bertr2d2
RPi galvanic isolated CAN-Bus Interface
Fri Sep 14, 2018 2:13 pm
if you are looking for a cheap, easy to build and galvanic isolated RPi CAN-Bus interface please have a look at:
https://github.com/GBert/misc/tree/master/RPi-MCP2515
PCB files are part of the git. If you prefer ready to use PCBs you can buy a proto pack (8+ PCBs - share it with you friends ;-) ) at Dirty-PCBS
Setup is easy:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install can-utils
edit /boot/config.txt
; uncomment
dtparam=spi=on
; add
dtoverlay=mcp2515-can0,oscillator=16000000,interrupt=25
; RPi 3
dtoverlay=spi-bcm2835-overlay
reboot
sudo shutdown -r now
Setup (e.g 250k)
sudo ip link set can0 up type can bitrate 250000 restart-ms 100
Regards
Gerd
PS: PCB also contains I2C Busextender (top - left side) which is optional
Easy to build CAN-Bus interface:
http://lnxpps.de/rpie
