JuanPZ
I2C read always get first byte
Thu Sep 13, 2018 10:40 pm
Hello, I have a little problem with I2C
I have an Arduino (Slave) and a PI (Master) connected with I2C. I can send strings through I2C to the Arduino using i2cset:
[email protected]:~ $ i2cset -y 1 0x08  0x41 0x52 0x47 0x42 0x3a 0x32 0x35 0x35 0x32 0x35 0x35 0x32 0x35 0x35 0x32 0x35 0x35 i
(The message was "ARGB:255255255255", for the arduino that is 255 255 255 255)
But when I try to retrieve a message sent by the Arduino using i2cget, I only get the first Byte
[email protected]:~ $ i2cget -y 1 0x08
0x32
(The message sent by the arduino was "255255255255", without the ARGB)
I read in Google that if I call the function twice, I should read another byte (0x35), but it's stills being 0x32 ("2"). I can call it a lot of time, but the result is the same.
So I though that it could be the Address parameter, but it's seems that It's ignored, because I can send this:
[email protected]:~ $ i2cget -y 1 0x08 0xff b
but the result stills 0x32.
If I look i2cdump, I get this:
[email protected]:~ $ i2cdump -y 1 0x08
No size specified (using byte-data access)
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 32 32 32 XX XX XX XX XX XX XX XX XX XX XX XX XX    222XXXXXXXXXXXXX
10: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
f0: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
I don't know If I'm using wrong the i2c, or if this is a bug from the apt-get package (i have the last version from apt-get) but I can't find any solution to read at least 3 bytes
Note: I tried sending a short message (only 3 bytes) from the Arduino, but the result was exactly the same.
Note2: The arduino gets the message correctly from i2cset, so the connection and the setup should be correct
joan
Re: I2C read always get first byte
Thu Sep 13, 2018 11:27 pm
We need to see the Arduino code.
JuanPZ
Thu Sep 13, 2018 11:31 pm
Sorry, I forget that. Here is (I removed some code to make it simple. Every code related to Wire stills there):
#include <Wire.h>
int aValue = 0; //0-255
int rValue = 0; //0-255
int gValue = 0; //0-255
int bValue = 0; //0-255
void setup() {
  Serial.begin(9600);
  Wire.begin(8);
  Wire.onReceive(OnReceive);
  Wire.onRequest(OnRequest);
void OnReceive(int Length) {
  Serial.println("Receiving...");
  String inString = "";
  int pos = 0;
  while (Wire.available() && pos < Length) {
    inString += (char)Wire.read();
    pos++;
  Serial.println(inString);
  if (inString.startsWith("RGB:")) {
    aValue = 255;
    rValue = inString.substring(4, 7).toInt();
    gValue = inString.substring(7, 10).toInt();
    bValue = inString.substring(10, 13).toInt();
  } else if (inString.startsWith("ARGB:")) {
    aValue = inString.substring(5, 8).toInt();;
    rValue = inString.substring(8, 11).toInt();
    gValue = inString.substring(11, 14).toInt();
    bValue = inString.substring(14, 17).toInt();
void OnRequest() {
  char ARGBStr[12];
  snprintf(ARGBStr, 12, "%03d%03d%03d%03d", aValue, rValue, gValue, bValue); //this make 255255255255
  Wire.write(ARGBStr);
  Serial.println(ARGBStr);
joan
Fri Sep 14, 2018 7:38 am
I would get rid of the serial prints from within the Arduino interrupt handlers. They could be delaying the I2C bus.
JuanPZ
Fri Sep 14, 2018 4:48 pm
Hi. I tried that but without success.
I have a question: Do I have to interpetate the Address sent from the Pi in the Arduino?
I mean: If I send 0x1, the arduino has to send the first byte manually (hard-code)?
danjperron
Sun Sep 16, 2018 12:07 am
Did you forget that an Arduino UNO is very slow.
you can't use sprintf inside the OnRequest. is too slow
make all the computation into a buffer then the OnRequest will works.
you are writing an array but you should write a byte at once.
ex:
#include <Wire.h>
void setup() {
  Wire.begin(8);
int index=0;
unsigned char Table[12]={11,10,9,8,7,6,5,4,3,2,99,98};
void OnRequest() {
  Wire.write(Table[index]);
  index= (index + 1) % 12;
void loop()
  delay(1);
0x0b
0x0a
0x09
0x08
0x07
0x06
00: 05 04 03 02 63 62 0b 0a 09 08 07 06 05 04 03 02    ????cb??????????
