ecardinal
Modern Device "USB BUB I" as a Raspberry Pi conso
Fri Apr 12, 2013 5:32 pm
Has anyone used the Modern Device 'USB BUB I' (not "II") as a Raspberry Pi console cable similar to Adafruit's? How should I wire it up? (I'm still new to this whole serial comm thing.) I'd rather not buy yet another flavor of FDTI cable if I don't need to. I also have a USBTinyISP, but I don't think that does quite the same thing. Please correct me if I'm wrong.
klricks
Re: Modern Device "USB BUB I" as a Raspberry Pi conso
Sat Apr 13, 2013 2:07 pm
I would use configuration 2 here:
http://cdn.shopify.com/s/files/1/0038/9 ... 1262060842
Configure for 3.3 V logic by soldering a wire across the 3.3 select pads -OR- if you need to switch back and forth from 5V to 3.3V logic then solder on the 3 header pins and install a berg jumper. For use with the RPi you must select 3.3V.
TX to RPi RX (GPIO pin 10)
RX to RPi TX (GPIO pin 8)
GND to GND (GPIO pin 25)
Normally you would not connect the 5V from the USB BUB to anything.
Go here for my RPi writeup. Basic config, Serial Port add-on etc:
http://blackeagle12.net/Comp/RPi/Rpi.html Click contact icon then world icon --->
moderndevice
Wed May 15, 2013 6:36 pm
I can confirm that this works, although it is slightly more convenient to use the ground on pin 6 instead. I just put up some photos and tutorials on the Modern Device blog here:
http://moderndevice.com/tutorials/talki ... evice-bub/
Who is online
Users browsing this forum: Baidu [Spider], targa and 15 guests
