ( 398 kB)
[ 0.000000] .bss : 0x8081147c - 0x808d01d4 ( 764 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000013] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000036] Switching to timer-based delay loop, resolution 52ns
[ 0.000336] Console: colour dummy device 80x30
[ 0.001805] console [tty1] enabled
[ 0.001855] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001938] pid_max: default: 32768 minimum: 301
[ 0.002340] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002402] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003666] Initializing cgroup subsys memory
[ 0.003756] Initializing cgroup subsys devices
[ 0.003812] Initializing cgroup subsys freezer
[ 0.003882] Initializing cgroup subsys net_cls
[ 0.003934] Initializing cgroup subsys blkio
[ 0.004046] CPU: Testing write buffer coherency: ok
[ 0.004161] ftrace: allocating 19576 entries in 58 pages
[ 0.052411] CPU0: update cpu_capacity 1024
[ 0.052489] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.052529] [bcm2709_smp_prepare_cpus] enter
[ 0.052685] Setting up static identity map for 0x525438 - 0x52546c
[ 0.112345] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.112659] CPU1: Booted secondary processor
[ 0.112667] [bcm2709_secondary_init] enter cpu:1
[ 0.112715] CPU1: update cpu_capacity 1024
[ 0.112724] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.132312] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.132565] CPU2: Booted secondary processor
[ 0.132571] [bcm2709_secondary_init] enter cpu:2
[ 0.132601] CPU2: update cpu_capacity 1024
[ 0.132609] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.152368] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.152611] CPU3: Booted secondary processor
[ 0.152618] [bcm2709_secondary_init] enter cpu:3
[ 0.152646] CPU3: update cpu_capacity 1024
[ 0.152654] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.152749] Brought up 4 CPUs
[ 0.152873] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.152907] CPU: All CPU(s) started in SVC mode.
[ 0.153932] devtmpfs: initialized
[ 0.179074] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.181088] pinctrl core: initialized pinctrl subsystem
[ 0.184365] NET: Registered protocol family 16
[ 0.189999] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.191180] bcm2709.uart_clock = 3000000
[ 0.194400] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.194456] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.194516] mailbox: Broadcom VideoCore Mailbox driver
[ 0.194651] bcm2708_vcio: mailbox at f300b880
[ 0.195014] bcm_power: Broadcom power driver
[ 0.195059] bcm_power_open() -> 0
[ 0.195086] bcm_power_request(0, 8)
[ 0.695766] bcm_mailbox_read -> 00000080, 0
[ 0.695800] bcm_power_request -> 0
[ 0.695965] Serial: AMBA PL011 UART driver
[ 0.696116] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.204203] console [ttyAMA0] enabled
[ 1.275606] SCSI subsystem initialized
[ 1.279627] usbcore: registered new interface driver usbfs
[ 1.285296] usbcore: registered new interface driver hub
[ 1.290769] usbcore: registered new device driver usb
[ 1.297701] Switched to clocksource arch_sys_counter
[ 1.332824] FS-Cache: Loaded
[ 1.336049] CacheFiles: Loaded
[ 1.350585] NET: Registered protocol family 2
[ 1.356233] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.363492] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.370224] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.376705] TCP: reno registered
[ 1.379994] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.385982] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.392723] NET: Registered protocol family 1
[ 1.397764] RPC: Registered named UNIX socket transport module.
[ 1.403707] RPC: Registered udp transport module.
[ 1.408452] RPC: Registered tcp transport module.
