Page 1 of 3
One wire w1-gpio and w1-gpio-custom
Posted: Thu Jan 02, 2014 10:23 pm
by JohnBeardmore
Help please ! Any pointers with any of this would be very welcome !
I'd like to interface a Pi to a lot of one wire devices, mostly to measure temperature (DS18B20), but maybe also to measure humidity.
To focus at the moment on the DS18B20, this seems to use kernel modules w1-gpio and w1-therm, of which I assume w1-gpio configures the gpio pin, and w1-therm makes the data available through /sys/bus/w1/devices/... Am I getting this right ?
I can't find any documentation which says how these two modules relate to each other.
It seems unlikely that I'll be able to get away with daisy-chaining through as many sensors as I need, as the route round the temperatures to be sensed will branch, so won't make a good transmission line.
This means I want to set up multiple one wire buses, possibly on all the GPIOs.
I've read that the w1-gpio that's mentioned on
http://www.cl.cam.ac.uk/projects/raspbe ... mperature/ is hard coded to GPIO4, but that the source of the w1-gpio module might be edited to change the GPIO pin that's used. Other pages suggest that there is a module w1-gpio-custom where the GPIO pin can be passed as a parameter.
http://www.rpural.net/thermometer for example, suggests that this might be configurable in /etc/modules by adding a line of the form "w1-gpio-custom bus0=0,4,0". I assume this is what they mean by passing a parameter ?
Does anybody know how to get the source for w1-gpio ? Is this something I can do in Raspbian with apt-get ? Similarly, where can I get w1-gpio-custom for Raspbian ?
If I want to set up multiple one wire buses on different GPIO pins, do I need to load multiple instances of w1-gpio for different GPIO pins, or put multiple "w1-gpio-custom bus0=0,3,0", "w1-gpio-custom bus0=0,4,0", "w1-gpio-custom bus0=0,5,0" etc lines into /etc/modules ?
If so, will I also need to load multiple instances of w1-therm ?
Thanks, J/.
Re: One wire w1-gpio and w1-gpio-custom
Posted: Tue Feb 25, 2014 4:06 am
by tdack
After spending too much time with Google and randomly browsing kernel code it looks like you can change the gpio pin.
But. It can only be done at boot time with a
/boot/cmdline.txt entry.
Reading
https://github.com/raspberrypi/linux/pull/457 it looks like if you add the following to
/boot/cmdline.txt:
Then your RPi will use GPIO-8 for 1-wire communication.
At this stage it doesn't look like there is any way to use more than one GPIO pin for 1-wire devices.
Posted: Tue Feb 25, 2014 5:28 pm
by JohnBeardmore
These were the conclusions I reached when I contacted people who had written these bits of the kernel.
The view seems widely held that the Pi has 'quite good' one wire support, but when you try to use a lot of it in anger, it isn't that great.
I know there alternative ways to do it, like bridging from the SPI bus, but as soon as you start to add extra hardware, I suspect t will become a lot harder to engage people who have only a casual interest in an open source project.
It looks as if the idea of using just the Pi and a lot of one wire sensors will have to lapse for now.
Many thanks, J/.
Posted: Sat Mar 01, 2014 7:56 pm
by fishfinger
Dear John....
I am running 4 different 1wire buses on a single pi via different GPIO pins with no
extra hardware. The big secret is a custom kernel, a few small changes in one of
the linux kernel source files to add the extra 1wire bus resources and it just works.
My version of the file linux/arch/arm/mach-bcm2708/bcm2708.c
contains a bit that looks like this (sorry can't do a diff but its based on kernel 3.6.11+ ):
#if defined(CONFIG_W1_MASTER_GPIO) || defined(CONFIG_W1_MASTER_GPIO_MODULE)
static struct w1_gpio_platform_data w1_gpio_pdata = {
.pin = W1_GPIO,
.is_open_drain = 0,
static struct platform_device w1_device = {
.name = "w1-gpio",
.id = 0,
.dev.platform_data = &w1_gpio_pdata,
static struct w1_gpio_platform_data w1_gpio_pdata1 = {
.pin = 22,
.is_open_drain = 0,
static struct platform_device w1_device1 = {
.name = "w1-gpio",
.id = 1,
.dev.platform_data = &w1_gpio_pdata1,
static struct w1_gpio_platform_data w1_gpio_pdata2 = {
.pin = 23,
.is_open_drain = 0,
static struct platform_device w1_device2 = {
.name = "w1-gpio",
.id = 2,
.dev.platform_data = &w1_gpio_pdata2,
static struct w1_gpio_platform_data w1_gpio_pdata3 = {
.pin = 24,
.is_open_drain = 0,
static struct platform_device w1_device3 = {
.name = "w1-gpio",
.id = 3,
.dev.platform_data = &w1_gpio_pdata3,
#endif
This change adds 3 more 1wire buses at GPIO pins 22/23/24, no need to change anything else. It works
fairly well.
