Fri Apr 05, 2013 4:39 pm
Hallo,
have you followed the instructions from Alex?
Analog < > Digital converter programs (NEW 13 December 2012)
To make use of atod.py, dtoa.py and dad.py you MUST have SPI enabled
sudo nano /etc/modprobe.d/raspi-blacklist.conf
make sure there IS a # before blacklist spi-bcm2708, so it looks like this...
#blacklist spi-bcm2708
Adding this # prevents SPI being disabled. If you had to change it, you'll need to
reboot to activate SPI.
sudo reboot
You will need to install the Python SPI wrapper: (Python 2.7)
cd ~
git clone git://github.com/doceme/py-spidev
If you don’t have git installed, the above command will fail. Install git with...
sudo apt-get update
sudo apt-get install git
When asked if you want to continue, answer Y
then, after installation, try again
then it should copy the files into a directory called py-spidev. Go there next
cd py-spidev/
If you have already installed WiringPi for Python the next step (python-dev) may not be necessary...
then type
sudo apt-get install python-dev
y (to confirm).
sudo python setup.py install
And after that you should be able to use the ADC/DAC programs. No further reboot needed.
