basti122303
RFM01-868 noconnection
Thu Mar 07, 2013 9:00 pm
i try to connect a Hope RFM01-868S to my Raspberry.
It based on http://www.susa.net/wordpress/2012/08/r ... nd-rfm12b/ and this schemata http://www.raspberrypi.org/phpBB3/viewt ... 28#p259228
Data-Sheet: http://www.quasaruk.co.uk/acatalog/RFM01.pdf
So I connect like,without any pullup resistor (i think its on the RFM) http://unix-solution.de/raspi/Raspi_RFM01S.pdf
The connections are ok, i think. (tested with a continuity tester)
But there is no device found on i2c bus
[email protected]:~# i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
[email protected]:~# i2cdetect -y 1
[email protected]:~# exit
I have a PI with 256 MB RAM (Ver1.0B1.1).
basti122303
Re: RFM01-868 noconnection
Thu Mar 07, 2013 10:27 pm
The First Problem i have Fixed.
Sorry I'am a Newcomer on SPI and I2C interface programing.
the RFM is no i2c device.
Now i have download the code from susa, and do some changes
http://www.susa.net/wordpress/2012/08/r ... mment-1548
compiled an started.
I get some values like:
[email protected]:/home/pi/wh1080_rf# ./wh1080_rf
Initialising RFM01
SPI: mode 0, 8-bit, 1000 KHz
Ctrl+C to exit
  LNA_0,RSSI_73 idx 0     0.00    0.00    0.00    0.00    0.00    0.00
  LNA_0,RSSI_79 idx 1     0.00    0.00    0.00    0.00    0.00    0.00
  LNA_0,RSSI_85 idx 2     0.00    0.00    0.00    0.00    0.00    0.00
  LNA_0,RSSI_91 idx 3     0.00<   0.00    0.00    0.00    0.00    0.00
  LNA_0,RSSI_97 idx 4     0.00    0.00    0.00    0.00    0.00    0.00
 LNA_0,RSSI_103 idx 5     9.47  100.00  100.00  100.00  100.00  100.00
  LNA_6,RSSI_73 idx 6     0.00    0.00    0.00    0.00    0.00    0.00
  LNA_6,RSSI_79 idx 7     0.00    0.00    0.00    0.00    0.00    0.00
  LNA_6,RSSI_85 idx 8     0.00    0.00    0.00    0.00    0.00    0.00
  LNA_6,RSSI_91 idx 9     0.00    0.00    0.00    0.00    0.00    0.00
  LNA_6,RSSI_97 idx 10    0.00    0.00    0.00    0.00    0.00    0.00
 LNA_6,RSSI_103 idx 11    0.00   95.79  100.00  100.00  100.00  100.00
 LNA_14,RSSI_73 idx 12    0.00    0.00    0.00    0.00    0.00    0.00
 LNA_14,RSSI_79 idx 13    0.00    0.00    0.00    0.00    0.00    0.00
 LNA_14,RSSI_85 idx 14    0.00    0.00    0.00    0.00    0.00    0.00
 LNA_14,RSSI_91 idx 15    0.00    0.00    0.00    0.00    0.00    0.00
 LNA_14,RSSI_97 idx 16    0.00    0.00    0.00    0.00    0.00    0.00
LNA_14,RSSI_103 idx 17    0.00    0.00   90.53  100.00  100.00  100.00
 LNA_20,RSSI_73 idx 18    0.00    0.00    0.00    0.00    0.00    0.00
 LNA_20,RSSI_79 idx 19    0.00    0.00    0.00    0.00    0.00    0.00
 LNA_20,RSSI_85 idx 20    0.00    0.00    0.00    0.00    0.00    0.00
 LNA_20,RSSI_91 idx 21    0.00    0.00    0.00    0.00    0.00    0.00
 LNA_20,RSSI_97 idx 22    0.00    0.00    0.00    0.00    0.00    0.00
LNA_20,RSSI_103 idx 23    0.00    0.00   91.58  100.00  100.00  100.00
RSSI Duty 0.00
it's a loop like "tail -f"
is this normal?
what does the values mean?
whats wrong?
basti122303
Thu Mar 07, 2013 11:05 pm
I have changed some values and get more data, but i don't know if there are correct?
