dracode
Adding an I2C device via sysfs -- how to specify parameters?
Mon May 13, 2019 1:30 am
Greetings,
Using Device Tree, one can specify extra parameters for interfacing with a specific peripheral.
For example, adding this line to /boot/config.txt:
dtoverlay=ssd1306,height=32
The extra parameter changes the height of the display from the default of 64.
One can also add an I2C device after boot through the sysfs interface, like so:
echo ssd1306 0x3c > /sys/bus/i2c/devices/i2c-1/new_device
My question is: when adding a device like this (through sysfs, not device tree) after boot, how does one pass additional parameters? I can't figure out a way to use a non-default "height".
I know that using device tree would be the preferred way, but that isn't my question. I'm specifically looking to set up the device after boot on an already-running system.
davef
Re: Adding an I2C device via sysfs -- how to specify parameters?
Thu May 16, 2019 12:31 am
If I recall correctly, doing this years ago, that in
or
there should be a list of parameters that you are allowed to change. Again, I think something like
echo some number to that location
How you might add new ones I never tried.
6by9
Thu May 16, 2019 9:30 am
You can use "sudo dtoverlay ssd1306 height=32" on a running system to dynamically load the DT overlay with parameter.
Add -R to remove the overlay (only works if loaded dynamically and not via config.txt).
dracode
Thu May 16, 2019 11:58 pm
This worked, thanks!
