RiccardoMoretti
IR Receiver TSOP 31238
Wed Dec 19, 2012 1:32 pm
Hi, firstly I'm a complete beginner and would like to learn,
I'm posting in this forum in an attempt to understand how to interface the Pi with a IR receiver,
I know there are how to;s elsewhere but many of them don't explain the basics.
I'd like to connect a TSOP31238 Photo Module to the GPIO of the pi,
Firstly looking at the data sheet we have 3 pins (TSOP31238 )
1 = GND, 2 = VS, 3 = OUT
and the data sheet states
R1 and C1 are recommended for protection against EOS.
Components should be in the range of 33 Ω < R1 < 1 kΩ,
C1 > 0.1 μF.
R1 lies between the +Vs and Vs since the rough maximum mA the module uses is 4.5 mA
using Ohms law R = E/I and since I'll be using pin 1 3.3 V i get R= 3.3/0.0045 = ~733 Ω
So I should use a 733 Ohm resistor to protect my Pi.
Now the Capacitor (which is where I'm stuck)
it states the Cap should be > 0.1 μF but what voltage should it be? Must it be exactly 3.3 Volts?
Pihkal
Re: IR Receiver TSOP 31238
Thu Dec 20, 2012 5:55 pm
The voltage of the cap doesn't matter as long as it's higher than vcc,3,3V in your case.
So any cap above 0,1µF and over 3,3V will do.
Dilligaf
Thu Dec 20, 2012 6:10 pm
The data sheet also says that circuitry is optional. In my experience connecting the receiver directly to the gpio pins works fine
Pihkal
Fri Dec 21, 2012 2:35 pm
It might be optinional but i would consider it good practice to use them anyway.
Buffering the powerrail and limiting the current are just good design rules.
