Jaikumar62
Multiple I2C devices interface
Mon Jul 02, 2018 12:15 pm
We are using Raspberry Pi to read the data of Acceleration sensors through I2C. And we need to read 2-6 Sensors.To read multiple sensors, we have connected SCLK lines of sensors together and SDA lines together.We are able to detect the devices with addresses 1d and 1e .But, when we try to read data from sensors one sensor is disconnecting(1d) and one senso(1e)r is giving proper data (We have connected 2 sensors).
Is it required to add pull up resistors? and what values we need to use?
Please suggest the possible solution.
FTrevorGowen
Re: Multiple I2C devices interface
Mon Jul 02, 2018 2:14 pm
The Pi has it's own on-board pull-ups on the main I2C channel IIRC (1k8 I think).
Are the sensors running at 3.3V or, with the I2C signals buffered by level-shifters**, at 5V? (The Pi's GPIO's are not 5V tolerant)
What type of sensors are they? (make, model & maybe, link to specs)
Trev.
**FWIW, some examples here: http://www.cpmspectrepi.uk/raspberry_pi ... dules.html
Jaikumar62
Wed Jul 04, 2018 4:08 am
Hi Gowen,
>The sensors are running at 3.3V
> The sensor we are using : https://www.st.com/en/mems-and-sensors/lis3dsh.html
Arjan
Wed Jul 04, 2018 2:45 pm
With respect to level-shifters; even when the I2C slave is running at 5V, then there could be no need for level-shifters. It depends on the factors a. If the I2C slave has pull-ups to 5V, b. The ViH min for the I2C slave is greater then 3V3
http://www.raspberrypi-dmx.org/
Open Source DMX/RDM/MIDI/OSC/Art-Net/sACN solutions
FTrevorGowen
Wed Jul 04, 2018 5:21 pm
However that 5V pull-up is likely to damage a Pi . The Pi's GPIO's are not 5V tolerant! Hence the level shifters.
Trev.
