Serial loopback not working with new build
Posted: Fri Aug 10, 2018 5:22 am
I'm trying to setup my alarmdecoder with the latest build (It all used to work with Jessie) and I'm running into some issues just getting the serial port to work now (let alone the alarmdecoder)
Thus I've done a simple test. I've disconnected the alarmdecoder from Rx/Tx and I've shorted Rx and Tx (BCM GPIO14 & 15) with a wire. Then I loaded and tried typing only to find out that nothing echo'ed after disabling hardware flow control. PS: I ran minicom as root to circumvent any potential issue regarding permissions.
My OS is (cat /proc/version):
My config.txt file (cat /boot/config.txt | grep uart):
My cmdline.txt (cat /boot/cmdline.txt)
Looking for getty using it (ps aux | grep getty)
Looking for other processes using AMA0 (ps aux | grep ttyAMA0)
Permission on device blocks:
At this point I'm running at a loss as to what could possibly be going wrong. Any idea? I've tried this on a Raspberry Pi Zero as well as an older raspberry pi B (rev 2.0) with no luck. I'd appreciate any ideas/pointers at this point.
Thanks,
Chris
minicom -b 115200 -o -D /dev/serial0Code: Select all
| A - Serial Device : /dev/ttyAMA0 |
| B - Lockfile Location : /var/lock |
| C - Callin Program : |
| D - Callout Program : |
| E - Bps/Par/Bits : 115200 8N1 |
| F - Hardware Flow Control : No |
| G - Software Flow Control : No |
| Change which setting? |
+-----------------------------------------------------------------------+Code: Select all
Linux version 4.14.34+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1110 Mon Apr 16 14:51:42 BST 2018
#dtoverlay=pi3-miniuart-bt
enable_uart=1Code: Select all
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwaitCode: Select all
root 712 0.0 0.3 4040 1744 tty1 Ss+ 21:33 0:00 /sbin/agetty --noclear tty1 linux
pi 1568 0.0 0.4 4272 2096 pts/0 S+ 22:05 0:00 grep --color=auto gettyCode: Select all
root 1606 1.0 0.3 4268 1888 pts/0 S+ 22:08 0:00 grep ttyAMA0Code: Select all
lrwxrwxrwx 1 root root 7 Aug 9 21:28 serial0 -> ttyAMA0
crw-rw---- 1 root dialout 204, 64 Aug 9 22:14 ttyAMA0Thanks,
Chris
