anthonyjk
Reading Tach Wire Pulses from Fan
Thu Aug 01, 2013 6:38 pm
Hello, I recently purchased a fan to connect to my GPIO. I know everyone says that it isn't necessary, but I mostly want it just get some experience with the GPIO.
The particular fan I purchased has a 3rd wire for the tachometer, I was wondering if it was possible to read the pulses that this wire is sending through the GPIO and get a reading of the fan RPMs.
Also, is is possible to set the GPIO pins to low or high based on a temperature reading from the raspberry pi? Would a CRON job be the best way to accomplish this?
Thanks for the help.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0646317347
Richard-TX
Re: Reading Tach Wire Pulses from Fan
Wed Aug 07, 2013 4:51 pm
As far as I am concerned, the best way to do fan control is with an off-the-shelf solution.
Here is one that looks easy and is the one I would try first.
http://www.analog.com/static/imported-f ... DT7470.pdf
That chip is low cost (about $5) and has many features.
There are other chips available. Google for "I2C fan controller".
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
rurwin
Wed Aug 07, 2013 5:07 pm
This is currently under discussion here: http://www.raspberrypi.org/phpBB3/viewt ... 31&t=51501
