JSmith1717
Replacing HDMI port Pi 3 B+
Wed Oct 03, 2018 2:47 pm
Was wondering if the HDMI port could be replaced with a 0.5mm 19 pin fpc connector? Like the adaptors you can get for the HDMI to fpc cable but I want it directly on the board.
JSmith1717
Re: Replacing HDMI port Pi 3 B+
Wed Oct 03, 2018 4:16 pm
Looks like it will work in Eagle, pinouts are backwards but that doesnt matter
Screenshot (1).png (35.08 KiB) Viewed 491 times
aBUGSworstnightmare
Wed Oct 03, 2018 5:14 pm
It's 0.5mm pin pitch, so why shouldnt it work? Pin assignment should also be no issue as you will need a custom adapter for the other end of the FPC
JSmith1717
Wed Oct 03, 2018 6:10 pm
Well the other end will be going to a pcb I'm building for a portable retropie system
