kodak
Driver usb-rs232
Sun Jan 05, 2014 6:36 pm
hei i have an "waytech usb-rs232 interface (v1.0) driver" cable,
and i need some driver thats Works with raspberry pi,
and an guide to install,
and maby a guide to tjek if it Works.
hope some on can help me.
hampi
Re: Driver usb-rs232
Sun Jan 05, 2014 7:06 pm
Normally you type
sudo tail -f /var/log/messages
and plug in the USB to serial converter to see what happens. The kernel modules for each USB-to-serial chip are usually in
/lib/modules/<kernel-version>/kernel/driver/usb/serial.
kodak
Sun Jan 05, 2014 7:16 pm
When i try to install it on Windows 7
then the Plug n Play install it as:
"HID-Gameunit" and "USB-Inputunit" at the same time.
Sun Jan 05, 2014 8:41 pm
When it's in your Windows machine can you take a look at the device manager. From there you should be able to get the vendor id and product id. Those can help find what chipset the device is using.
plug it in to your RPi
dmesg
dmesg | grep usb # to just show the USB messages
lsusb
Those commands should show whether the Linux kernel recognised it and whether it has a driver that works for it.
