Hi currently using a couple of relays to between my alarm system and my Pi, so basically when the Pir or door sensor activates the relay is triggeredfrom an output on my alarm system.
Unfortunately the relays are surprisingly loud especially when in the kitchen as the device activates multiple times if there are multiple people in there, I know I could box them to muffle it etc etc etc.
But is there a Mosfet circuit I can use to achieve the same goal?
my alarm panel puts out a 12Vdc signal, hence the current use of relays
cheers