pi@rasptemp /sys/bus/w1/devices $ ls
10-0008028a785f 28-00000452ee23 28-000004851799 28-00000485d5cb
10-0008028a8cf9 28-00000452efef 28-000004853efd w1_bus_master1
28-00000451f186 28-0000045310b4 28-000004854766 w1_bus_master2
28-00000452c2c7 28-00000484d5bb 28-000004854853 w1_bus_master3
28-00000452c778 28-00000484f06f 28-00000485637a w1_bus_master4
28-00000452d63f 28-00000484f396 28-00000485d487
Posted: Wed Apr 09, 2014 9:46 pm
by ltpitt
I'd want this so bad...
I love linux but never compiled a kernel...
Are there any detailed info about how to use two w1-gpio at the same time?
I read your snippets but look quite arab to me
Posted: Wed Apr 09, 2014 10:02 pm
by JohnBeardmore
I think the last post is really promising, but my sad life has been too busy to try it over the last few weeks. This is still something I really want to get working though.
I have tried building kernels before, but it's a frustrating business as there's no one right way to do it, every expert has their own take, preferred source and configuration, and there isn't necessarily a definitive latest version to use as a starting point.
I suggest you start by building a kernel with no changes first, but don't test it until you've backed up your SD card !
Once you've got a working kernel build process, try the suggestions in the previous messages to get multiple one wire buses.
A sensible starting point might be ask fishfinger which kernel source they built their kernel from, though it may be that you don't need anything esoteric.
Please keep asking for help and let us know how you get on. If I get a chance I'll try and get another look at it in a few weeks.
Cheers, J/.
Posted: Thu Apr 10, 2014 12:20 pm
by ltpitt
Hi there and thanks for sharing!
I've read better and it looks like on newer firmware versions this is possible at boot time modifying /boot/cmdline.txt
I did a successful rpi-update and then added at the beginning of my /booy/cmdline.txt :
bcm2708.w1_gpio_pin=18
The only effect was to let my ds18 to totally stop working
Posted: Thu Apr 10, 2014 12:40 pm
by ltpitt
I only had to check my connection...
Everything works perfectly
All informations found here did the job:
http://www.raspberrypi.org/forums/viewt ... 59#p518859
Posted: Thu Apr 10, 2014 3:29 pm
by JohnBeardmore
But is this letting you use multiple one wire buses (handy, but not that useful), or is it letting you use multiple 1WBs ? I'm after multiple.
Cheers, J/.
Posted: Thu Apr 10, 2014 8:11 pm
by logg
hi gui,
i've a proble with my gpio 4 (time ago i damage it) now i want to connect i ds18b20 to my raspy i try to change 1-wire pin
editing /booy/cmdline.txt file but don't work,
someone can help me..some editing kernel or something.
tnksin addvance
Posted: Fri Apr 11, 2014 8:28 am
by dpenezic
JohnBeardmore wrote:But is this letting you use multiple one wire buses (handy, but not that useful), or is it letting you use multiple 1WBs ? I'm after multiple.
Cheers, J/.
I am little bit out of kernel development , but in particular case you have option tu select different pin for 1 1-wire bus (multiple options i have in mind when i start changing kernel, but i didnt finish that solution).
Of course you may have multiple 1-wire devices on same 1-wire bus.
Regards,
Dubravko Penezic
Posted: Fri Apr 11, 2014 8:29 am
by dpenezic
logg wrote:hi gui,
tnksin addvance
may you provide your connection schematic, or connection picture ?
REgards,
Dubravko Penezic
Posted: Fri Apr 11, 2014 2:09 pm
by logg
hi,
my schematic is pi ds18b20 pin 1 to ground, pin 2 to gpio 4 ,pin 3 to 3,3 volt and resistence of 4,7k betwen pin 2 and 3.
i'm shure that is connect right becouse before it work.i try also to use like output but do not work.
can you help me to change 1 wire pin?
tnks in addvance
Posted: Fri Apr 11, 2014 7:28 pm
by dpenezic
logg wrote:hi,
tnks in addvance
please send picture of that connection, theoretically it is O.K. ... in most case people have some non obvious mistake.
