Display dsi check
Posted: Wed Dec 19, 2018 10:11 pm
by jax7121
hi guys, is there a way to check if the dsi touchscreen display (of a remote raspberry) is working or not?
Re: Display dsi check
Posted: Wed Dec 19, 2018 11:11 pm
by DougieLawson
A
tvservice -s command will return this:
pi@tranquility:~$ tvservice -s
state 0x400000 [LCD], 800x480 @ 60.00Hz, progressive
pi@tranquility:~$
Posted: Fri Jan 25, 2019 7:04 pm
by jax7121
hi, thanks for the reply. I was already aware of the "tvservice -s" command.
But my goal is to monitor the display in real time. Let me explain: If I start the raspberry with the display connected (powered separately from the rasp) and run the command "tvservice -s" the answer is as you say "state 0x400000 [LCD], 800x480 @ 60.00Hz, progressive". But if I disconnect the power of the display alone and relaunch the control command I get the same answer.
Is there an alternative command to identify correct operation in real time without restarting the rasp? Thanks in advance.
Posted: Fri Jan 25, 2019 7:05 pm
by DougieLawson
There's nothing to monitor. If the display goes off you can't restart it without a reboot.
