raspberryfish
RFM12 directly to RPi?
Mon Nov 19, 2012 7:51 pm
is there a chance to connect a RFM12-Module directly to the RPi? I found this, but i dont want to buy the board, because i have few RFM12 here.
Peter
Re: RFM12 directly to RPi?
Mon Nov 19, 2012 8:44 pm
I think you might need to be a bit more specific about what an RFM12 module actually is - some links would help.
thsBavR10
Mon Nov 19, 2012 9:05 pm
maybe this one: http://www.hoperf.com/upload/rf/RFM12.pdf
FEATURES
• SPI compatible serial control interface
• Clock and reset signals for microcontroller
• 16 bit RX Data FIFO
• Two 8 bit TX data registers
• 2.2 to 5.4 V supply voltage
raspberryfish
Mon Nov 19, 2012 9:30 pm
Yes its the RF-Module thsBavR10 mentioned.
raspberryfish
Mon Nov 19, 2012 10:07 pm
Not tested yet,...
maybe this could be an approach
thsBavR10
Tue Nov 27, 2012 6:15 am
Many thanks for the hint - although I'm not the starter of the thread.
raspberryfish
Tue Nov 27, 2012 6:37 am
Yes, thank u a lot.
Stephen99
Wed Jan 02, 2013 6:06 pm
Hi Peter,
If you want to connect using FSK rather than OOK you might want to take a look at the JeeLabs forum at http://jeelabs.net/boards/6/topics/213.
Stephen
emmerlin
Wed Feb 06, 2013 3:11 pm
wrote some stuff in c, setting up a handshaked communication between two rfm12b-modules, controlled by RPi's SPI-Bus, some doxygen documentation included, check it out
http://www.hs-coburg.de/20775.3
thsBavR10
Thu Feb 07, 2013 8:18 pm
@emmerlin:
pretty solution, excellent documentation!
Grüße aus Erlangen, ich habe in CO studiert :-)
Bramco
Sun Feb 10, 2013 4:33 pm
Have you seen the board already available at OpenEnergyMonitor?
http://openenergymonitor.org/emon/emonbase/raspberrypi
Phunkafizer
Tue Jan 28, 2014 11:32 am
Here is a small adapter board which is interfacing the RFM12 directly to the raspberry:
http://www.seegel-systeme.de/index.php? ... spberry-pi
I use it to receive wireless temperature- and energysensors.
Regards
Stefan
Jeppedy
Tue Feb 11, 2014 7:00 pm
Has anyone done this yet? I'll be glasd to use the RFM12Pi board (I have one on order), but I'd like to see some references where the Pi is already communicating over RF, including what libs and code were used on the Pi.
I want to experiment with making my own sensor network, but when it comes to RF to the Pi, most sources out there start to get thin and inconclusive.
Have you done it? If so, how did you communicate to the RPi over RF?
meigrafd
Sun Dec 28, 2014 12:15 pm
Have a look to my Development Thread:
http://www.forum-raspberrypi.de/Thread- ... unk-sensor
I've described the direct connect of RFM12B Module to PI @ "Beitrag#873" and "Beitrag#849"
And the final Collection of the Development:
http://www.forum-raspberrypi.de/Thread- ... 7#pid62817
:ugeek:
