nroff-man
Introducing the Bus Parrot Bus Pirate :-)
Sat Dec 28, 2013 3:53 pm
Hi
Using the application introduced some time ago in this thread
http://www.raspberrypi.org/phpBB3/viewt ... 45&t=22370
I am demonstrating how we may create a Bus Pirate clone on breadboard
directly connected to the R-PI.
There are plenty of applications for the Bus Pirate demonstrated on the
dangerousprototypes web site and here I only explore one. Take a look
there to get an overview of the what a Bus Pirate can do.
This demo hasn't really been completed because I don't have the components
available to do so, nor has exploring whether building it on a `humble pi'
for example, would be useful exercise. You may complete this project at
your leisure.
I now need to dismantle my breadboard `Bus Parrot' but I will return to it
in future once I have new components for new options available so in the
meantime, it's over to you...
Bus Parrot Bus Pirate Setup
The Circuit
http://dev.kewl.org/k8048/Src/asm/PIC24 ... parrot.png
This layout is a work-in-progress and is almost functionally
the same as the original the difference being the the power section.
This can be solved later but adequate parts are not available for
testing at this time.
All parts should be available from CPC in the UK including the PICMicro.
k8048 config
~/.k8048:
DEVICE=RPI
SLEEP=1
BITRULES=0x1700
VPP=9
PGM=255
PGC=10
PGD=11
These are the configuration options for the k8048 application which
is used to program the PICMicro.
See http://k8048.kewl.org/ to discover how to install and
use this application.
Detect the PIC24FJ64GA002
> k24 lvp id
[000000] [PROGRAM] 5600 WORDS
[00ABFC] [CONFIG2] F9DF
[00ABFE] [CONFIG1] 3F7F
[8007F0] [APPID] D3
[8007F4] [CALIB1] E97B34
[8007F6] [CALIB2] 0F0081
[8007F8] [CALIB3] FF006F
[8007FA] [CALIB4] FF0001
[8007FC] [CALIB5] FFFF21
[8007FE] [CALIB6] FFF97D
[FF0000] [DEVID] 0447 FAM:11 DEV:07 PIC24FJ64GA002
[FF0002] [DEVREV] 3046 MAJOR:1 DOT:6
Time: 0:00.07s
Program the PIC24FJ64GA002
> k24 lvp program BPv3-Firmware_v6.3-beta1_r2151__Bootloader_v4.4.hex
Total: 18436
Time: 0:03.97s
Verify the PIC24FJ64GA002
> k24 lvp verify BPv3-Firmware_v6.3-beta1_r2151__Bootloader_v4.4.hex
Total: 18436 Pass: 18436 Fail: 0
Time: 0:04.58s
Install and setup kermit
> sudo apt-get install kermit
~/.kermrc:
set modem type none
set line /dev/ttyAMA0
set carrier-watch off
set speed 115200
set flow none
connect
Test the Bus Parrot Bus Pirate
> kermit
RE
Bus Pirate v3.a
Firmware v6.3-beta1 r2151 Bootloader v4.4
DEVID:0x0447 REVID:0x3046 (24FJ64GA002 B8)
http://dangerousprototypes.com
HiZ>
<CTRL>\Q
<CTRL>\ is the CONTROL key pressed and then backslash entered without releasing control.
Enter this and afterward enter upper case Q. This will quit kermit and return to the UNIX
shell.
Bus Parrot Bus Pirate Demo
http://dangerousprototypes.com/docs/Bus_Pirate
I2C EEPROM
http://dev.kewl.org/k8048/Images/busparrot.jpg
http://dangerousprototypes.com/docs/3EE ... I2C_EEPROM
> kermit
RE
Bus Pirate v3.a
HiZ>m
1. HiZ
2. 1-WIRE
3. UART
4. I2C
5. SPI
6. 2WIRE
7. 3WIRE
8. LCD
x. exit(without change)
(1)>4
Set speed:
1. ~5KHz
2. ~50KHz
3. ~100KHz
4. ~400KHz
(1)>
Clutch disengaged!!!
To finish setup, start up the power supplies with command 'W'
Ready
I2C>P
Pull-up resistors ON
I2C>W
POWER SUPPLIES ON
Clutch engaged!!!
I2C>(0)
0.Macro menu
1.7bit address search
2.I2C sniffer
I2C>(1)
Searching I2C address space. Found devices at:
0xA0(0x50 W) 0xA1(0x50 R)
I2C>[0b10100000 0 0 3 2 1]
I2C START BIT
WRITE: 0xA0 ACK
WRITE: 0x00 ACK
WRITE: 0x00 ACK
WRITE: 0x03 ACK
WRITE: 0x02 ACK
WRITE: 0x01 ACK
I2C STOP BIT
I2C>[0b10100000 0 0]
I2C START BIT
WRITE: 0xA0 ACK
WRITE: 0x00 ACK
WRITE: 0x00 ACK
I2C STOP BIT
I2C>[0b10100001 r:3]
I2C START BIT
WRITE: 0xA1 ACK
READ: 0x03 ACK 0x02 ACK 0x01
NACK
I2C STOP BIT
I2C>
<CTRL>\Q
If you have any questions I will attempt to answer them.
Good luck.
