BostonBatman
Wiring 2.2" tft to pi zero w [Issues]
Sun Jul 14, 2019 11:27 pm
Hey everybody,
First time poster. I'm trying to wire up some tft lcds I got from China to my pi. I found the code to enable spi and add the screen-specific drivers, but I'm running into the rudimentary issue of not being confident in the wiring. All of adafruits walkthroughs are for 8 and 20 pin (iirc) screens and mine is only 7.
I'm adding the supporting files for the screen and what I thought the right configuration would be, but I have a few questions about whether the pin layout is correct for the zero. I won't be using I2C, so I'm just looking for clarity on that.
https://www.amazon.com/MakerFocus-Displ ... B07P9X3L7M is a near identical screen with the same pin layout, so if you use that pin out and the attached r pi zero w gpio pin layout for a 1:1 matching game, that would be the greatest thing ever, haha. Thanks!!!
HermannSW
Re: Wiring 2.2" tft to pi zero w [Issues]
Thu Jul 18, 2019 1:48 am
You have the pin description on display board, and explanation of the pins on amazon product page (5th image).
I used instructions in Kolban's (free) ebook on Raspberry Pi to easily connect ili9341 SPI displays:
https://www.raspberrypi.org/forums/view ... p?t=157618
After you will have successfully connected your display, you might want to connect two SPI displays to Pi Zero[W]:
https://www.raspberrypi.org/forums/view ... 4#p1217930
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
BostonBatman
Thu Jul 25, 2019 4:21 pm
The issue is the screen is actually from aliexpress and just uses very similar pinouts. The main issue is the multiple locations for the pins to connect and whether they are required or can be either spot. I guess I was looking more for a guide like, "mosi -gpio 17" etc or a "gpio 23 can be either x or y, but it's typically the touchscreen input for most screens". The main issue is the difference in the pinout from the adafruit store products and their respective tutorials.
HermannSW
Fri Jul 26, 2019 6:06 pm
Your display has 7 connections:
GND, VCC, SCL, SDA, RES, DC, BLK
RES, DC, BLK can be connected to any GPIO you like and are specified in the modprobe statement:
sudo modprobe fbtft_device name=rpi-display gpios=reset:23,dc:24,led:18 rotate=90
Besides VCC and GND these are the only fixed GPIOs for SPI0:
(SDA=)MOSI_____19 MOSI
(SCL=)SCK______23 SCLK
https://www.raspberrypi.org/forums/view ... 6#p1213885
Finally I moved pins into central 8 pin group of GPIO pins (pins 17-24), started with this command:
sudo modprobe fbtft_device name=rpi-display gpios=reset:25,dc:24,led:27 rotate=90
https://www.raspberrypi.org/forums/view ... 6#p1214626
I used those co-located pins to superglue the eight male connectors together in order to have my own GPIO connector (I did superglue the female pins as display connector as well):
