basti122303
1-Wire Weather Station
Tue Apr 02, 2013 1:56 pm
After my try to get PCE FWS-20 Weatherstation working with pi i want to connect all the sensors to 1-Wire network.
At the Moment a BPM085 (Pressure-Sensor) is connected to PI
(see http://learn.adafruit.com/using-the-bmp ... i/overview).
Pin 1 -> VCC
Pin 3 -> SDA
Pin 5 -> SCL
How can I connect the Concept:
http://unix-solution.de/raspi/pic/DS2423.jpg
DeeJay
Re: 1-Wire Weather Station
Tue Apr 02, 2013 5:58 pm
If I have understood correctly, the connection to the Pi is a 'bus' which can be extended by adding further sensors in parallel. So you use the same GPIO pin.
basti122303
Wed Apr 03, 2013 7:58 am
A new Revison of my schemata, can anybody please check if it is ok?
http://unix-solution.de/raspi/pic/DS2423-2.jpg
basti122303
TX 23 -- invalid pin state
Fri Apr 05, 2013 10:01 pm
I have use my schema above and compile the code from swpi
(https://github.com/ToninoTarsi/swpi/blo ... readTX23.c)
pin2 -> yellow -> GND
pin3 -> Green
pin4 -> red -> 3.3V
           | 10K Ohm pullup
pin5 -> brown -> GPIO22 (pin15)
I get only this:
root@raspberrypi:/home/develop/swpi/TX23# python test.py
Segmentation fault
root@raspberrypi:/home/develop/swpi/TX23# ./readTX23 -v
Error 1 : Invalid pin state
root@raspberrypi:/home/develop/swpi/TX23# ./readTX23 --debug
62uS,1
Whats wrong?
basti122303
Fri Apr 05, 2013 10:26 pm
After a restart I get data like:
Bit Length: 1225 uSec
Start frame: 27
Wind Direction: WSW (11)
Wind Direction2: WSW (11)
Wind Speed: 1
Wind Speed2: 1
Checksum (received): 12
Checksum (calculated): 12
Data is Valid!
(11 , 1 )root@raspberrypi:/home/develop/swpi/TX23#
64uS,1
1616uS,0
19851uS,1
22292uS,0
23513uS,1
27173uS,0
28395uS,1
33277uS,0
51588uS,1
52809uS,0
57691uS,1
70021uS,0
89430uS,1
91949uS,0
93093uS,1
96753uS,0
97974uS,1
101636uS,0
104078uS,1
106518uS,0
115062uS,1
118725uS,0
121166uS,1
122387uS,0
126050uS,1
128532uS,0
130932uS,1
139599uS,0
140556uS,1
66uS,1
1563uS,0
19515uS,1
21957uS,0
23178uS,1
25617uS,0
29279uS,1
30501uS,0
48812uS,1
53714uS,0
54915uS,1
69685uS,0
89095uS,1
91631uS,0
92756uS,1
95198uS,0
98859uS,1
100080uS,0
118390uS,1
123273uS,0
124493uS,1
139264uS,0
140291uS,1
Start frame: 27
Wind Direction: S (8)
Wind Direction2: S (8)
Wind Speed: 0
Wind Speed2: 0
Checksum (received): 8
Checksum (calculated): 8
Data is Valid!
(8 , 0 )root@raspberrypi:/home/develop/swpi/TX23#
I have a small fan next to the wind sensor witch is rotate.
Whats wrong that the wind is too less?
Or in other words whats the measure ? (1,2,3) and can i get m/s ?
basti122303
Mon Apr 08, 2013 12:19 pm
There http://www.lavrsen.dk/foswiki/bin/view/ ... SMemoryMap I have found that wind-speed can be different units.
How can i set this?
MikeX
Wed Sep 04, 2013 8:23 pm
hi basti,
i'm also playing with RPi and the TX23 sensor.
unfortunately i do not get the swpi TX23 code running, i get the same errors as you before.
# ./readTX23 -v
# ./readTX23 -d
62uS,1
# python test.py
Segmentation fault
what have you done in order to get it working?
thanks
mike
basti122303
Sun Sep 08, 2013 6:37 pm
sorry my raspi is offline at the moment.
