frikosal
BitWizard display
Thu Jun 20, 2013 10:07 pm
Hi, I'm trying to use the SPI BitWizard display with keypad,
http://www.bitwizard.nl/wiki/index.php/ ... erface#SPI
All I got from it after many tests is the initial message
"SPI_rpi_ui 1.6
A: 94"
For instance, the command to clear the lcd,
bw_tool -I -a 94 -r 16 -v 0
reports
can't open device: No such file or directory
Aborted
I tried to write to SPI using Wiring, no success.
Do you have that shield ? Any suggestion would be appreciated !
TommyboyNL
Re: BitWizard display
Fri Jun 21, 2013 2:39 pm
It seems the SPI driver isn't loaded. Try "sudo insmod spi-bcm2708", and then run your command.
