External SDCARD with FatFs module
Posted: Sun Feb 24, 2013 4:59 pm
by Arjan
The attached code (Eclipse project) is tested with SD card and micro SD card. Both 2GB.
It uses only 4 bit of GPIO port. No interrupt, no SPI port is used.
The attached code is based on FatFs - Generic FAT File System Module (http://elm-chan.org/fsw/ff/00index_e.html).
And the sample MMC bitbanging code is taken from the zip file : http://elm-chan.org/fsw/ff/ffsample.zip
The changes to the generic sample code (mmcbb.c) are shown below.
#define  INIT_PORT()	init_port()			/* Initialize MMC control port (CS=H, CLK=L, DI=H, DO=in) */
#define 	DLY_US(n)	bcm2835_delayMicroseconds(n)		/* Delay n microseconds */
#define  CS_H()  bcm2835_gpio_set(RPI_GPIO_P1_26)	/* Set MMC CS "high" */
#define  CS_L()  bcm2835_gpio_clr(RPI_GPIO_P1_26)	/* Set MMC CS "low" */
#define  CK_H()  bcm2835_gpio_set(RPI_GPIO_P1_23)	/* Set MMC SCLK "high" */
#define  CK_L()  bcm2835_gpio_clr(RPI_GPIO_P1_23)	/* Set MMC SCLK "low" */
#define  DI_H()  bcm2835_gpio_set(RPI_GPIO_P1_19)	/* Set MMC DI "high" */
#define  DI_L()  bcm2835_gpio_clr(RPI_GPIO_P1_19)	/* Set MMC DI "low" */
#define  DO      bcm2835_gpio_lev(RPI_GPIO_P1_21)	/* Test for MMC DO ('H':true, 'L':false) */
void init_port(void) {
	bcm2835_init();
	bcm2835_gpio_fsel(RPI_GPIO_P1_23, BCM2835_GPIO_FSEL_OUTP); // CLK
	bcm2835_gpio_clr(RPI_GPIO_P1_23);
	bcm2835_gpio_fsel(RPI_GPIO_P1_19, BCM2835_GPIO_FSEL_OUTP); // MOSI
	bcm2835_gpio_set(RPI_GPIO_P1_19);
	bcm2835_gpio_fsel(RPI_GPIO_P1_26, BCM2835_GPIO_FSEL_OUTP); // CE1
	bcm2835_gpio_set(RPI_GPIO_P1_26);
	bcm2835_gpio_fsel(RPI_GPIO_P1_21, BCM2835_GPIO_FSEL_INPT); // MISO
The bcm2835_* functions are from Mike's library : http://www.open.com.au/mikem/bcm2835/index.html
The data transfer rate will be several times slower than hardware SPI. I've just received a logic analyzer and I hope to build code for the SPI hardware soon.
For reference the SDCARD pinout :
Re: External SDCARD with FatFs module
Posted: Sun Apr 28, 2013 4:57 pm
by mharizanov
that looks like interesting project, have you had further progress?
Posted: Tue Apr 30, 2013 3:25 pm
by Arjan
Yes, I have finished my new break-out board. See http://www.raspberrypi.org/phpBB3/viewt ... 92#p333992.
Furthermore, I am working on a bare-metal library for accessing the external SD card.
As I have already ported Mike's C library to bare-metal, it looks promising.
Regards, Arjan
Posted: Fri May 03, 2013 8:55 am
by Arjan
The source code {Linux} is now available from https://github.com/vanvught/OpenILDA/tree/master/sdcard
The source code {baremetal} is now available from https://github.com/vanvught/OpenILDA/tr ... card-mmcbb
Posted: Fri May 03, 2013 9:45 am
by mharizanov
Thanks,
will take a peek now
Posted: Thu May 09, 2013 9:57 am
by peterburk
I'm very impressed! I'm working on making version 2 of my PiPod (http://peterburk.dyndns.org/pipod) after the first one was stolen, and I'm hoping to make a built-in SD card reader this time. The 2 times I've needed a mobile USB host have been to read photos from an SD card, using a USB SD card reader.
I'm concerned about transfer speed, though. If the GPIO operates at 1 Mb/s instead of 480 Mb/s USB 2, I think it could take a rather long time for 20 photos of 5 MB each to transfer.
Can you confirm or deny my worries? How long does your system take to transfer 100 MB?
Thanks!
Peter
Posted: Thu Oct 17, 2013 9:02 pm
by vchristo
Hi friend.
First time thank you for this simple and functional solution.
