drappleton
Infrared and irexec
Thu Sep 26, 2013 2:58 am
I've downloads LIRC and setup my remote. I do not have the file (irexec)needed to convert IR codes into "file calls".
I am running Raspbian. The directory etc/lirc/ does not have this file (irexec). Did I download it incorrectly?
Many thanks
ghans
Re: Infrared and irexec
Thu Sep 26, 2013 8:35 am
What happens if you type irexec at the command-line ?
irexec is a executable program AFAIK.
ghans
mba
Thu Sep 26, 2013 7:23 pm
irexec is part of the LIRC package. Did you install it by calling:
sudo apt-get install lirc
Using irexec you need to create an .lircrc file and place it in your home folder like ~/.lircrc. Or you can create a lircrc and put it in /etc/lirc/
You should take a look at the fileformat of lircrc here http://www.lirc.org/html/configure.html
Br.
Martin
AMOTE - a LIRC client for Android. Build your own Android-based universal remote.
FTrevorGowen
Thu Sep 26, 2013 8:12 pm
FWIW, Notes on my, somewhat brief, foray into "IR Remote Control" can be found at: http://www.cpmspectrepi.webspace.virgin ... board.html
They include links to the "setup guide" I followed/adapted and some example lircd????.conf files I was able to generate.
Trev.
drappleton
Thu Sep 26, 2013 11:26 pm
ghans wrote:What happens if you type irexec at the command-line ?
ghans
Interesting that it does know the directory where the file should be located (when I try to run the *.exe)
pi@raspberrypi ~ $ sudo irexec
irexec: could not open config files /root/.lircrc and /etc/lirc/lirc/lircrc
irexec: No such file or directory
drappleton
Fri Sep 27, 2013 1:35 am
mba wrote:Hi,
Br.
Martin
I did do this and when I do it again, it states that LIRC is already newest version:
Reading package lists... Done
Building dependency tree
lirc is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 23 not upgraded.
Maybe I should uninstall then re-install it? Is irexec out there as an application that I can just put on my board?
drappleton
Fri Sep 27, 2013 2:44 am
FTrevorGowen wrote:FWIW, Notes on my, somewhat brief, foray into "IR Remote Control" can be found at: http://www.cpmspectrepi.webspace.virgin ... board.html
Trev.
This is getting interesting. I've put a new SD card in an attempt to redo everything including installing LIRC.
After this new install (on a clean SD card) the directory:
etc\lirc\
Still does not contain the executable: irexec
I am running the raspbian OS. Should I run a different OS to get this EXE file?
drappleton
Fri Sep 27, 2013 3:21 am
Shouldn't the application called be in \root\etc\lirc\
drappleton
Fri Sep 27, 2013 3:53 am
I've had the IR interface working. I've recorded codes for my remote. If I am unable to find the application irexec is there a different way that I can have button presses trigger an event?
Dilligaf
Fri Sep 27, 2013 4:58 am
You have irexec on your system, you need to add the config files to /etc/lirc, run the command
which irexec
and it will tell you where it is, if it doesn't then run the command with sudo
drappleton
Fri Sep 27, 2013 5:30 am
ednl wrote:
drappleton wrote:pi@raspberrypi ~ $ sudo irexec
Read what it says: irexec runs but can't open the config files. You need to create one or both. Any reason you're using sudo?
Thank you! "Read what it says"
I was looking for the actual application, but it is in fact running (from somewhere).
I need to see what's on with my config file (I have set them up but not in this directory).
I don't remember why I ran as Superuser.
Many thanks again.
ghans
Fri Sep 27, 2013 6:49 am
I agree with ednl.
By the way:
The reason that you can execute most commands from anywhere
without specifying the full path is that there are common
directories for programs under Linux just as under Windows
("C:\Program Files" vs /usr/bin , /usr/local/bin etc.) and that
they are searched for matching executables.
You can decide which directories are searched for commands
via manipulating the PATH variable (the so-called search path).
/usr/bin and /usr/local/bin should already be included in that
variable , along with other directories.
Long-standing DOS users might remember this , too ...
http://en.m.wikipedia.org/wiki/PATH_(variable)
ghans
