Klaas
[SPI] LED Matrix using Maxim MAX7221
Wed Apr 24, 2013 9:58 pm
I have been reading this board searching for information on how to control a LED Matrix. A lot of information was available and useful to get a LED Matrix working using a Maxim MAX7221. Via this post I want to share with you the "How to" on controlling the LED Matrix.
Build LED Matrix hardware
1. Only a couple of components are needed, see schematic:
Schematic
Make sure you also read the Data Sheet for the Maxim MAX7221
I build it on a test board first (on this picture I cascaded two matrix's).
Test Setup
The nice this about this schematic is that you can easily cascade multiple matrix's.
Setup the Raspberry Pi
1. Install the latest wheezy raspbian (2013-02-09).
2. Enable the SPI device
sudo nano /etc/modules
>Add line: spi_bcm2708
3. Reboot
sudo reboot
4. Check if SPI devices are available
ls /dev/spi*
>Result should be: /dev/spidev0.0  /dev/spidev0.1
*** Always make sure your hardware is powered down before doing (re)connecting! ***
Create sample program, compile and run.
Below a sample program which generates some nice effects.
 * SPI to MAX7221 (using spidev driver)
#include <math.h>
#include <stdint.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <getopt.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <sys/time.h>
#include <linux/types.h>
#include <linux/spi/spidev.h>
void timestamp(const char *s)
	time_t curtime;
	struct tm *loctime;
	char timestr [20];
	curtime = time(NULL);
	loctime = localtime(&curtime);
	strftime(timestr,20,"%H:%M.%S",loctime);
    printf("%s - %s",timestr,s);
static void pabort(const char *s)
	perror(s);
	abort();
static const char *device = "/dev/spidev0.0";
static uint8_t mode;
static uint8_t bits = 8;
static uint32_t speed = 200000;
static uint16_t delay;
static void matrixwrite(int fd, unsigned char max_address, unsigned char max_data)
	uint8_t tx[] = { max_address, max_data, };
	write(fd, tx, 2);
static void initspi(int fd)
	int ret = 0;
	/** spi mode **/
	ret = ioctl(fd, SPI_IOC_WR_MODE, &mode);
	if (ret == -1)
		pabort("can't set spi mode");
	ret = ioctl(fd, SPI_IOC_RD_MODE, &mode);
	if (ret == -1)
		pabort("can't get spi mode");
	/** bits per word **/
	ret = ioctl(fd, SPI_IOC_WR_BITS_PER_WORD, &bits);
	if (ret == -1)
		pabort("can't set bits per word");
	ret = ioctl(fd, SPI_IOC_RD_BITS_PER_WORD, &bits);
	if (ret == -1)
		pabort("can't get bits per word");
	/** max speed hz **/
	ret = ioctl(fd, SPI_IOC_WR_MAX_SPEED_HZ, &speed);
	if (ret == -1)
		pabort("can't set max speed hz");
	ret = ioctl(fd, SPI_IOC_RD_MAX_SPEED_HZ, &speed);
	if (ret == -1)
		pabort("can't get max speed hz");
void matrix_single(int fd, int delay, int repeat)
	uint8_t col; // Column
	uint8_t row; // Row
	uint8_t z;
	timestamp("2. single leds.\n");
	for (z = 1; z <= repeat; z++) {
		for (col = 1; col <= 8; col++) {
			for (row = 0; row <= 7; row++) {
				z = pow(2,row);
				matrixwrite(fd, col, z);
				usleep(delay);
			matrixwrite(fd, col, 0);
void matrix_colwipe(int fd, int delay, int repeat)
	uint8_t row; // Row
	uint8_t z;
	timestamp("3. Column wipe.\n");
			matrixwrite(fd, col, 0xFF);
			usleep(delay);
			matrixwrite(fd, col, 0x00);
			usleep(delay);
		for (col = 8; col >= 1; col--) {
			usleep(delay);
			usleep(delay);
void matrix_linewipe(int fd, int delay, int repeat)
	uint8_t row; // Row
	uint8_t z;
	timestamp("4. Line wipe.\n");
			z = pow(2,row);
				usleep(delay);
				usleep(delay);
void matrix_linewipeupdown(int fd, int delay, int repeat)
	uint8_t row; // Row
	uint8_t z;
	timestamp("5. Line up/down.\n");
			usleep(delay);
			usleep(delay);
void matrix_flash(int fd, int delay1, int delay2, int repeat)
	uint8_t row; // Row
	uint8_t z;
	timestamp("6. Flash.\n");
		usleep(delay1);
		usleep(delay2);
int main(int argc, char *argv[])
	int fd;
	fd = open(device, O_RDWR);
	if (fd < 0)
		pabort("can't open device");
	initspi(fd);
	printf("---------------------------------------\n");
	printf("spi mode: %d\n", mode);
	printf("bits per word: %d\n", bits);
	printf("max speed: %d Hz (%d KHz)\n", speed, speed/1000);
	//All leds off.
