EduardH
I2C on Rpi4 in C language
Sun May 09, 2021 7:58 am
Good morning,
I am looking for some code examples about using the I2C interface on a Rpi4 (or Rpi3B+). There are many examples wtih Python but I didn't find any in simple C language.
The ultimate goal is connecting a pico to the Rpi4. The code on the pico seems to be working. The pico shows up in i2cdetect -y 1 .
Sincerely,
Eduard
joan
Re: I2C on Rpi4 in C language
Sun May 09, 2021 8:30 am
I suggest you choose a C GPIO library and look for I2C support. If you don't want to use a library I'd look at how the library implements the calls as a starting point.
Sun May 09, 2021 9:48 am
6by9
Sun May 09, 2021 5:47 pm
Please note that SMBus is a subset of I2C. Only use it if your slave device actually complies with the SMBus spec.
Kernel I2C docs - https://www.kernel.org/doc/html/v5.10/i ... rface.html
For generic I2C commands you want to look at ioctl I2C_RDWR. Set the slave address first with ioctl I2C_SLAVE.
EduardH
Tue May 11, 2021 7:28 pm
Good evening,
It took a lot of time figuring out why the Rpi4 master could write to the slave but not read. The slave is a raspberry pico. After all I changed the pico for an ordinary i2c integrated circuit. (a Philips TEA5767). From then on the bus was up and living.
There must be something wrong in the program I installed on the pico slave. Searching what goes wrong on the pico will be my next task.
Thanks a lot for Your help,
sincerely,
Eduard
