i2c IR sensor with 25MHz Clock
Posted: Mon Aug 12, 2013 8:52 pm
I'm currenty in the process of rigging up an IR sensor to the raspi via i2c. The sensor requires a clock signal @25MHz.
The question is, could i take this signal from P1-07 (GPCLK0) directly into the sensor rather than using an external oscillator or have i got the wrong end of the stick with the GPCLK. Incidentally, i'm trying to rig up the pixart IR sensor from a wiimote (no datasheets available but i've found that it requires a 25MHz clock).
Cheers,
Chris
Cheers,
Chris