For changing pin follow instruction on
http://www.raspberrypi.org/forums/viewt ... 59#p518859 .
Regards,
Dubravko Penezic
Posted: Sun Apr 13, 2014 12:30 pm
by logg
hi,
i follow instruction on post, but nothing .i start raspbian by berryboot (maybe isn't problem) i edit also cmdline.txt in berryboot configuration. in w1 folder there ins't any device (only master), when i boot webiopi i see than w1 devices are alway in pin 4.
this what i do:
sudo su -
nano /boot/cmdline.txt
add this line:
bcm2708.w1_gpio_pin=07
reboot
modprobe w1-gpio
modprobe w1-therm
right?
tnks in addvance
Posted: Sun Apr 13, 2014 2:57 pm
by dpenezic
logg wrote:hi,
this what i do:
sudo su -
add this line:
reboot
modprobe w1-gpio
modprobe w1-therm
right?
tnks in addvance
pin 07 doesnt exist , if you mean GPIO7 , then you need to write bcm2708.w1_gpio_pin=7, and please be aware that value have BCM label of pin not pin position on JP5 header.
Regards,
Dubravko Penezic
Posted: Sun Apr 13, 2014 7:17 pm
by logg
hi,
really nothing to do! strange things is than when i run it say me than gpio 4 there is 1-wire device,like if i don't change w1 pin.
may be is a configuration problem.Wath you can suggest me ?
many tanks
Posted: Mon Apr 14, 2014 10:57 am
by logg
solved!
i install last version of raspbian and now working.
Posted: Wed Jun 11, 2014 7:37 pm
by Holyhead
Thanks @fishfinger!
I've used your code stub to compile a patched 3.12.21 kernel implementing four 1-w busmasters.
For those interested, I've uploaded the patch file here
http://holyhead.de/RaspberryPi/bcm2708- ... .12.21.txt.
Posted: Sat Jun 21, 2014 12:40 am
by JohnBeardmore
Thanks for this, but I've still got problems. Hopefully simple to solve.
A while back I downloaded kernel source, raspberrypi-linux-8fa2e19 which as far as I could see was the latest version.
This source has file called bcm2708.c but it doesn't contain the strings "W1_GPIO" or "one-wire". I assume then, that I've probably downloaded the wrong source.
Which source are you working from, and are there any good instructions for building the kernel and installing it ?
Thanks, J/.
Posted: Sat Jun 21, 2014 12:42 am
by JohnBeardmore
Next question -
If the Pi is only to be used to talk to one wire temperature sensors, are there any GPIO pins which shouldn't be used as one-wire buses ?
Many thanks, J/.
Posted: Sat Jun 21, 2014 1:02 am
by FLYFISH TECHNOLOGIES
JohnBeardmore wrote:If the Pi is only to be used to talk to one wire temperature sensors, are there any GPIO pins which shouldn't be used as one-wire buses ?
No.
Just keep in mind on-board 1k8 pull-up resistors on I2C bus signals.
Best wishes, Ivan Zilic.
Posted: Sat Jun 21, 2014 7:46 pm
by JohnBeardmore
The usual pull-up is 4k7 if I remember correctly. How critical is it ? I think I've used 3k9 in the past when I couldn't find 4k7s. That seemed OK, at least with a lead length of a couple of meters.
Would I get away with 1k8 ?
Cheers, J/.
Posted: Thu Nov 27, 2014 5:25 pm
by impluse
fishfinger wrote:Dear John....
.pin = W1_GPIO,
.is_open_drain = 0,
.name = "w1-gpio",
.id = 0,
.pin = 22,
.is_open_drain = 0,
.name = "w1-gpio",
.id = 1,
.pin = 23,
.is_open_drain = 0,
.name = "w1-gpio",
.id = 2,
.pin = 24,
.is_open_drain = 0,
.name = "w1-gpio",
.id = 3,
#endif
fairly well.
Dear fishfinger....
Can you explain step by step how can i have more than one pin for 1-wire bus on single pi
I really need to have more than one pin for 1-wire because I want to use many
(more than 10) DS18B20 on Single pi
Posted: Sat Nov 29, 2014 6:32 am
by impluse
hi...
