CAN FD Bit Rate Switch on Raspberry Pi 3
Posted: Tue Mar 24, 2020 9:58 am
Hello everyone,
I am trying to get two RasPis with a CAN FD shield (MCP2517FD) to communicate via CAN FD. It actually works fine, but as soon as I set the BRS to TRUE, weird things happen and the messages are not sent out properly.
The setup I used for both Pis is pretty similiar to that one: https://github.com/GBert/misc/tree/master/RPi-MCP2517
I added the following lines to my /boot/config.txt:
The send and receive files are written and python and pretty much copied from: https://github.com/skpang/PiCAN-FD-Python-examples
If I send messages without the BRS active I receive:
Everythings fine so far.
Now I send the same messages but with the BRS set to True:
The result is different most of the times. I am sending 16 messages but only receive some of them (always a different number). Furthermore, if I send more messages from the same RasPi, I am getting the following error on the sending RasPi:
Sometimes the RasPi freezes and I have to shut him down.
The bitrates and samplepoints of both configurations are the same.
Any ideas on how to get this running properly while the BRS is set or why this is happening?
Thank you very much in advance!
core_freq=250
kernel=ms7/zImage
device_tree=ms7/bcm2710-rpi-3-b.dtb
overlay_prefix=ms7/overlays/
dtoverlay=mcp2517fd-can0
dtparam=interrupt=25
dtparam=oscillator=40000000
dtparam=spimaxfrequency=20000000
pi@raspberrypi:~/Desktop $ python receive.py
CAN Tx test
Bring up CAN0....
Ready
1585041201.788182 1 0 123 8 1 2 3 4 5 6 7 8
1585041201.808952 1 0 123 8 1 2 3 4 5 6 7 8
1585041201.830066 1 0 123 8 1 2 3 4 5 6 7 8
1585041201.851458 1 0 123 8 1 2 3 4 5 6 7 8
1585041201.872531 1 0 123 8 1 2 3 4 5 6 7 8
1585041201.893586 1 0 123 8 1 2 3 4 5 6 7 8
1585041201.914766 1 0 123 8 1 2 3 4 5 6 7 8
1585041201.935900 1 0 123 8 1 2 3 4 5 6 7 8
1585041201.957289 1 0 123 8 1 2 3 4 5 6 7 8
1585041201.978357 1 0 123 8 1 2 3 4 5 6 7 8
1585041201.999257 1 0 123 8 1 2 3 4 5 6 7 8
1585041202.020625 1 0 123 8 1 2 3 4 5 6 7 8
1585041202.042069 1 0 123 8 1 2 3 4 5 6 7 8
1585041202.062888 1 0 123 8 1 2 3 4 5 6 7 8
1585041202.083847 1 0 123 8 1 2 3 4 5 6 7 8
1585041202.104733 1 0 123 8 1 2 3 4 5 6 7 8
CAN Tx test
Bring up CAN0....
Ready
1585042868.352613 1 1 123 8 1 2 3 4 5 6 7 8
1585042868.372650 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.372807 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.372949 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.373283 1 1 123 8 1 2 3 4 5 6 7 8
1585042868.393287 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.393603 1 1 123 8 1 2 3 4 5 6 7 8
1585042868.414106 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.414431 1 1 123 8 1 2 3 4 5 6 7 8
1585042868.434750 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.435073 1 1 123 8 1 2 3 4 5 6 7 8
1585042868.455482 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.455801 1 1 123 8 1 2 3 4 5 6 7 8
1585042868.476293 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.476358 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.476461 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.476531 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.476863 1 1 123 8 1 2 3 4 5 6 7 8
1585042868.497091 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.497158 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.497273 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.497595 1 1 123 8 1 2 3 4 5 6 7 8
1585042868.517904 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.518014 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.518133 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.518226 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.518320 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.518439 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.518558 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.518678 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.518815 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.518870 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.518991 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.519087 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.519267 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.519425 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.519550 0 0 8 8 0 0 0 0 0 0 0 0
1585042868.519683 0 0 8 8 0 0 0 0 0 0 0 0
File "send.py", line 32, in <module>
bus.send(msg)
File "/home/pi/.local/lib/python2.7/site-packages/can/interfaces/socketcan/socketcan.py", line 626, in send
sent = self._send_once(data, msg.channel)
File "/home/pi/.local/lib/python2.7/site-packages/can/interfaces/socketcan/socketcan.py", line 649, in _send_once
raise can.CanError("Failed to transmit: %s" % exc)
can.CanError: Failed to transmit: [Errno 105] No buffer space available
