sondeben
Setting register bit
Tue Jul 17, 2018 11:35 pm
Hello all
First of all thanks a lot for this forum in which I found all answers now by reading through the replies. I am a mechanical engineer (41) and realized several hobby RPI projects up to now.
But now I am stuck: I have a FDC2214 capacitive sensor I want to connect to the RPI via I2C. I am an absolute I2C newbie and already struggle with the wake-up command.
The datasheed says:
When the FDC powers up, it enters into Sleep Mode and will wait for configuration. Once the device is
configured, exit Sleep Mode by setting CONFIG.SLEEP_MODE_EN to b0.
Device address is: 0x2A
Config register is: 0x1A
CONFIG.SLEEP_MODE_EN is on bit 13
What I did for trial is this:
onmode = bus.read_byte_data(0x2A, 0x1A)
print "onmode: ", onmode
bus.write_byte_data(0x2A, 0x1A, 0)
With the result, that I always get a value of 0, even when I write a value of 1.
My problem: The write method only allows to enter the address and register (and value) but no bit. How can I specify the bit I need to set? Or am I completely wrong?
Anyone an idea or a link where I can find an explanation. All the tutorials I went through did not answer this question yet....
Thanks in advance for any support.
Regards,
Benno
KnarfB
Re: Setting register bit
Thu Jul 19, 2018 1:30 pm
Hi sondeben,
I have not worked with those chips, but take a look at the datasheet (SNOSCZ9–MAY 2016) page 21 figure 16 and 17 (i2c write and read) and take a look at 7.6.1 Register List.
All registers are 16-bit. So you need ro read/write two bytes of data (read_word_data...). One cannot address a single bit via i2c. If you need to extract/set/reset inididual bits, read the whole word, use bitwise operators and write back the result.
hth
KnarfB
Pi Flyer
Thu Jul 19, 2018 9:18 pm
Benno,
You're not going to be able to just write one bit, the smbus "write_byte_data" method expects you to write at least one byte...hence the name of the method. Furthermore, it looks like your device expects more than one byte.
Thu Jul 19, 2018 9:27 pm
Benno,
Yes you can. Read the register first. Use logicial OR to set a bit. Use logical AND to reset a bit.
def pinOn(bank, pin):
  global valueA
  global valueB
  bit = pin - 1
  if bank == 'B':
    valueB = valueB | (1 << bit) # OR to SET bit
    bus.write_byte_data(ADDR, OLATB, valueB)
  else:
    valueA = valueA | (1 << bit)
    bus.write_byte_data(ADDR, OLATA, valueA)
def pinOff(bank, pin):
  global valueA
  global valueB
  bit = pin - 1
  if (bank == 'B'):
    valueB = valueB & (0xff - (1 << bit)) # RESET bit
  else:
    valueA = valueA & (0xff - (1 << bit))
Pi Flyer
Thu Jul 19, 2018 11:07 pm
But you must write a byte...which I thought was the obvious point of my post. The OPs code included a single value for the data portion of the i2c message as he thought he could write a bit.
sondeben
Sat Jul 21, 2018 12:13 am
Hi all
Thanks for all your replies. Surprisingly I am getting realistic values by using word_data or byte_data. Nevertheless I do not really understand why, as I am only adressing CONFIG on 0x1A with a value of 0. For my understanding I would also need to specify the bit 13 as there are different setting in CONFIG.
(Besides I am fighting with a "IOError: [Errno 5] Input/output error" now, but this is a different story I think...)
Regards,
Benno
Sat Jul 21, 2018 9:33 am
You should be using read_word_data(0x2A, register) or read_word_data(0x2B) to get two bytes returned.
You'll need to check with i2cdetect -y 1 which address your sensor appears at.
sondeben
Sun Jul 22, 2018 1:06 am
Hello Dougie
Thanks for your reply. The IOError: [Errno 5] seems to be linked to accessing via VNC in my case. i2cdetect -y 1showed random results. Solved now by working directly on the Pi.
Also understood now how to set the bits. Numbering from back and starting from 0 confused me as newbie.
I am getting some results now. But still need to figure out how to read the 12 bits with data from the 2 bytes I receive....
Thanks a lot for your support!
Benno
Sun Jul 22, 2018 7:39 am
To pick twelve bit from 16 bits, logically AND the result with 12 bits.
bit12value = bit16value & 0b0000111111111111
or (using hex because it's easier than binary bit strings)
bit12value = bit16value & 0x0fff
sondeben
Wed Jul 25, 2018 11:12 am
Hi all
I am still fighting with the communication. Trying to understand the received values I realized that there is an endian issue with the RPI. So I changed the order of the bytes read with "word" in order to get this right. Reading the MANUFACTURER ID and DEVICE ID tells me I am on the right way as I am getting the correct values for these:
def word_split1 (temp):
    first_byte = temp >> 8 # right shift 8 places
    return first_byte
def word_split2 (temp):
    first_byte_times256 = first_byte << 8 # shift left 8 places
    second_byte = temp - first_byte_times256
    return second_byte
def read_sensor(adr):
    valI2C = bus.read_word_data(ADDRESS, adr)
    first_byte = word_split1 (valI2C)
    second_byte = word_split2 (valI2C)
    revised_word = (second_byte <<8) + first_byte
    return revised_word
But when I read back the CONFIG sent with the following statement:
bus.write_word_data(ADDRESS, CONFIG, 0x1e01)
I get as an answer: 0x1e
Somehow it seems I am loosing information here.
Do I also need to swap MSB/LSB for data I am sending to the device?
The readings of the sensor values are 0xfff or 0x0, so there seems to be an issue with the configuration I need to solve first....
Regards,
Benno
joan
Wed Jul 25, 2018 11:34 am
When sending a 16 bit word quantity I2C always sends the least significant byte first.
When reading a 16 bit quantity I2C always puts the first received byte in the least significant byte of the returned word.
sondeben
Wed Jul 25, 2018 12:05 pm
Hi Joan
According to the Datasheet my device wants to have the MSB first - for reading and writing - or am I wrong?
http://www.ti.com/lit/ds/snoscz5a/snoscz5a.pdf Page 22
Writing:
ADDRESS - REGISTER - MSB - LSB
Reading:
ADDRESS - REGISTER - ADDRESS - MSB - LSB
I assume this is the reason why I do not get the right values...
joan
Wed Jul 25, 2018 12:11 pm
If the device wants MSB first you will have to swap the bytes at the Pi end. Yes, that will explain the errors.
sondeben
Wed Jul 25, 2018 2:12 pm
Hi all
Yeah - it's working.
Changing the order of the written bytes for the configuration finally made it and I receive realistic readings on all channels!
Thanks for your support!
Benno
GabrielTVP
Fri Jan 04, 2019 4:22 pm
Benno
Would you have the code to read the data for each channel?
Gabriel
