msperl
registration of SPI-devices without recompiling the kernel
Wed Oct 02, 2013 4:12 pm
Hi!
I have just published an initial version of a new kernel module "spi-config" that allows you to configure devices of your choice on the SPI bus.
For example - configuring the CAN Bus for PYCAN could look like this (assuming Raspien would provide an updated kernel with the module compiled in):
modprobe spi-config devices=bus=0:cs=0:modalias=mcp2515:speed=10000000:gpioirq=25:pd=140024f4000220
This would configure a mcp2515 on SPI0.0 with a max SPI-bus speed of 10MHz and the interrupt on GPIO25. It also configures the MCP2515 to have a clock of 16MHz.
You can change mcp2515 for any other module of your choice.
modprobe spi-config devices=bus=0:cs=1:modalias=spidev:speed=4000000
and you add on spi0.1 SPIDEV at a max speed of 4MBit.
or
modprobe spi-config devices=bus=0:cs=0:modalias=mcp2515:speed=10000000:gpioirq=25:pd=140024f4000220,bus=0:cs=1:modalias=enc28j60:speed=16000000:gpioirq=22
to get the Ethernet controller on SPI0.1 to work with GPIO22 as interrupt plus on SPI0.0 you get the CAN controller...
For the code please see: https://github.com/msperl/spi-config
Hopefully this gets integrated with the Raspian linux kernel (posted an issue here: https://github.com/raspberrypi/linux/issues/391 to get it started). Then most of our lives may be easier without the need to compile our personal SPI-kernels...
Please review it and if it helps your work, then please ask nicely to get it included in the Raspian kernel - the more people ask for it the quicker we will get a solution...
Thanks,
Martin
msperl
Re: registration of SPI-devices without recompiling the kern
Sun Oct 06, 2013 4:05 pm
Should now also compile for 3.6.y kernels - also tested with 3.6.11+
Please give it some testing and feedback!
sam nazarko
Sun Oct 06, 2013 6:48 pm
@msperl: are you having success with SPI on 3.10.x? I am not: please see http://www.raspberrypi.org/phpBB3/viewt ... 44&t=57516
msperl
Wed Oct 09, 2013 7:54 pm
Found a bug with spi-config, that can result in a crash when unloading the module, if the spi-bcm2708 driver has been removed first...
The new version on GitHub fixes this issue and tries to be more diligent avoiding such a situation - it will only remove a device it has assigned and only if it has not been changed since...
So beware...
Martin
msperl
Wed Oct 09, 2013 7:55 pm
I have no issues either with 3.10 or 3.11.
My typical cases work as usual...
