RS485 with UART and pyserial
Posted: Wed Feb 20, 2019 7:20 pm
by Elektrix
Hello all,
this is my very first post in this beautiful forum. I found lots of information here already. Thanks to all.
At the moment I am trying to get RS485 up and running. This seems nothing special as there are lots of RS485 boards around. I already have this one: https://www.conrad.biz/de/raspberry-pi- ... 67832.html and it works in one of my environments. With other devices I can't get RS485 running perhaps beause of the behaviour of this device:
For RS485 communication the sender / receiver has to by switched in either send or receive mode. This is done normally by an additional output pin. The board I have doesn't do this and switches between send and receive depending on the state of TX. I think this is somewhat strange but seems to work and the advantage is that this additional output pin is not needed. Only TX and RX are necessary.
What I want to do is to create a standard RS485 bus. The transceiver switches to send mode then sends all the bits and then switches back to receive mode. What I found is that on the raspi the pin used to switch the transceiver is RTS (GPIO 17) and pyserial has a RS485 mode. So I set up the following code:
#!/usr/bin/env python3
import serial
import serial.rs485
ser = serial.Serial(
               port="/dev/ttyAMA0",
               baudrate = 9600,
               parity=serial.PARITY_NONE,
               stopbits=serial.STOPBITS_ONE,
               bytesize=serial.EIGHTBITS,
               timeout=0,
               rtscts = True
ser.rs485_mode = serial.rs485.RS485Settings()
if (ser.isOpen() == True):
  ser.close()
ser.open()
ser.reset_input_buffer
outstr = "5"
ser.write(outstr.encode(encoding = 'ascii'))
This code initializes the UART and simply puts out one character and is according to this info: https://pyserial.readthedocs.io/en/late ... l_api.html. When I comment out the line beginning with ser.rs485_mode... the code runs and I see the correct output signal on the TX pin with my scope. But with rs485 mode activated I get the following error that I don't understand:
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 156, in _set_rs485_mode
fcntl.ioctl(self.fd, TIOCSRS485, buf)
OSError: [Errno 25] Inappropriate ioctl for device
During handling of the above exception, another exception occurred:
File "./test485.py", line 14, in <module>
File "/usr/lib/python3/dist-packages/serial/serialutil.py", line 480, in rs485_mode
self._reconfigure_port()
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 434, in _reconfigure_port
self._set_rs485_mode(self._rs485_mode)
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 158, in _set_rs485_mode
raise ValueError('Failed to set RS485 mode: {}'.format(e))
ValueError: Failed to set RS485 mode: [Errno 25] Inappropriate ioctl for device
The pyserial package is python3-serial and the OS is rasobian stretch lite 2018-11-13. I am totally stuck here so any help is very much appreciated.
Elektrix
Re: RS485 with UART and pyserial
Posted: Thu Feb 21, 2019 3:37 am
by tempest766
scanning through your initial message I'm not seeing the buzzwords "mutli-drop", "half-duplex" or "master/slave" . I believe those concepts are important for what I understand you're trying to do.
This is a good starting point -- http://www.bb-elec.com/Learning-Center/ ... ndard.aspx
Posted: Thu Feb 21, 2019 5:33 pm
by Elektrix
Thank you for your reply. The transceiver on the raspi is always the busmaster in this RS485 bus. All other members are slaves. I want the bus to run in half duplex master/slave which is RS485 standard.
What I have understood so far is that GPIO17 which can be used as RTS for RS232 is used to switch send / receive mode of the transceiver in RS485 mode. This is what I want to do.
I hope it's a bit clearer now.
Elektrix
Posted: Thu Feb 21, 2019 7:27 pm
by danjperron
There is a class for rs485 settings in pyserial.
https://www.raspberrypi.org/forums/view ... 5#p1383709
Posted: Fri Feb 22, 2019 7:19 pm
by Elektrix
Thank you very much for this link!! This is exactly the information I was looking for. I will try it out and then come back.
Elektrix
Posted: Mon Jun 10, 2019 8:38 am
by TheJanggut
Hi there
I would like to ask. Now want to asked something. How do I connect the RaspberryPi 3 Model B with USB to 2 Wire RS 485.
