slexy
Using bluetooth from raspberry pi to send commands to PC
Mon Sep 30, 2019 11:23 am
Hello!
Model: Raspberry Pi 3B+
We have a school project going, where we have to use raspberry pi to send joystick movement over bluetooth to PC to control a game. We've gotten the raspberry pi to read the joystick movement and button clicks.
I have zero experience with raspberry pi's bluetooth. Is there a possibility to send these commands through bluetooth and make PC read those commands.
The idea is to make a game with Unity 3D, which would be controlled with raspberry pi via bluetooth? I'm in a corner with this.
Another possibility is to use Wifi, but I'll let you more experienced guys to throw out ideas.
Douglas6
Re: Using bluetooth from raspberry pi to send commands to PC
Mon Sep 30, 2019 1:45 pm
Yes, a couple of ways to go.
1. If it's not a Macintosh PC, you can connect from the Pi using Bluetooth's Serial Port Profile (SSP). Then read and write to a program running on the Pi using serial communications.
2. You could make the Pi emulate a Bluetooth HID device that would send actual joystick movements to the PC. I did that once emulating a keyboard, but I can't be of much help with a joystick or game controller.
slexy
Mon Sep 30, 2019 1:53 pm
Thank you for your answer! This will help us to proceed further with the project.
Any recommended tutorials to use the SSP profile?
Douglas6
Mon Sep 30, 2019 2:29 pm
This post may help: https://www.raspberrypi.org/forums/view ... 85#p947185
After that, simply connect the devices using PySerial (with Python) or another programming language. You'll need to research how to do that on the PC.