[ 1.413169] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.420623] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 1.429038] bcm2708_dma: DMA manager at f3007000
[ 1.433841] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.443698] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.450166] audit: initializing netlink subsys (disabled)
[ 1.455639] audit: type=2000 audit(1.239:1): initialized
[ 1.477166] VFS: Disk quotas dquot_6.5.2
[ 1.481532] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.491084] FS-Cache: Netfs 'nfs' registered for caching
[ 1.497433] NFS: Registering the id_resolver key type
[ 1.502640] Key type id_resolver registered
[ 1.506839] Key type id_legacy registered
[ 1.512055] msgmni has been set to 1853
[ 1.517683] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.525331] io scheduler noop registered
[ 1.529310] io scheduler deadline registered (default)
[ 1.534790] io scheduler cfq registered
[ 1.541324] BCM2708FB: allocated DMA memory fac00000
[ 1.546339] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.557449] Console: switching to colour frame buffer device 82x26
[ 1.569479] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.578786] uart-pl011 dev:f1: no DMA platform data
[ 1.585766] vc-cma: Videocore CMA driver
[ 1.591297] vc-cma: vc_cma_base = 0x00000000
[ 1.597548] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.604491] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.623258] brd: module loaded
[ 1.633807] loop: module loaded
[ 1.638725] vchiq: vchiq_init_state: slot_zero = 0xba800000, is_master = 0
[ 1.647898] Loading iSCSI transport class v2.0-870.
[ 1.655219] usbcore: registered new interface driver smsc95xx
[ 1.662587] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.870212] Core Release: 2.80a
[ 1.874831] Setting default values for core params
[ 1.881132] Finished setting default values for core params
[ 2.088604] Using Buffer DMA mode
[ 2.093387] Periodic Transfer Interrupt Enhancement - disabled
[ 2.100769] Multiprocessor Interrupt Enhancement - disabled
[ 2.107901] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.113815] Dedicated Tx FIFOs mode
[ 2.119190] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 2.132161] FIQ FSM acceleration enabled for :
[ 2.132161] Non-periodic Split Transactions
[ 2.132161] Periodic Split Transactions
[ 2.132161] High-Speed Isochronous Endpoints
[ 2.155124] dwc_otg: Microframe scheduler enabled
[ 2.155200] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x803d6a28
[ 2.162757] WARN::hcd_init_fiq:413: FIQ ASM at 0x803d6d84 length 36
[ 2.170668] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb80a000
[ 2.178285] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.184793] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.193695] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.200826] Init: Port Power? op_state=1
[ 2.206291] Init: Power Port (0)
[ 2.211326] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.219738] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.228561] usb usb1: Product: DWC OTG Controller
[ 2.234809] usb usb1: Manufacturer: Linux 3.18.9-v7+ dwc_otg_hcd
[ 2.242435] usb usb1: SerialNumber: bcm2708_usb
[ 2.249430] hub 1-0:1.0: USB hub found
[ 2.254753] hub 1-0:1.0: 1 port detected
[ 2.260662] dwc_otg: FIQ enabled
[ 2.260676] dwc_otg: NAK holdoff enabled
[ 2.260687] dwc_otg: FIQ split-transaction FSM enabled
[ 2.260725] Module dwc_common_port init
[ 2.261129] usbcore: registered new interface driver usb-storage
[ 2.268965] mousedev: PS/2 mouse device common for all mice
[ 2.276689] bcm2835-cpufreq: min=600000 max=900000
[ 2.283372] sdhci: Secure Digital Host Controller Interface driver
[ 2.291142] sdhci: Copyright(c) Pierre Ossman
[ 2.297214] DMA channels allocated for the MMC driver
[ 2.337744] Load BCM2835 MMC driver
[ 2.344577] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.355845] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.365822] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.373145] usbcore: registered new interface driver usbhid
[ 2.380392] usbhid: USB HID core driver
[ 2.387165] TCP: cubic registered
[ 2.392088] Initializing XFRM netlink socket
[ 2.398014] NET: Registered protocol family 17
[ 2.404185] Key type dns_resolver registered
[ 2.413769] Registering SWP/SWPB emulation handler
[ 2.421070] registered taskstats version 1
[ 2.426921] vc-sm: Videocore shared memory driver
[ 2.433163] [vc_sm_connected_init]: start
[ 2.439406] [vc_sm_connected_init]: end - returning 0
[ 2.447135] Waiting for root device /dev/mmcblk0p2...
