LouisDT
Connection to DAC/ADC with SDIO
Fri Aug 23, 2019 9:26 am
I am attempting to connect a DAC (DAC1220E) and ADC (MCP3550) to the raspberry using the SPI. The DAC uses a single port for data transfer (in and out), the ADC only has a port for OUT/RDY. I looked into activating the bidirectional mode on the RPI4, but could not find a clear route for this.
Is it possible to set the SPI interface to bidirectional mode on the RPi4? More concretely: can SPI1 (3 CE) be turned on to birectional mode?
How do I enable this function?
Alternatively, is it possible to interface MOSI/MISO ports directly to a SDIO?
Any suggestions and help are greatly appreciated.
Links to datasheets:
DAC: http://www.ti.com/lit/ds/symlink/dac1220.pdf
ADC: https://pdf1.alldatasheet.com/datasheet ... P3550.html
tjrob
Re: Connection to DAC/ADC with SDIO
Mon Sep 09, 2019 5:13 am
I don't understand your question. SPI is inherently bidirectional -- whenever you write a byte, you also read a byte. On an ADS1256, while writing the configuration you ignore the bytes it sends to you; once you have told it to send the data, it ignores the bytes you send to it.
