Reading SPI commands
Posted: Wed Sep 04, 2019 1:40 pm
by joshybaby
Good afternoon guys!!
I'm currently trying to use a raspberry pi to transmit some SPI commands but am not sure if they're being sent correctly.
I also have a second Pi laying around and I want to use it as a health checking monitor for all the information getting sent.
How would I go about recording what has been sent on the second Pi?
(it's preferable to be using the second Pi for readings due to location issues)
All I want to do is open a channel to read the GPIO traffic from the SPI specific pins (SCLK, CE0 and MOSI).
If anyone could advise I'll be eternally grateful.
Thanks!
Josh
Re: Reading SPI commands
Posted: Wed Sep 04, 2019 2:33 pm
by joan
If you can drop the SPI speed to 50kbps or so then you can monitor the GPIO on the Pi you are using for SPI.
http://abyz.me.uk/rpi/pigpio/piscope.html
or
http://abyz.me.uk/rpi/pigpio/examples.h ... monitor_py
or
http://abyz.me.uk/rpi/pigpio/examples.h ... SPI_mon_py
Posted: Thu Sep 05, 2019 9:39 am
by HermannSW
In addition to using Pi itself for that, you can use usb logic analyzer.
Cheap 8CH 24Msps ones start at 4$ (5$ with free shipping):
https://www.aliexpress.com/premium/logi ... _new_app=y
My 100Msps one did cost 20$, the 400Msps one 68$ (with free shipping).
I used logic analyzer sofar nearly only to analyze I2C traffic (from Raspberry to v1/v2 camera), but you can specify protocols as USB or SPI as well. The software does the decoding for you then.
I2C sample:
https://www.raspberrypi.org/forums/view ... 0#p1237647
Image Image
Time	[s]	Analyz.	Name	Decoded	Protocol	Result
1.21379535	I2C	Setup	Write	to	[l]	+	NAK
1.21390535	I2C	Setup	Read	to	[m]	+	NAK
1.21402639	I2C	Setup	Write	to	[l]	+	NAK
1.21413639	I2C	Setup	Read	to	[m]	+	NAK
1.21425728	I2C	Setup	Write	to	[l]	+	NAK
1.21436727	I2C	Setup	Read	to	[m]	+	NAK
1.21549542	I2C	Setup	Write	to	[l]	+	ACK
1.21558542	I2C	0	+	ACK
1.21567542	I2C	\n	+	ACK
1.21578542	I2C	Setup	Read	to	[m]	+	ACK
1.21587542	I2C	V	+	ACK
1.21596542	I2C	G	+	NAK
1.21658899	I2C	Setup	Write	to	[l]	+	ACK
1.21667899	I2C	'1'	+	ACK
1.21676899	I2C	'3'	+	ACK
1.21685899	I2C	'1'	+	ACK
1.21697899	I2C	Setup	Write	to	[l]	+	ACK
1.21706899	I2C	'1'	+	ACK
1.21715899	I2C	'0'	+	ACK
1.21724898	I2C	'0'	+	ACK