10: 63 62 0b 0a 09 08 07 06 05 04 03 02 63 62 0b 0a    cb??????????cb??
20: 09 08 07 06 05 04 03 02 63 62 0b 0a 09 08 07 06    ????????cb??????
30: 05 04 03 02 63 62 0b 0a 09 08 07 06 05 04 03 02    ????cb??????????
40: 63 62 0b 0a 09 08 07 06 05 04 03 02 63 62 0b 0a    cb??????????cb??
50: 09 08 07 06 05 04 03 02 63 62 0b 0a 09 08 07 06    ????????cb??????
60: 05 04 03 02 63 62 0b 0a 09 08 07 06 05 04 03 02    ????cb??????????
70: 63 62 0b 0a 09 08 07 06 05 04 03 02 63 62 0b 0a    cb??????????cb??
80: 09 08 07 06 05 04 03 02 63 62 0b 0a 09 08 07 06    ????????cb??????
90: 05 04 03 02 63 62 0b 0a 09 08 07 06 05 04 03 02    ????cb??????????
a0: 63 62 0b 0a 09 08 07 06 05 04 03 02 63 62 0b 0a    cb??????????cb??
b0: 09 08 07 06 05 04 03 02 63 62 0b 0a 09 08 07 06    ????????cb??????
c0: 05 04 03 02 63 62 0b 0a 09 08 07 06 05 04 03 02    ????cb??????????
d0: 63 62 0b 0a 09 08 07 06 05 04 03 02 63 62 0b 0a    cb??????????cb??
e0: 09 08 07 06 05 04 03 02 63 62 0b 0a 09 08 07 06    ????????cb??????
f0: 05 04 03 02 63 62 0b 0a 09 08 07 06 05 04 03 02    ????cb??????????
I prefer to use register on i2C communication. This is easier to get all the register ready first.
JuanPZ
Sun Sep 16, 2018 12:31 am
ex:
#include <Wire.h>
void setup() {
  Wire.begin(8);
int index=0;
void OnRequest() {
void loop()
  delay(1);
0x0b
0x0a
0x09
0x08
0x07
0x06
Thanks for the explanation.
Actually, I change a little bit the way to comunicate. Sadly I didn't had time to write a reply (in fact, right now I'm not in my house), but the way that I fix it was like this:
1) First, the message is being built when I change a variable instead in OnRequested.
2) In my Pi side, I send a i2cget with address (the Arduino get that address in OnReceived) and I store that in a global variable.
3) After OnReceived, the arduino will Call the OnRequested function, where it's sends the X char of the string (which is also a Global Variable)
4) Repeat the steps 2 until I receive all the bytes (in the Pi Side there is a variable that store the count of byte that there should be).
Tomorrow I will update with the code of both the Pi side (.php) and the arduino side (.ino)
danjperron
Sun Sep 16, 2018 12:52 am
Perfect! This is more or less what I ask you to do!
JuanPZ
Sun Sep 16, 2018 11:21 pm
Here is my code:
Pi side (.php)
function GetActualLightColor() {
    $lights = read_string(12);
    //Proccess the data
function read_register($address) {
    $cmd = 'i2cget -y ' . $GLOBALS['i2c_bus'] . ' ' . $GLOBALS['2ic_first_slave_address'] . ' ' . $address . ' b';
    return trim(shell_exec($cmd));
function read_string($strLen) {
	$result = "";
	for($i = 0; $i < $strLen; $i++) {
		$intVal = intval(read_register($i), 16);
		$result = $result.chr($intVal);
		usleep(25 * 1000);
	return $result;
This is the Arduino code:
#include <Wire.h>
#define Rpin 9
#define Gpin 5
#define Bpin 6
#define ARGBStrLen 13 //I use snprintf so the lenght must be N+1
int posToSend = 0;
char ARGBStr[12];
  if(Length == 1) {
    posToSend = Wire.read();
    Serial.print("New pos: ");
    Serial.println(posToSend);
    return;
  snprintf(ARGBStr, ARGBStrLen, "%03d%03d%03d%03d", aValue, rValue, gValue, bValue);
void OnRequest() {
  Wire.write(ARGBStr[posToSend]);
Note: I deleted a lot of code to make it simple. the xValue variables from arduino I proccess in another part NOT included in the example code
Anyway, thanks for the help!
