Corndork2
CAN bus on Pi
Wed Aug 07, 2013 3:50 pm
Hey everyone
Is anyone using CAN BUS on the Pi? I've got a couple USB to CAN BUS adapters connected to the Pi and am seeing them over the USB bus. I'm assuming that I will have to build a kernel with support for it. However, if anyone has already done so, would they please be kind enough to share their kernel?
I started building one, but my first attempt was not successful. I will be contuning to work on it, but would love any help or suggestions for others working with CAN on this platform
Thanks!
Richard-TX
Re: CAN bus on Pi
Wed Aug 07, 2013 5:04 pm
Depending on the USB-> CAN adapter you should be able to do everything from user space and not have to touch the kernel. What does the output of lsusb look like? Who made the device?
Richard
Doing Unix since 1985.
Corndork2
Re: CAN bus on Pi
Wed Aug 07, 2013 9:46 pm
Thanks very much for your reply.
Output of lsusb:
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 1ae0:0001
Bus 001 Device 005: ID 0878:1102
The bottom two devices are the USB to CAN adapters
One is a Sys-Tec Electronic USB to CAN adapter, and the other is a Axiomatic AX070501 USB to CAN adapter
I also have a Peak USB to CAN adapter I can try.
What would you suggest I do from here?
Corndork2
Re: CAN bus on Pi
Thu Aug 08, 2013 6:37 pm
Well I tried building a kernel for it a couple times on a couple different systems, including a Raspberry pi, and keep getting a Kernel Panic
Kernel Panic - Not Syncing: No init found
However the modules did compile... so could those be added to /lib/modules/drivers on a working pi with the same 3.6 kernel version?
yhzyhzyhz
Re: CAN bus on Pi
Sat Aug 31, 2013 6:19 am
I used a stm32 micro controller as a bridge, I used a stm32f103vet6 it has a lot of port. It can be connect to RPi with SPI, I2C, or RS232.
