Serial communication voltages
Posted: Fri Jul 24, 2020 11:33 am
by blippy
I recently got an USB to TTL232 module. I suddenly realised that I have no clue about voltages. I'd like to connect the device's RX and TX pins to the appropriate GPIO pins on the Pi. I have no idea if that will fry the GPIO pins, though. What's the answer?
The chip is a CH340C. I'm assuming that VCC output is 5V, which doesn't matter, because I am powering my Pi separately anyway. The big question is what's coming out of the TX pin.
Re: Serial communication voltages
Posted: Fri Jul 24, 2020 12:12 pm
by B.Goode
blippy wrote: ↑Fri Jul 24, 2020 11:33 am
So you want to plug the usb end into some unspecified external device, and connect the 'other' side of the convertor to the RPi 40-way header?
The big question is what's coming out of the TX pin."
Absolutely! And for that you need the datasheet for the convertor module and/or its chipset.
But note that as a general principle rs232 signalling is bi-polar, or 'non return to zero'. So the two signal states ( mark/space ) are represented by positive and negative going versions of the same absolute signal level. Not only will a signal level of 5v be potentially fatal to a 3.3v gpio pin, but ANY negative-going signal is also likely to cause damage.
And just in case I don't know what I am talking about:
All UARTs on the Raspberry Pi are 3.3V only - damage will occur if they are connected to 5V systems.
Ref:
https://www.raspberrypi.org/documentati ... on/uart.md
Posted: Fri Jul 24, 2020 12:32 pm
by hippy
Indeed. You could just measure it with a multimeter as it should be idle high to connect to a Pi's UART. Or assume it's 0V/5V and choose resistors for an appropriate divider which will likely still work if 3V3.
.----------. .------------------< Pi TXD
| RX |<--' ___
| UART TX |-------|___|---.------> Pi RXD
| 0V |---. 12K .|.
`----------' | | | 22K
| |_|
`-----------^------- Pi 0V (GND)
UART TX = 5V0, Pi RXD = 3V2
UART TX = 3V3, Pi RXD = 2V1
Posted: Fri Jul 24, 2020 1:42 pm
by blippy
hippy wrote: ↑Fri Jul 24, 2020 12:32 pm
Aha, that's useful. That voltage came out at 4.05V, which I assume is still too high. Sigh, well that was a waste of a couple of quid from China!
Fortunately, I've got a Plan B. I have an ESP32, which operates on 3V3. So with a little bit of code I can use it as a "proxy" to the Pi.
Thanks for your help, guys.
Posted: Fri Jul 24, 2020 4:14 pm
by hippy
blippy wrote: ↑Fri Jul 24, 2020 1:42 pm
Just adjust the resistor values to drop it to 3V3 or slightly less. Plenty of on-line calculators available. 10K over 30K would probably do the job.
That's got to be a lot easier than using an ESP as some sort of proxy.
Posted: Fri Jul 24, 2020 4:19 pm
by FTrevorGowen
@blippy, for future reference you may find these notes/tests about/of a number of USB-to-Serial TTL devices of interest:
https://www.cpmspectrepi.uk/raspberry_p ... pters.html
Trev.
Posted: Fri Jul 24, 2020 9:47 pm
by blippy
hippy wrote: ↑Fri Jul 24, 2020 4:14 pm
My electronics knowledge is naff, but I can figure out voltage dividers. If I set up a voltage divider I have to set up components with a breadboard. If I use an ESP32, it's basically just three Dupont wires into the Pi.
Posted: Fri Jul 24, 2020 9:50 pm
by blippy
Posted: Sat Jul 25, 2020 9:12 am
by hippy
blippy wrote: ↑Fri Jul 24, 2020 9:47 pm
You can take your dupont wires, and solder the resistors in-line, wrap it all with insulating tape, no PCB required. Or pass it though a plastic pen body cut-off to make a nicer end-result.
But whatever you choose to do is fine.
Posted: Sat Jul 25, 2020 4:41 pm
by nliviu
You can use something like
this which has a jumper to select betweeen 5V/3.3V interface.
It works very well to program ESP8266 with the jumper set to 3.3V.
