rbis2101
PWM specs
Wed Jul 03, 2019 2:46 am
I've looked in the forums and for other on line documentation. I just need a few simple answers. What is the resolution of the PWM the pi3 is capable of (%DC)? How many pins on the header are PWM capable?
HermannSW
Re: PWM specs
Wed Jul 03, 2019 10:30 am
With software PWM between 320Hz and 16000Hz with pigpio library:
http://abyz.me.uk/rpi/pigpio/pigs.html#PFS
All pins can do software PWM. In addition Pi allows for two hardware PWMs [GPIO(12|18) and GPIO(13|19)]:
http://abyz.me.uk/rpi/pigpio/pigs.html#HP
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
rbis2101
Re: PWM specs
Sat Jul 06, 2019 2:35 am
Hermann thanks for your reply. It sounds like the frequency range is impressive, however I'm particularly in the duty cycle - you know the ratio of the time high to time low for each cycle. Can it be as low as 1% even with the software outputs or even <1%?
joan
Re: PWM specs
Sat Jul 06, 2019 7:18 am
The pigpio software PWM defaults are 800 Hz with 250 steps (internally mapped to 0-255). If you lower the frequency you get more resolution. If you higher the frequency you get less resolution. E.g. at 8000 Hz there are 25 steps, at 200 Hz there are 1000 steps.
The pigpio hardware PWM defaults are 250 million / frequency steps.