LNA=6 is the only one i get somethink like:
lm wh1080_rf.o bcm2835.o bmp085.o -o wh1080_rf
Initialising RFM01
Ctrl+C to exit
  LNA_0,RSSI_91 idx 3     0.00    0.00    0.00    0.00    0.00    0.00
 LNA_0,RSSI_103 idx 5    88.04  100.00  100.00  100.00  100.00  100.00
 LNA_6,RSSI_103 idx 11    0.00< 100.00  100.00  100.00  100.00  100.00
LNA_14,RSSI_103 idx 17    0.00    5.38   96.88  100.00  100.00  100.00
LNA_20,RSSI_103 idx 23    0.00    0.00   95.83  100.00  100.00  100.00
RSSI Duty 2.20
..Pulse stats: Hi: 113 - 958   Lo: 1051 - 3252  (46 point)
Data bits = 87   (offset 0) (11 short) No packet signature found
Pulse stats: Hi: 151 - 997   Lo: 1008 - 3681  (87 point)
Data bits = 81   (offset 43) (11 short) Packet signature found
Pulse stats: Hi: 148 - 997   Lo: 1000 - 7071  (81 point)
................Pulse stats: Hi: 126 - 976   Lo: 1021 - 1834  (50 point)
Data bits = 90   (offset 0) (191 short) No packet signature found
Pulse stats: Hi: 185 - 977   Lo: 1017 - 5909  (90 point)
Data bits = 73   (offset 0) (204 short) No packet signature found
Pulse stats: Hi: 148 - 987   Lo: 1012 - 3744  (73 point)
.........Pulse stats: Hi: 146 - 980   Lo: 1033 - 2912  (56 point)
.Pulse stats: Hi: 124 - 960   Lo: 1000 - 4307  (52 point)
.Pulse stats: Hi: 125 - 988   Lo: 1032 - 4009  (46 point)
Data bits = 61   (offset 20) (321 short) Packet signature found
Pulse stats: Hi: 109 - 928   Lo: 1000 - 4262  (61 point)
It looks like that i get this data only one time.
ksangeelee
Fri Mar 08, 2013 10:28 am
Try LNA_14,RSSI_103, or LNA_20,RSSI_103 - looks like you're getting some data from the unit, but just not reliably.
Finding the 'sweet spot' for your environment has been discussed here - http://www.raspberrypi.org/phpBB3/viewt ... 37&t=14777, and also in the blog comments in http://www.susa.net/wordpress/2012/08/r ... nd-rfm12b/
It's worth taking half an hour to at least skim the conversations, there's quite a lot of useful info there.
basti122303
Fri Mar 08, 2013 7:26 pm
I don't understand this:
Initialising RFM01
Ctrl+C to exit
 LNA_0,RSSI_103 idx 5     0.00   94.74  100.00  100.00  100.00  100.00
 LNA_6,RSSI_103 idx 11    0.00   67.71  100.00  100.00  100.00  100.00
LNA_14,RSSI_103 idx 17    0.00    0.00   86.32  100.00  100.00  100.00
LNA_20,RSSI_103 idx 23    0.00    0.00   85.26< 100.00  100.00  100.00
RSSI Duty 82.14
Data bits = 114   (offset 97) (0 short) Packet signature found
Pulse stats: Hi: 144 - 940   Lo: 1006 - 4299  (114 point)
^C
I only get data like following with config LNA_6 BW_134, LNA_14 BW_200, LNA_20 BW_200:
RSSI Duty 82.63
Data bits = 89   (offset 34) (153 short) Packet signature found
Pulse stats: Hi: 144 - 992   Lo: 1001 - 2888  (89 point)
Pulse stats: Hi: 111 - 973   Lo: 1043 - 4350  (47 point)
....Pulse stats: Hi: 149 - 999   Lo: 1000 - 2114  (42 point)
Data bits = 96   (offset 0) (264 short) No packet signature found
Pulse stats: Hi: 112 - 959   Lo: 1006 - 4404  (96 point)
...Pulse stats: Hi: 117 - 848   Lo: 1032 - 2637  (49 point)
.Pulse stats: Hi: 113 - 973   Lo: 1008 - 3318  (49 point)
................Pulse stats: Hi: 110 - 960   Lo: 1031 - 2612  (60 point)
.......Pulse stats: Hi: 112 - 964   Lo: 1039 - 5526  (41 point)
...............^C
What does RSSI Duty mean?
