manthony121
current output on 5V header pins
Sun Jan 19, 2020 7:37 pm
I want to set up my Pi to control a 1 watt LED. The LED draws about 300 milliamp at 3.3 volts. I plan to use a GPIO pin to control a transistor to turn the LED on and off. Can the 5V pin on the J8 header provide the current to drive the LED? Or, do I need to use one of the USB ports to provide the current?
joan
Re: current output on 5V header pins
Sun Jan 19, 2020 8:17 pm
Yes, provided there is enough spare from your power supply after feeding the Pi and any connected peripherals.
Which model Pi?
manthony121
Sun Jan 19, 2020 8:35 pm
Not sure. Most likely a 3 B+, but I may wind up using a Zero-W. The only other peripheral will be a camera module.
