howroyd
ser2net tracefile
Thu Apr 11, 2013 1:33 pm
Hi all,
I'm using ser2net to read in a serial stream and pump it out over TCP. Working well.
However, I want to include functionality to save the log to the sd card, which according to the ser2net info is just a line of code. However, when I use this it crashes when connecting to the port, saves no file and does not connect.
Any ideas?
Si
This works fine, but no log (tracefile)
BANNER:banner:\r\nraspPilot on  port \p device \d [\s] \r\n\r\n
2000:telnet:600:/dev/ttyAMA0:115200 NONE 8DATABITS -RTSCTS NOBREAK banner
2001:raw:600:/dev/ttyAMA0:115200 NONE 8DATABITS -RTSCTS NOBREAK banner
This is having none of it:
TRACEFILE:tb1:/tmp/ser2netLogTelnet
TRACEFILE:tb1:/home/pi/ser2netLogRaw.log
2000:telnet:600:/dev/ttyAMA0:115200 NONE 8DATABITS -RTSCTS NOBREAK tb=tb1 banner
2001:raw:600:/dev/ttyAMA0:115200 NONE 8DATABITS -RTSCTS NOBREAK tw=tw1 banner
michu
Re: ser2net tracefile
Fri Apr 12, 2013 8:21 am
try to open an issue on the ser2net website. I reported a bug in ser2net (did not work if ipv6 module was not loaded) that was fixed a day after.
cheers
howroyd
Fri Apr 12, 2013 8:39 am
Cheers,
I have put it up on their site at the link below if anyone else is interested.
https://sourceforge.net/p/ser2net/discu ... /f20632bb/
