RPI 3 UART max speed
Posted: Wed Nov 14, 2018 9:06 am
by RPI_333333
I saw many posts on this issue but still don't have a clear answer.
I would like to use the UART on the Pi3 at the highest rate possible but still make sure the transmission is fully realiable.
I haven't managed to find a clear answer: what is the maximum UART rate for realiable transmission ?
I would also like to know:
1. What is the UART driver on the RPI 3 , is it PrimeCell® UART (PL011) (How can i confirm that this is the exact component)?
2.What are the driver capabilities, what is the maximum baud rate?
Acorrding to the reference manual secion 2.1:
supports the following maximum baud rates:
— 921600 bps, in UART mode
— 460800 bps, in IrDA mode
— 115200 bps, in low-power IrDA mode.
LInk to the document:
http://infocenter.arm.com/help/topic/c ... p5_trm.pdf
3. I saw that many people mentioned that they manged to activate the UART at much higher rates than the manual, how can it be?
Thanks for the help!
Re: RPI 3 UART max speed
Posted: Wed Nov 14, 2018 1:03 pm
by HiassofT
The RPi has 2 UARTs, a PL011 and a "mini UART". In general it's best to use the PL011.
The PL011 uses the ~48MHz uart clock as a base, which results in a maximum achievable baudrate of 3Mbit/sec (48MHz/16).
I recently did some tests and transmitting data at 3mbit/sec looked fine on the scope. I haven't done any receive tests but I guess with RTS/CTS handshaking enabled (the PL011 and the driver seem to support auto hardware RTS/CTS handshaking) that should work fine.
The miniuart is a bit of an odd beast, it uses the ~250MHz VPU clock as a base so maximum baudrate would be about 31.25 Mbit/sec. But the actual baudrate seems to be a bit lower than requested - even at lower speeds like 115kbit/sec. Not sure what's exactly going on there, actual speeds seemed to be within acceptable (+/- 3%) limits though.
so long,
Hias
Posted: Wed Nov 14, 2018 1:35 pm
by RPI_333333
so long,
Hias
Thanks for the answer.
If the PL011 UART can go up to 3Mbit/sec why the PL011 spec mentioned 921600 bps ? what am i missing?
Posted: Wed Nov 14, 2018 1:57 pm
by bensimmo
Just adding a link to the UART documents for anyone else reading.
https://www.raspberrypi.org/documentati ... on/uart.md or for the RPI_333333 if not found already.
Posted: Thu Nov 15, 2018 6:12 am
by RPI_333333
Thanks you all for the answer,
I still don't understand:
Posted: Mon Oct 26, 2020 7:02 pm
by Michiel
Where did you get the 48MHz from?
