Question about 1Wire
Posted: Sun Mar 17, 2013 12:12 pm
by Kampi
Hello Guys,
i´m using 1Wire for my Raspberry Pi:
http://webshed.org/wiki/RaspberryPI_DS1820
Now i have a Question. Can i use the 1Wire for other Devices than an DS1820 Temperaturesensor on the same Way or is this way only for a DS1820.
I want to connect some other 1Wire Devices on my rPi but i don´t know if they got listed in the /sys/bus/w1/devices Folder.
Can somebody help me please :)
Thank you.
Greetings
Daniel
Re: Question about 1Wire
Posted: Mon Mar 18, 2013 2:38 pm
by beakersoft
You can use lots of devices on 1-wire, the DS1820 sensor is probably the easiest though, as the sensor itself ‘talks’ the 1-wire protocol.
There is a DS2438 device, that while designed to be used a battery monitor will allow you to interface into different sensors. Your best bet is probably to look at using that. Oddly enough I’m in the middle of creating a pcb add on board for the pi to provide 1-wire support over RJ45.
Posted: Mon Mar 18, 2013 8:36 pm
by repton
beakersoft wrote:Oddly enough I’m in the middle of creating a pcb add on board for the pi to provide 1-wire support over RJ45.
Like this:
http://www.sheepwalkelectronics.co.uk/RPI1.shtml
or this:
http://www.sheepwalkelectronics.co.uk/RPI2.shtml
The first one connects to GPIO4 to use the kernel 1-Wire driver, the second is an I2C based master.
Regards,
Paul
