sterlingbutters
HDMI to CSI2 (TC358743) Raspbian Buster
Sat Aug 17, 2019 9:34 pm
Greetings,
The latest posts I've seen regarding progress in this are over a year old. With the release of the RPi4, I was hoping to use one of these bridges in my project. Documentation is not existent or limited in the support for this chipset driver. Tinkering with
ulv4
and
raspivid
, I have been unsuccessful in making any progress.
I haven't been able to make the distinction between methods used by @6by9 or @RpiName or even determine if they would work with Buster. I am looking for any guidance on getting audio&video stream using this bridge.
6by9
Re: HDMI to CSI2 (TC358743) Raspbian Buster
Fri Aug 23, 2019 11:42 am
uv4l is a closed source project, so you need RpiName or others involved in linux-projects.org to update things. Some people have reported that the Stretch packages will just work with some jiggery-pokery.
Use of raspivid is unsupported. It should still work, but won't be updated.
The kernel V4L2 drivers for it are being supported. See https://www.raspberrypi.org/forums/view ... 8#p1339178 for instructions on how to bring up the device. You can then use FFmpeg or GStreamer to access the data and create a processing pipeline. Or use yavta as a test app (see the link).
Lomax
Sat Oct 05, 2019 9:30 pm
6by9 wrote:uv4l is a closed source project, so you need RpiName or others involved in linux-projects.org to update things. Some people have reported that the Stretch packages will just work with some jiggery-pokery.
I'm curious about this - I only recently started looking at uv4l and immediately got a bad vibe; no name or contact details on the site, closed source code, and mysterious licensing procedure. Looks pretty dodgy to be honest. What do people know about linux-projects.org? Who is behind it? Is it a registered business - and if so, in what country?
