Does anyone have instructions or links for connecting two RPi,
using ethernet over usb?
I did manage to connect a kindle to one RPI this way.
see: http://www.ponnuki.net/2012/09/kindleberry-pi/
if not, other than ethernet patch cable, what's easy?
Re: 2x RPi ethernet over usb? howto?
Ethernet over USB connections are usualy done using the "USB Gadget CDC Ethernet" kernel feature, which make possible to emulate a "USB Network Adapter device".
One hardware requirement is that one USB Device / OTG port must be available. Unfortunately, I don't think the RPi has an OTG USB Port.
- Contact: Website Yahoo Messenger
Bastard Operator Of Hell Sentence No.: 2014:peepo wrote:Does anyone have instructions or links for connecting two RPi,
PI has OTG , but the usb ether link featger not compiled in.
dmesg | grep otg
[ 2.615696] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.085717] dwc_otg: Microframe scheduler enabled
[ 3.085932] dwc_otg bcm2708_usb: DWC OTG Controller
[ 3.093897] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 3.104267] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 3.153755] usb usb1: Manufacturer: Linux 3.8.13+ dwc_otg_hcd
[ 3.185069] dwc_otg: FIQ enabled
[ 3.185088] dwc_otg: NAK holdoff enabled
[ 3.602858] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 4.246797] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.586691] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
~ # uname -a
Linux smb 3.8.13+ #2 PREEMPT Thu May 30 09:52:24 UTC 2013 armv6l GNU/Linux
From this article, I understand that even if the BCM2835 does support USB OTG, electronic around the CPU doesn't: the LAN9512 chip is already connected to the unique USB port, acting as USB Host.
But I'm very new to Raspberry Pi, so I may be wrong
BofH sencence No.: 2015Electrocut wrote:From this article, I understand that even if the BCM2835 does support USB OTG, electronic around the CPU doesn't: the LAN9512 chip is already connected to the unique USB port, acting as USB Host.
please read this : https://developer.ridgerun.com/wiki/ind ... networking
~ # zgrep USB_GADGET /proc/config.gz
# CONFIG_USB_GADGET is not set
Yes, but I think you will met hardware limitation later. I'm afraid that is would be necessary to unsold the LAN9512 Chip, in order to connect directly to the CPU USB Port.
One other solution would be to buy a special "USB Host to USB host" cable, which acts as a USB Slave Ethernet Adapter from the computer side: http://ubuntuforums.org/showthread.php?t=993036
With this solution, no need to get the USB port work in Device mode
Yes, you are correct. The LAN chip prevents the possibility of using OTG on the model B. As the model A doesn't have the LAN chip, it would be possible to use that in OTG mode if the right drivers were installed.Electrocut wrote:From this article, I understand that even if the BCM2835 does support USB OTG, electronic around the CPU doesn't: the LAN9512 chip is already connected to the unique USB port, acting as USB Host.
If you want really simple hardware, but don't need a very high data rate, you could connect the serial ports on the GPIO headers together, and use SLIP.
https://github.com/IanHarvey
Really really late reply, but does the CONFIG_USB_GADGET feature apply to the Pi Zero as well ?
Short answer is: Yes.does the CONFIG_USB_GADGET feature apply to the Pi Zero as well ?
However, there are actually small problems with the USB gadget driver. If these are resolved PI A, PI A+ and PI Zeros can be used as nodes in a low-cost USB 2.0 cluster (without Ethernet adapters).
e.g one Rasperry (B+, B2) as host and all other Pis (A, A+, Zeros) as devices.
or one Zero as host and the other Zero as device. (BOM: 5$ + 5$ = 10$ for both Zeros. Add one Cabel and one 5V/2A PSU for both)
viewtopic.php?t=127211&p=852910patraulea wrote:Really really late reply, but does the CONFIG_USB_GADGET feature apply to the Pi Zero as well ?