I have tested and it works very fine, when it works alone (nothing more device on SPI bus)
but I found a trouble when I connect the ADC (mcp3004) on SPI bus as CS0.
if I execute the readout or write to sd card before initialize the ADC, I can read or write to card,
but the access to ADC gives wrong date acquisition.
If I read ADC first, I can not write to card.
I have forced CS1 and/or CS0 to high after finished access to sd card or ADC.
Have you any idea, can you help me?
thanks
Vitor
Posted: Fri Oct 18, 2013 8:21 am
by msperl
One question: why don't you use the standard linux mmc_spi.c driver (over spi) which exposes the device as a normal block-device? You then can use the file system of your choice to format it... I have used this before and it worked quite will - if I remember correctly I was able to get up to 1MB/s (probably read) using a 20mhz clock rate on the spi bus.
If you fancy to use the non-spi ports, then you might try to get the linux spi-bitbang.c driver to work to create a second spi bus with the pins of your choice.
As for troubles with 2 spi devices on the same spi bus: maybe you are using the spi driver for a device that is active on CS-high -not CS-low- maybe because you use an optocoupler or similar.
If so, then I have to tell you that I believe there is a bug in the spi-bcm2708.c driver that would change back to default-polarity whenever a second device is used (hence effectively sending to both devices).
I have just found this yesterday during a code-review (but without means to verify it, as I am missing such a device)... No patch available yet...
Martin
Posted: Wed Apr 23, 2014 6:52 am
by chiruru
Did you further more improvement?
I want to test about Second SD card for Raspberry Pi.
Please notify your situation for Second SD card
and How to use your Second SD card.
eg, How to connect HW, How to install SW, How to Mount on Linux...etc.
Thanks,,,,
Posted: Sun May 10, 2015 10:38 pm
by miguel_trujano
Hey im trying to read a second SDcard from the SPI pins of the raspberry pi B, so far i have try the first code from the ATTHACHMENTS, i havent been able to read anything from the SDcard, can somebody lead me in the right direcction, im kinda lost. i intend to read the raw SDcard without the directory i think it will be easier.
Thanks guys.
Posted: Thu May 14, 2015 10:49 am
by msperl
Note that there is an issue introduced somewhere in 3.13 that produces hickups detecting the sd card when loading mmc-spi.
It was a simple patch similar to this:
diff --git a/drivers/mmc/host/mmc_spi.c b/drivers/mmc/host/mmc_spi.c
index ae19d83..e21b8be 100644
--- a/drivers/mmc/host/mmc_spi.c
+++ b/drivers/mmc/host/mmc_spi.c
@@ -1386,8 +1386,7 @@ static int mmc_spi_probe(struct spi_device *spi)
        host->data = kmalloc(sizeof(*host->data), GFP_KERNEL);
        if (!host->data)
                goto fail_nobuf1;
-       if (spi->master->dev.parent->dma_mask) {
+       if (0) {
                struct device   *dev = spi->master->dev.parent;
                host->dma_dev = dev;
That made mmc_spi detect sd cards - with a corresponding device-tree...
dmesg shows:
[ 8687.130221] mmc1: host does not support reading read-only switch, assuming write-enable
[ 8687.130276] mmc1: new SD card on SPI
[ 8687.141819] mmcblk1: mmc1:0000 SD2GB 1.86 GiB
[ 8687.154384]  mmcblk1: p1 p2
Then you can mount the mmc directly in the kernel:
mount /dev/mmcblk1p1 /mnt
Posted: Thu May 14, 2015 10:55 am
by msperl
the corresponding device tree looks like this:
                sd1: sd@1 {
                                reg = <1>;
                                status = "okay";
                                compatible = "spi,mmc_spi";
                                voltage-ranges = <3200 3500>;
                                spi-max-frequency = <8000000>;
so all you need to do is write an overlay file...
Note that there is ONE catch that I have experienced:
make sure that mmc_spi is blacklisted in /etc/modprobe.d/raspi-blacklist.conf
otherwise the second sd-card may become the "main" boot-device resulting in headaches.
In case this happens: disconnect the sd card and you should be fine and you can boot the normal way...
Posted: Sun Dec 20, 2015 7:33 pm
by oneinsect
msperl wrote:Note that there is an issue introduced somewhere in 3.13 that produces hickups detecting the sd card when loading mmc-spi.
        if (!host->data)
                goto fail_nobuf1;
+       if (0) {
dmesg shows:
Hello Martin
Can you please tell me how to apply the above patch. I am running the latest raspbian 4.1.13 in my raspberry pi a+. My rpi a+ does not recognize the SPI SD Card.
Do i have to compile from source? There are NO dmesg or any logs anywhere that can show it recognizes the mmc1.
Thanking you
Rahul