	for (col = 1; col <= 8; col++) { matrixwrite(fd, col, 0); }
	timestamp("1. Self test.\n");
	matrixwrite(fd, 0x0F, 0x01);
	usleep(500000);
	matrixwrite(fd, 0x0F, 0x00);
	usleep(500000);
	// Initialize Matrix
	matrixwrite(fd, 0x0C, 0x01); // Normal operation
	matrixwrite(fd, 0x0B, 0x07); // Scan Limit (all digits)
	matrixwrite(fd, 0x0A, 0x07); // Intensity
	matrixwrite(fd, 0x09, 0x00); // Decode mode (off)
	matrix_single(fd, 10000, 2);
	usleep(1000000);
	matrix_colwipe(fd, 20000, 5);
	usleep(1000000);
	matrix_linewipe(fd, 20000, 5);
	usleep(1000000);
	matrix_linewipeupdown(fd, 40000, 5);
	usleep(1000000);
	matrix_flash(fd, 30000, 70000, 20);
	timestamp("Completed.\n");
	//All leds off.
	close(fd);
	return;
1. Connect LED Matrix to Raspberry Pi and start the Raspberry.
2. Copy the code above to your Raspberry Pi to a file called "matrix_test.c".
3. Compile the source:
gcc -omatrixtest matrix_test.c -lm
Compiler warning can be ignored.
4. Start the program:
sudo ./matrixtest
Result displayed (and your matrix should start blinking too... 8-) ):
spi mode: 0
bits per word: 8
max speed: 200000 Hz (200 KHz)
23:43.01 - 1. Self test.
23:43.02 - 2. single leds.
23:43.04 - 3. Column wipe.
23:43.08 - 4. Line wipe.
23:43.12 - 5. Line up/down.
23:43.16 - 6. Flash.
23:43.18 - Completed.
Happy building... :D
metroroland
Re: [SPI] LED Matrix using Maxim MAX7221
Wed Jun 26, 2013 5:53 am
I am using your solution. Yet what if I want to cascade multiple Max7221s? Do I need to change the' bits per word' parameter such that I can successful to write to different drivers?
Richard-TX
Sat Jun 29, 2013 1:14 pm
The Max7221 allows for cascading on the SPI bus so the limit on the number of devices on a RPI is fairly high. It appears to be unlimited. (How many no-op commands can you send?)
Look at page 10 and the diagram at the bottom of page 13 of the document at http://datasheets.maximintegrated.com/e ... AX7221.pdf
Nothing special is needed to address the different chips.
If four MAX7219s are cascaded, then to write to the fourth chip, sent the desired 16-bit word, followed by
three no-op codes. When LOAD/CS goes high, data is latched in all devices. The
first three chips receive no-op commands, and the fourth receives the intended data.
Think of it like a shift register and it will become clearer.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
metroroland
Tue Jul 02, 2013 5:51 am
Hi Richard-TX,
I am curious when some other solution on the web require custom setting of load/CS to high/low to latch data, this one doesn't require. I suspect there is some different in writing the tx[] to fd, or can spidev handle this automatically, when I write uint8_t tx[] = { 0,0,max_address, max_data, }; to it?
Regards,
Roland
RobertPHeller
Wed Oct 26, 2016 8:41 pm
I am having trouble getting this to work on a Raspberry Pi B+ Model 2 (with the 40-pin header). Is this because this is a 3.3V device and not a 5V device, which the MAX7221 is meant for? My MAX7221 board works just fine with an Arduino driving it.
Robert Heller -- 978-544-6933
Deepwoods Software -- Custom Software Services
http://www.deepsoft.com/ -- Linux Administration Services
heller@deepsoft.com -- Webhosting Services