[ 2.457846] Indeed it is in host mode hprt0 = 00021501
[ 2.461152] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.463284] mmc0: new high speed SDHC card at address b368
[ 2.463920] mmcblk0: mmc0:b368 14.9 GiB
[ 2.476845] mmcblk0: p1 p2
[ 2.576066] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.587372] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.596884] devtmpfs: mounted
[ 2.602171] Freeing unused kernel memory: 384K (8074e000 - 807ae000)
[ 2.667855] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.676381] Indeed it is in host mode hprt0 = 00001101
[ 2.878107] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.886661] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.896503] hub 1-1:1.0: USB hub found
[ 2.902258] hub 1-1:1.0: 5 ports detected
[ 3.187999] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.308294] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.317288] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.329524] smsc95xx v1.0.4
[ 3.391920] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:dd:63:13
[ 3.648036] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
[ 3.770424] udevd[170]: starting version 175
[ 3.802754] usb 1-1.4: New USB device found, idVendor=0a12, idProduct=0001
[ 3.812607] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 3.822949] usb 1-1.4: Product: CSR8510 A10
[ 4.427524] Bluetooth: Core ver 2.19
[ 4.450023] NET: Registered protocol family 31
[ 4.469364] Bluetooth: HCI device and connection manager initialized
[ 4.480651] Bluetooth: HCI socket layer initialized
[ 4.487893] Bluetooth: L2CAP socket layer initialized
[ 4.495151] Bluetooth: SCO socket layer initialized
[ 4.522479] usbcore: registered new interface driver btusb
[ 4.594857] bcm2708_i2c_init_pinmode(1,2)
[ 4.614046] bcm2708_i2c_init_pinmode(1,3)
[ 4.640479] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 4.751580] CAN device driver interface
[ 4.914027] random: nonblocking pool is initialized
[ 6.381399] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.843861] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.415408] fuse init (API version 7.23)
[ 7.595005] i2c /dev entries driver
[ 12.100958] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 13.561194] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 14.816291] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2134012k SSFS
[ 15.527292] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.527344] Bluetooth: BNEP filters: protocol multicast
[ 15.527412] Bluetooth: BNEP socket layer initialized
dtparam=spi=on
dtoverlay=mcp2515-can0-overlay,oscillator=16000000,interrupt=25
dtoverlay=spi-bcm2835-overlay
root@raspberrypi:~# uname -a
Linux raspberrypi 3.18.9-v7+ #768 SMP PREEMPT Sun Mar 15 19:41:56 GMT 2015 armv7l GNU/Linux
root@raspberrypi:~# /sbin/ip link set can0 up type can bitrate 500000
Cannot find device "can0"
Thanks!
Re: CAN controller
Please also add the following to /boot/config.txt:
then reboot.
Please run:
as well as:
and share the output?
Thanks, Martin
dtdebug=on
Please run:
head /sys/bus/spi/devices/spi*/modalias
sudo vcdbg log msg
Thanks, Martin
Re: CAN controller
root@raspberrypi:~# head /sys/bus/spi/devices/spi*/modalias
==> /sys/bus/spi/devices/spi0.0/modalias <==
spi:mcp2515
==> /sys/bus/spi/devices/spi0.1/modalias <==
spi:spidev
root@raspberrypi:~# vcdbg log msg
000695.394: HDMI:EDID error reading EDID block 0 attempt 0
000696.657: HDMI:EDID error reading EDID block 0 attempt 1
000697.916: HDMI:EDID error reading EDID block 0 attempt 2
000699.174: HDMI:EDID error reading EDID block 0 attempt 3
000700.434: HDMI:EDID error reading EDID block 0 attempt 4
000701.692: HDMI:EDID error reading EDID block 0 attempt 5
000702.952: HDMI:EDID error reading EDID block 0 attempt 6
000704.211: HDMI:EDID error reading EDID block 0 attempt 7
000705.470: HDMI:EDID error reading EDID block 0 attempt 8
000706.729: HDMI:EDID error reading EDID block 0 attempt 9
000707.751: HDMI:EDID giving up on reading EDID block 0
000710.482: HDMI:Setting property pixel encoding to Default
000710.504: HDMI:Setting property pixel clock type to PAL
000710.522: HDMI:Setting property content type flag to No data
000710.544: HDMI:Setting property fuzzy format match to enabled
000715.996: gpioman: gpioman_get_pin_num: pin LEDS_RUNNING not defined
000716.019: gpioman: gpioman_get_pin_num: pin LEDS_NAND_ACTIVITY not defined
000716.040: gpioman: gpioman_get_pin_num: pin LEDS_USB_ACTIVITY not defined
000716.061: gpioman: gpioman_get_pin_num: pin LEDS_FATAL_ERROR not defined
000716.082: gpioman: gpioman_get_pin_num: pin LEDS_APP_OK not defined
000716.104: gpioman: gpioman_get_pin_num: pin LEDS_APP_FAILED not defined
