petert1
DAC for 0 - 10v output
Sun Dec 22, 2013 10:55 pm
Anybody have Pi experience with a DAC which can output 0 to 10V .?
Input from either I2C or SPI.
Python preferred
Any suggestions appreciated. Tutorials very welcome!
Richard-TX
Re: DAC for 0 - 10v output
Mon Dec 23, 2013 2:43 pm
I can find no DACs with a V_out like you specified. Having said that, there is a way to achieve what you want. See the application note at http://www.maximintegrated.com/app-note ... mvp/id/429
So for a complete solution you will need 2 DACs. One to control the gain of the amplifier and the other to do the D-A conversion.
It really is a nice solution as the PGA can be trimmed to some very good accuracy.
Richard
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
Richard-TX
Mon Dec 23, 2013 2:52 pm
If you are starting out with data conversion, I would look at the DAC/ADC boards being sold on Ebay. For less than $2 delivered, the 4 channel adc with single channel DAC is a great learning tool. It uses the PCF8591 chip. There is tons of example code out there for it.
http://www.ebay.com/itm/190888152989
Richard
mahjongg
Mon Dec 23, 2013 3:42 pm
DAC with 0..5V output plus 2x gain Opamp
use a 12V powered rail-to rail and single power supply capable opamp.
petert1
Mon Dec 23, 2013 7:13 pm
Thanks to all. Those are good suggestions- I think I'll try them all.. Will let you know results.
:D
Richard-TX
Tue Dec 24, 2013 1:52 am
mahjongg wrote:DAC with 0..5V output plus 2x gain Opamp
That is exactly what that application note defines except that the gain of the opamp is programmable.
Richard
mahjongg
Tue Dec 24, 2013 1:59 am
the gain can obviously be set by choosing the feedback resistors, but a times 2 gain transfers a 5V max output to a 10V max output, like you wanted.
if you use this circuit for the opamp:
it will have a gain of 2 if both R1 and R2 are the same (10K typically).
Bruce_Pi
Mon Apr 30, 2018 4:55 pm
@natopal46 the i2c chip you mentioned is digital IO expander NOT a DAC. To get a analog output you will need to use a DAC not io. there aren't many DAC chips which outputs 0-10V, most of these outputs 0-5V. You will need build a amplifier with gain set to two.
If you are not sure how to build or dont have tools i will recommend getting a breakout board which already has all this on board.
something like this 0-10V i2C DAC https://store.ncd.io/product/1-channel- ... -i%C2%B2c/
Cheers!!!
Aptinex
Fri Sep 28, 2018 4:06 pm
You can use Aptinex DAC Module DA1C010BI I2C Digital to Analog 0-10V which is base on MCP4725 dac.
https://aptinex.com/product/aptinex-dac ... p4725-i2c/
Aptinex (Pvt) LTD.
No 167 1/1, Galle road,
Dehiwala,
Sri Lanka
info@aptinex.com
+94 11 2735220