What is Pulse stats?
Can someone please explain the other values shown above?
Is the an other relevant config param?
When does Initialising finish?
I have a PCE-FWS-20 868Mhz Modell, is there anybody too?
basti122303
Sat Mar 09, 2013 7:20 pm
i still get no signal so i open the sender device and the station to take some photos.
http://unix-solution.de/raspi/pic/sender_front.jpg
http://unix-solution.de/raspi/pic/sender_back.jpg
http://unix-solution.de/raspi/pic/station.jpg
http://unix-solution.de/raspi/pic/receiver.jpg
http://unix-solution.de/raspi/pic/temp-sensor.jpg
The antenna has a lenght of 68mm.
Does anybody how long my antenna on the RFM01 must be?
And perhaps anybody can tell more about the sender module?
And here are some photos from my receiver based on RFM01
http://unix-solution.de/raspi/pic/RFM01-868-S.jpg
basti122303
Sun Mar 17, 2013 8:08 pm
Now my weather station is working.
I use this code: https://github.com/kenmcc/wh1080listener
so i have a sqllite database as backup and can inport the "csv" testfile into my postgres server.
But there are still some errors:
  • Is the station placed next to the raspberry it lose the connection after a while (20 min) or so.
    The longest time i continuously get data was for 4 hours.
  • Is the station placed 5m far away from raspberry the connection get unstable and lose some bits.
The first i have solved with a while loop to "re-initial" the sensor after 15 query’s, at the moment i test if its run 24h without any error.
The 2nd is a antenna problem i think. At the moment i use a copper wire, its 36,4 mm long.
Can anybody tell some details about a antenna for 868,3 MHz please?
Would this be an alternative?
http://www.conrad-uk.com/ce/en/product/ ... Max-range-
Whats about the "signal line loss" when i use this antenna with the 2.5 m coaxial cable (50 Ω) ?
Do i need any additional components?
Is there an other antenna that could be use?
I plan to install the antenna next to the sender to minimize the distance problem.
tb63
Wed Mar 20, 2013 2:00 pm
I think antenna should be 8.6 cm ( 1/4 wavelength ) fo 868 MHz.
basti122303 could you please post your code for the PCE 868MHz station ?
basti122303
Thu Mar 21, 2013 7:59 pm
I have changed only some param's:
rfm01.h
define the right module in Line 2 or 3
// #define BAND_433		(1 << 11)
#define BAND_868		(1 << 11)
weatherlogger.c
// uint16_t cmd_freq	= CMD_FREQ|0x620; // 433.92 MHz
uint16_t cmd_freq	= CMD_FREQ|0x67c; // 868.3 MHz
// change band from 433 to 868 and also BW, LNA_0, RSSI to your needs
uint16_t cmd_config	= CMD_CONFIG|BAND_868|LOAD_CAP_12C0|BW_134;
uint16_t cmd_rcon = (CMD_RCON|RX_EN|VDI_DRSSI|LNA_0|RSSI_97);
for more details read the comments on susa-site.
On this site you can also read
#define BAND_868		(1 << 12)
I don't know the differences.
The other changes I have done are only dirty debug hacks.
