Lactobacillus
Pi 1B: Deactivate all LEDs
Sun Jul 07, 2019 9:18 am
I would like to deactivate all LEDs (but ACT = cpu0) of a Pi 1B at startup.
I was able to install this little program: https://www.raspberrypi.org/forums/view ... 63&t=72070
With "sudo ./MyScripts/llctl/llctl f0 l0 d0" I can deactivate the LAN-LEDs, but it does not work in my rc.local:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
#echo 0 | sudo tee /sys/class/leds/led1/brightness
# Set the ACT LED to trigger on cpu0 instead of mmc0 (SD card access).
echo cpu0 | tee /sys/class/leds/led0/trigger
sleep 30
#turn off LAN-LEDs
exit 0
Any Ideas how to deactivate the PWR-LED? "/sys/class/leds/led1" does not exist. led0 works fine.
Raspberry Pi 1B; Rev2; 512mb RAM (Samsung)
Raspberry Pi Zero, V1.3 + Esp8266
Burngate
Re: Pi 1B: Deactivate all LEDs
Sun Jul 07, 2019 9:45 am
If it's really an early Pi - from round 2013 - then you can't. The PWR LED is directly wired to the 3v3 line.
From the B+ to 3B, it's possible because there's a APX803 detecting low voltage that switches the LED off and feeds a GPIO to inform the SOC, so driving that GPIO low also switches it off.
Lactobacillus
Sun Jul 07, 2019 2:53 pm
It is really an old Pi: Late 2012 or early 2013. Made in China with 512 MB.
Does anyone know how to "sudo ./MyScripts/llctl/llctl f0 l0 d0" at startup?
Sun Jul 07, 2019 3:44 pm
Add this to /etc/rc.local (just before the exit 0 line).
/home/pi/MyScripts/llctl/llctl f0 l0 d0
Lactobacillus
Mon Jul 08, 2019 6:50 pm
Thats what I did (see first post), isn't it?
Mon Jul 08, 2019 7:36 pm
Does your script need the GUI? Or does it use pure command line stuff?
Does your script use explict paths and filenames (eg. /home/pi/foo not ~/foo)?
