greengoblin
Problem with ST7735S controller lcd display
Tue Jul 17, 2018 4:48 pm
Hello everyone
I've just bought a lcd display to show an image with, is this one: https://es.aliexpress.com/item/0-96-inc ... 0000000000
The problem is that I'm new in this world and I don't know how to set it up and thought I've searched for information I can't get the way to make it work.
Any ideas?
Thanks.
juj
Re: Problem with ST7735S controller lcd display
Wed Jul 25, 2018 7:13 pm
If the only difference between ST7735S and ST7735R is the resolution (128x64 instead of 128x160), then you may be able to use fbcp-ili9341 to drive the display, by changing this line https://github.com/juj/fbcp-ili9341/blo ... 735r.h#L23 to do 64 instead of 160. See https://github.com/juj/fbcp-ili9341.
If there are other differences between the two, then fbcp-ili9341 probably does not apply (and may be a waste of time). In that case, try searching the web for driver code or libraries from projects that have successfully used ST7735S, and/or try to find the spec sheet to see if you can develop or port a driver for it.
Good luck!