Play around with BW solve my problems partly.
rockyy
Mon Jun 09, 2014 5:00 pm
hey i also have a problem...
i tried BW200, 400, 134, LN0, 6, 14, RSSI from 85, 91, 97 allways duty: 100
i connected it like this:
SDO -> MISO
SDI -> MOSI
SCK -> SCLK
SEL -> CE0_N
FSK/DATA/nFFS -> GPIO27 (P1-13)
VDD -> 3V3 from Pi
GND -> GND on Pi
Initialising RFM01
Ctrl+C to exit
LNA_0,RSSI_73 idx 0 100.00 100.00 100.00 100.00 100.00 100.00
LNA_0,RSSI_79 idx 1 98.94 98.95 100.00 100.00 100.00 100.00
LNA_0,RSSI_85 idx 2 100.00 98.94 100.00 100.00 100.00 100.00
LNA_0,RSSI_91 idx 3 100.00< 100.00 100.00 100.00 100.00 100.00
LNA_0,RSSI_97 idx 4 100.00 98.94 98.94 100.00 100.00 100.00
LNA_0,RSSI_103 idx 5 100.00 100.00 100.00 100.00 100.00 100.00
LNA_6,RSSI_73 idx 6 100.00 100.00 100.00 100.00 100.00 100.00
LNA_6,RSSI_79 idx 7 100.00 100.00 100.00 100.00 100.00 100.00
LNA_6,RSSI_85 idx 8 100.00 100.00 100.00 100.00 100.00 100.00
LNA_6,RSSI_91 idx 9 100.00 100.00 100.00 100.00 100.00 100.00
LNA_6,RSSI_97 idx 10 100.00 100.00 100.00 100.00 98.95 100.00
LNA_6,RSSI_103 idx 11 100.00 100.00 100.00 98.92 100.00 100.00
LNA_14,RSSI_73 idx 12 100.00 100.00 100.00 100.00 100.00 98.94
LNA_14,RSSI_79 idx 13 98.94 100.00 100.00 100.00 98.89 100.00
LNA_14,RSSI_85 idx 14 100.00 100.00 100.00 100.00 100.00 100.00
LNA_14,RSSI_91 idx 15 100.00 100.00 100.00 98.94 100.00 100.00
LNA_14,RSSI_97 idx 16 100.00 98.95 100.00 100.00 100.00 100.00
LNA_14,RSSI_103 idx 17 98.94 100.00 100.00 100.00 100.00 100.00
LNA_20,RSSI_73 idx 18 100.00 100.00 100.00 100.00 100.00 100.00
LNA_20,RSSI_79 idx 19 100.00 100.00 100.00 100.00 100.00 100.00
LNA_20,RSSI_85 idx 20 100.00 100.00 100.00 100.00 100.00 98.94
LNA_20,RSSI_91 idx 21 100.00 100.00 100.00 100.00 98.95 100.00
LNA_20,RSSI_97 idx 22 100.00 100.00 100.00 100.00 100.00 100.00
LNA_20,RSSI_103 idx 23 98.95 100.00 100.00 100.00 100.00 98.94
RSSI Duty 99.79
martino
Thu Jan 22, 2015 12:16 pm
hello.
I need your help.
I have done all of this post but the program does the following:
[email protected] ~/wh1080_rf $ sudo ./wh1080_rf
Initialising RFM01
Ctrl+C to exit
LNA_0,RSSI_97 idx 4 0.00 0.00< 0.00 0.00 0.00 0.00
LNA_0,RSSI_103 idx 5 0.00 47.06 100.00 100.00 100.00 100.00
LNA_6,RSSI_103 idx 11 0.00 0.00 0.00 33.72 96.39 100.00
LNA_14,RSSI_103 idx 17 0.00 0.00 0.00 0.00 0.00 0.00
LNA_20,RSSI_103 idx 23 0.00 0.00 0.00 0.00 0.00 0.00
RSSI Duty 0.00
Data bits = 88 (offset 8) (0 short) Packet signature found
Frequency deviation 3.0KHz (3)
a6 e2 7b 2c 00 00 0c 17 00 08 crc ok (gap 27s)
Pulse stats: Hi: 611 - 718 Lo: 1631 - 1742 (88 point)
Threshold now 1174
I don't know why the program doesn't keep running ant printing the data (temperature...).
scarschtt
Mon Feb 08, 2016 11:56 pm
Hi, I'm trying to connect RFM01 to a Raspberry Pi 2 model B v 1.1, which uses a BCM2836, I can't find a the TIMER_ARM_COUNT address, where can I found it?