000716.123: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_AUTH not defined
000716.145: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_UNAUTH not defined
000716.167: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_ON not defined
000716.188: gpioman: gpioman_get_pin_num: pin LEDS_DVI_ON not defined
000716.210: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_HPD_UP not defined
000716.231: gpioman: gpioman_get_pin_num: pin LEDS_REMOTE_CONTROL not defined
000716.251: gpioman: gpioman_get_pin_num: pin LEDS_ARM_CONTROLLED not defined
000734.293: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
000734.319: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
000734.715: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
000735.984: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
000737.248: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
000738.512: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
000739.776: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
000741.040: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
000742.304: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
000743.568: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
000744.832: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
000746.096: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
000747.123: hdmi: HDMI:EDID giving up on reading EDID block 0
000747.152: hdmi: HDMI: No lookup table for resolution group 0
000747.169: hdmi: HDMI: hotplug attached with DVI support
000747.230: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
000747.599: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
000748.860: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
000750.123: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
000751.385: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
000752.647: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
000753.909: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
000755.171: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
000756.433: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
000757.695: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
000758.957: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
000759.982: hdmi: HDMI:EDID giving up on reading EDID block 0
000760.042: hdmi: HDMI: hotplug deassert
000760.057: hdmi: HDMI: HDMI is currently off
000760.072: hdmi: HDMI: changing mode to unplugged
000760.095: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
000760.888: *** Restart logging
000761.848: Read command line from file 'cmdline.txt'
000766.766: Loading 'kernel7.img' from SD card
000997.898: Kernel trailer DTOK property says yes
000998.026: Loading 'bcm2709-rpi-2-b.dtb' from SD card
001024.451: dtparam: spi=on
001027.206: dtparam: i2c_arm=on
001041.678: Loaded overlay 'mcp2515-can0-overlay'
001070.813: dtparam: oscillator=16000000
001073.986: dtparam: interrupt=25
001085.215: Loaded overlay 'spi-bcm2835-overlay'
001093.476: dtparam: arm_freq=900000000
001151.256: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
003250.128: vchiq_core: vchiq_init_state: slot_zero = 0xfa800000, is_master = 1
003253.589: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
003257.264: gpioman: gpioman_get_pin_num: pin LEDS_RUNNING not defined
003257.290: gpioman: gpioman_get_pin_num: pin LEDS_NAND_ACTIVITY not defined
003257.313: gpioman: gpioman_get_pin_num: pin LEDS_USB_ACTIVITY not defined
003257.335: gpioman: gpioman_get_pin_num: pin LEDS_FATAL_ERROR not defined
003257.355: gpioman: gpioman_get_pin_num: pin LEDS_APP_OK not defined
003257.375: gpioman: gpioman_get_pin_num: pin LEDS_APP_FAILED not defined
003257.398: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_AUTH not defined
003257.418: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_UNAUTH not defined
003257.440: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_ON not defined
003257.460: gpioman: gpioman_get_pin_num: pin LEDS_DVI_ON not defined
003257.480: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_HPD_UP not defined
003257.503: gpioman: gpioman_get_pin_num: pin LEDS_REMOTE_CONTROL not defined
003257.526: gpioman: gpioman_get_pin_num: pin LEDS_ARM_CONTROLLED not defined
Re: CAN controller
Device tree looks fine.
Are you sure the cabling is done correctly as per your diagram?
That seems to be the only thing left open.
The only other thing I can think of is to run the following shell script (which runs spi bitbang inside a shell script):
The output should look like this:
Can you check that?
Any difference would indicate an issue with the wireing, but that is impossible to debug from afar...
