Nagendar
PEAK System CAN Device Error Over Run and insufficient power supply on Raspberry PI
Mon Oct 15, 2018 8:14 am
I am working on PEAK CAN USB and Raspberry pi. I need to get CAN messages from PCAN on Raspberry Pi. for that i have implemented Matlab Custom Simulink Library to read CAN data from PCAN. i will connect PCAN through USB2.0 port. when i run the simulation after some time CAN data is terminated from the Bus. CAN Bus works with 500k buad rate. I suspect error raised because of the insufficient power supply from raspberry pi to PEAK device. is raspberry pi available with USB3.0 port?. i want to test with USB3.0 port.
Thanks and Regards,
Nagendar