When I get this error something was wrong with the cable connection.
Regards,
basti
rayperkins
Sat Sep 14, 2013 8:11 am
Hi All. I have just got my PI reading from a TX23U using the RaspberryPiDotNet library and following John's guide here: http://www.john.geek.nz/2012/08/la-cros ... -protocol/
Let me know if you are interested in the code / wiring guide.
basti122303
Thu Nov 14, 2013 3:10 pm
Hello rayperkins,
can you please post your code?
At the moment i have several problems:
- first of all, in a test environment with a chassis-fan I get 24/7 data -- outdoor only a few per day
- I want to collect data via munin ... its a bit difficult to get a "reality" graph, specially for wind direction
wujek74
Sat Dec 07, 2013 4:54 pm
Does anyone launched a weather station on rpi cooperating with the TX23? I'm interested only wind strength and direction. I tried to run SWPI but unfortunately without success. Thank you in advance for your help, otherwise I'll have to sell the RPI and TX23.
rayperkins
Wed May 28, 2014 9:21 am
Hi All
Attached is the code for reading from a TX23U using .NET and RPi.Net. To run it make sure Mono is installed and then type the command 'sudo mono Home.TX23ULogger.exe 4', where '4' is the pin number connected to the TX23U line. The line must be pulled up by a resistor (4k7 works ok).
The code is based on the good work done here: http://www.john.geek.nz/2012/08/la-cros ... -protocol/
Let me know if you have any issues.
Enjoy!
Note: MikeX has pointed out some issues which I will correct and re post the code in the very near future. The workaround is to make sure the libbcm2835.so library is installed and loaded on the pi and either change the GPIO number in the code and recompile or use GPIO4. I hope to fix the issue in the next few days.
Home.TX23ULogger.zip
TX23U Visual Studio projects
(44.39 KiB) Downloaded 173 times
TX23UdotNet.zip
.Net console app
(32.82 KiB) Downloaded 156 times
Oomkens
Wed Aug 09, 2017 12:08 pm
A bump up for this old thread! Just wondering if someone has successfully integrated the TX23 and RPi 3B into a reliable datafeed for wind speed and direction.
rayperkins
Sat Aug 12, 2017 9:50 am
Hi Oomkens
The Mono program in the TX23UdotNet.zip file was made to take a reading from the TX23U. To make it work you will need to wire up the TX23U to a GPIO on the raspberry pi and then run the program with a command line argument saying what pin you have used (default is pin 4).
That is how I remember it from way back when.
Feel free to download the TX23UdotNet.zip application and see let us know if it works on the RPi3.
Oomkens
Sat Aug 12, 2017 7:19 pm
Yes, it does work after I updated the bcm2385 library file, since the pin count/lay-out is different. However, I'd like to automatically log the data into a SQL database. So I need to recompile the exec file, or something entirely new... You have suggestions?
frunk
Sat Feb 17, 2018 9:29 am
I spent a whole day trying to get data of the TX23 with the Raspberry Pi 3 and finally, works!
I just get running the Home.TX23ULogger.exe, but you must use pin BCM4 always, because the program didn't got the pin parameter.
1) Download the library bcm2835 version 1.55 and compile it:
(dont forget change xx with the version number)
# download the latest version of the library, say bcm2835-1.xx.tar.gz, then:
tar zxvf bcm2835-1.xx.tar.gz
cd bcm2835-1.xx
./configure
make
sudo make check
sudo make install
2) Compile libbcm2835.a:
cd bcm2835-1.xx/src
make libbcm2835.a
gcc -shared bcm2835.o -o libbcm2835.so
3) Download rayperkins program posted before.
4) Erase the old libbcm2835.so and move the new from /bcm2835-1.xx/src to the folder of Home.TX23ULogger.exe.
5) Run it (no wind today):
>>Angle 135, Direction SE, Speed 0, KPH 0
And that is all!
So I must parse the console out to python for get the data in my program!
If someone encourage, could fix the ToninoTarsi library for better integration.
orneeman
Sun Apr 08, 2018 4:21 pm
Hi
I got this error :"Failed to read TX23U"
someone can help me please?
frunk
Sat Apr 14, 2018 6:43 am
Hi
Is your data wire connected to BCM4?