#! /bin/sh
CS=8
test -z "$1" || CS=$1
SCLK=11
MOSI=10
MISO=9
#config SPI Pins and Directions
CONFIG_PINS() {
(while read gpio dir level; do
test -f /sys/class/gpio/gpio$gpio/value || echo $gpio > /sys/class/gpio/export
echo $dir > /sys/class/gpio/gpio$gpio/direction
test -z "$level" || echo $level > /sys/class/gpio/gpio$gpio/value
done) <<EOF
$CS out 1
$MISO in
$MOSI out 0
$SCLK out 0
EOF
UNCONFIG_PINS() {
test -f /sys/class/gpio/gpio$gpio/value || echo $gpio > /sys/class/gpio/unexport
done) <<EOF
$CS
$MISO
$MOSI
$SCLK
EOF
CS() {
echo "$1" > /sys/class/gpio/gpio$CS/value
MOSI() {
echo "$1" > /sys/class/gpio/gpio$MOSI/value
SCLK() {
echo "$1" > /sys/class/gpio/gpio$SCLK/value
spi_send() {
echo "$1" \
| awk '{X=$1;for(i=128;i>=1;i/=2){B=0;if (X>=i){ B=1;X-=i;}print i,B}}' \
| while read bit v; do
MOSI $v
SCLK 1
echo -n "$bit "
cat /sys/class/gpio/gpio$MISO/value
SCLK 0
done \
| awk 'BEGIN{C=0}{if ($2){C+=$1}}END{printf "%-20s %3i 0x%02x\n","'$2'",C,C;}'
CONFIG_PINS
# reset mcp2515
echo "Resetting MCP2515"
CS 0
spi_send 192 RESET
CS 1
# wait some time
sleep 1
# and read the registers
echo "Read MCP2515 registers"
CS 0
spi_send 3 CMD-READ
spi_send 40 REG-CNF3
spi_send 0 CNF3
spi_send 0 CNF2
spi_send 0 CNF1
spi_send 0 INTE
spi_send 0 INTF
spi_send 0 EFLG
spi_send 0 CANSTAT
spi_send 0 CANCTRL
CS 1
UNCONFIG_PINS
Resetting MCP2515
RESET 0 0x00
CMD-READ 0 0x00
REG-CNF3 0 0x00
CNF3 0 0x00
CNF2 0 0x00
CNF1 0 0x00
INTE 0 0x00
INTF 0 0x00
EFLG 0 0x00
CANSTAT 128 0x80
CANCTRL 135 0x87
Re: CAN controller
Yeah. I get:
Last 2 are different.
Maybe it is the HW. I have parts on order to build another one. We'll see. If I still can't get it to go, I'll get an off-the shelf product.
Resetting MCP2515
RESET 0 0x00
CMD-READ 0 0x00
REG-CNF3 0 0x00
CNF3 0 0x00
CNF2 0 0x00
CNF1 0 0x00
INTE 0 0x00
INTF 0 0x00
EFLG 0 0x00
CANSTAT 0 0x00
CANCTRL 0 0x00
Re: CAN controller
Just check with an mcp2515 on a breadboard - Just connect miso/mosi/sck/cs0/gnd/3v3 to the mcp2515 and the script should work and show the values above.
But beware: you may also need a working clock/resonator to get spi on the mcp2515 working in the first place - can not remember if I have ever tried without...
Re: CAN controller
I checked continuity of all the needed mcp2515 pins, and they all go to the right GPIO pins. Unfortunately I don't have an oscilloscope to do any real testing.
Maybe I fried the IC . I just looked @ the MCP data-sheet for the max soldering temps, and I may (read: definitely) have gone too hot with the iron.
Thanks for your help!
Re: CAN controller
For completeness:
Connect gpio7 (cs1) with gpio9 (miso) directly(maybe with a 1k resistor) without anything else connected to the pi.
Then run the script above again, but give an argument of "7" to the script to use the second chip-select.
If it returns 255/0xff for all then the portion on the pi is fine.
Subsequently you could also check the same, but with your board connected as well - if you read anything else, then you got some sort of short on the miso line.
